Pitney Bowes fax with error code 050
This Pitney Bowes 9820 fax machine has a relatively new PCU and was working. It was moved and sat for several months before powering on again.
2 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: need to set a pitney bowes 9820 to print a fax confirmation
Function
74
set
12
set
set
stop.
Posted on Nov 20, 2008
  • 149 Answers
SOURCE: pitney bowes 9820 error message
press function, print incomplete command report, then go to function 4 and use command numbers on report to delete.
Posted on Dec 24, 2009
Pitney bowes 9820 fax machine is popping up error 50 check printer what might be the problem
Error 50 is a service error and you will need to contact your local computer repair or go to their site and talk to customer service to get someone to fix this for you.
Hope this helped
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | Pitney Bowes 9920 Plain Paper Fax
Pitney bowes fax machine model 1630 has 76 error code, what does it mean
The heater lamp in the fuser is broken. Call 1 800 243 5556 for service.
Oct 19, 2009 | Pitney Bowes Office Equipment & Supplies
Error code 050 what is this? PITNY BOWES 9820
This is a defective laser code. The lubrication in the laser has hardened and the laser cannot turn as fast as it needs to.
Oce is the repair people for PB faxes now. 1 800 243 5556
Oct 05, 2009 | Pitney Bowes 9920 Plain Paper Fax
Always asking for an access code.
You will probably need a technician to set the machine back to it's factory defaults. Sorry
Jun 11, 2009 | Pitney Bowes 9920 Plain Paper Fax
Pitney bowes 9820 error message
Jun 01, 2009 | Pitney Bowes 9920 Plain Paper Fax
New help getting Pitney Bowes 8050 fax machine to work
The code is the same as the model number 8050, Your battery has failed and will not keep it's settings if it loses power.
May 17, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney Bowes 1530 Fax Machine
On top of the operating panel is a small removeable tab with a bump on top. (not the Blue ones) Pull it out of the machine This is the battery holder.
The battery is a CR 2032. Most electronic stores sell them.
Jan 31, 2009 | Pitney Bowes Office Equipment & Supplies
I need an access codes of a pitney bowes 9920 please
9920 is the default code. if that does not work use ***1 tech override code
Dec 19, 2008 | Pitney Bowes 9920 Plain Paper Fax
Pitney bowes 9720 error
I've never heard of that type of error. After going through Pitney Bowes vast database, the searches turned up with nothing worthwhile.
Do you have any other information I can use to further assist you?
Please let me know if this helps. Good luck!
Feb 29, 2008 | Pitney Bowes 9920 Plain Paper Fax
111 people viewed this question
