I cant Remove the number from Call reject List...... Please Solve My Problem
In your android phone click Settings > Call settings > All calls > Auto reject > Auto reject list You can remove rejected numbers from there
If you are using LEO Privacy to block unwanted calls, you just need to go into Harassment Intercept feature to unblock it.
LEO Privacy Applock Hide Safe Android Apps on Google Play
SOURCE: removing numbers from reject list in samsung f480
Goto
Settings-->Call settings-->All calls-->Auto reject
Click on 'Reject list'
Here just for making them to be receivable calls, uncheck them
If you want to completely remove, you need to click on each entry and then press Options-->Delete. But the problem with deletion is you need to do that for each entry separately.
SOURCE: removing a number from reject list in my Samsung GT-S5233A.
Hi ,
just go into menu , settings , application settings(5), call (1), all calls( 1) , auto Reject (2), scroll down to reject list and you will find all numbers added to it, simply delete them and they will be back as normal in your phonebook,
hope that'll help you
SOURCE: how to remove numbers from the reject list on the samsung sgh-j600 mobile phone?
thanks a lot Bajanguru you should have said that it was an option to reset the phone now all my stuff is gone.
SOURCE: i have added my husband's number by mistake in the
I had the same problem, here's the solution: Main Menu Settings Apllication Settings Call All Calls Auto Reject Activation: Off
