Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45862 Front Loader FDL
Thanks for your tips. I believe that we have a failed door lock. The link that you had posted on fixya is no longer active under:
http://www.fixya.com/support/support/r587965-door_latch_replacement_fdl_error
Do you have another link or somewhere that will tell me what I need to order and how to fix the problem?
Thanks for your help.
Jon
  • psgolfer70 Dec 15, 2008
    Great, thank you very much.
    Do you have a link or recommendation where to purchase a new Door Lock Assembly?
    Regards
  • Anonymous Mar 24, 2014
    front loader door in lock how can I unlock it
  • 5,911 Answers
I can't explain why the link isn't working for you, because I just went to my "Tips and Tricks" section and the link you mentioned is still there. To avoid a possible bad hyperlink again, I cut and pasted the instructions from the link for you below. If you are experiencing the "Fdl" error code, it is an indication of a door latch malfunction. The following steps explain how to replace the latch:
This advice is for replacing the door latch on the Kenmore Elite or Whirlpool Duet FRONT LOADER washing machines.
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Good luck and I hope this information is helpful.
Posted on Dec 15, 2008
  • 5,911 Answers
Try one of these websites: searspartdirect.com, repairclinic.com, pcappliancerepair.com or appliancepartspros.com. They all offer great service and competitive pricing, so take the time to shop for the best price. The first and last sites mentioned also have helpful exploded view parts drawings to assist in locating and assembly. I hope this helps you.
WATER LEFT IN MACHINE AND SMELLS MUSTY
Posted on Oct 07, 2009
Kenmore 45862 F11 error is intermittent. What is this?
Posted on Oct 04, 2009
Machine won't start code dl F
The machine is not starting because the door lock fails to lock the door as what error code FdL stands for. It flashes after the door locking routine fails to lock the door after 6 attempts. Replacing the door lock/switch assembly is the only viable if no problem is seen with the wire harness connecting the assembly to the central control unit. The link below contains the detailed instructions in replacing the door lock/switch assembly.
Replacing the Door Lock/Switch Assembly on Whirlpool Duet and Kenmore Elite Washers
Aug 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
GIVING CODE FDL?
If the door fails to lock after six (6) attempts "Fdl" will display. The "Fdl" error code indicates the door failed to lock or the control does not detect the door being locked. The likely failure is the door lock mechanism. There is always a chance there could be a loose wire connection between the door lock mechanism and the Central Control Unit (CCU) causing the error too.
Jan 22, 2011 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore with code F and the DL. It will
"Fdl" is a lock latch error code. This is an indication of either a defective door latch, defective Central Control Unit (CCU), or an interconnecting cable problem between the two. The following link explains how to troubleshoot the problem:
http://www.fixya.com/support/r4490349-fdl_error_code
I've included parts resources, if required, and the steps required to replace any defective parts.
If you have questions, please post back and let me know. I hope this helps you.
Apr 05, 2010 | Kenmore Elite 45986 Front Load Washer
FDL fault code on kenmore elite washer
F DL
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Nov 08, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 front loader F-11 and FDL codes
yes!! the F/11 is triggered under high voltage conditions like high speed spinning. The part is called the MCU motor control unit. if it goes into failure while using your machine and locks the door, just wait 3 minutes and the door will unlock after the MCU resets. Try using you machine with a low speed spin for awhile.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
My kenmore elite smartwash flashes f and dl when i try and run the wash cycle
Hi
Thanks for using FixYa. Error fdl means a Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
It has occurred due to
1. Door lock mechanism is broken or removed from door.
2. Door switch/lock unit failure. To unlock it follow the steps—
a. Unplug washer or disconnect power.
b. Check door switch/lock unit.
c. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Please revert for further assistance.
Thanks
Rylee
Jul 21, 2009 | Kenmore Elite 45986 Front Load Washer
Will not lock, seems to be in the locked position. DS pushed "something" in that should be out.
You'll need to manually unlock it.
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 26, 2009 | Kenmore Washing Machines
Received an error code dl f on my Kenmore Elite 45986. Replaced the locking mechanism and I am still receving the same error and results. It just clicks and gives this error code. Thanks "dl F" error code...
The "Fdl" error code indicates a problem with the door latch assembly. The clicking sound you hear is the door latch attempting to latch. If it fails to latch, the wash cycle will not start and the error code and audible beep will occur. There should be a tech sheet inside the washer. It's usually located behind the bottom panel under the door, or along the inside of the casing on either the left or right hand side. The tech sheet will have a list of error codes, procedures on how to perform diagnostics, and troubleshooting hints. It's strongly recommended that you leave the tech sheet inside the washer, so you don't lose it.
Repairclinic.com carries the door latch for about $50 and is listed as item number 1094190.
Searspartsdirect carries it for slightly less for about $43 and lists it under the "Door and Latch Parts" as item number 7 (part #8181700).
If you go to my profile and click on "Tips and Tricks" I have a posting there on how to change the door latch on a front loader. It's a very simple repair that any Do-It-Yourselfer can accomplish.
If you can't find the instructions you need, or need further assistance, please post back and let me know. I hope this helps you.
May 11, 2009 | Kenmore Washing Machines
Kenmore 45986 door lock
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Jan 25, 2009 | Kenmore 43142 Front Load Washer
KENMORE ELITE WASHER error (DL) then (F)
May 07, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
486 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
