Question about Thermador PDR486GDZS Gas Kitchen Range
Thermador Range Blue Blinking Lights Error
I have a Professional Series Thermador Range (PRD486EDG) On the small oven, the blue lights are blinking. The first blinks twice and the second light blinks once. I think this translates to a "21" code, but I don't know what it means. Thanks.
SOURCE: Flashing Lights on Thermador Oven/Range
the lights flashing in a sequence indicates the error code. The error codes indicates what the problem is with your stove. Based on the response to your message, it sounds like their error code is 12, one then two. It is not clear what your error code is.
There is an explanation of the error codes on the wiring diagram that comes with the stove. I found the wiring diagram for my stove taped to the inside of the kick plate. The kick plate had to be removed to find it.
my oven is not working either. the error code I get is 34. I am told by a technician that error code indicates that the computer is not recognizing that the cooling fan is operating, which is why my oven will not work.
When I try and order a new cooling fan from Thermador, the website says that it is temporarily out of stock. Obviously, other people are having the same problem I am.
Posted on Mar 06, 2009
  • 1891 Answers
SOURCE: thermador prd486edg oven/heating flashing 1/2
only code that is close ( e12) ( E12) look at display and make sure .. mm if the code is E12 then " CT oven:latch switch problem ) this may help Note E . 1 turn the clock selector knob to off 2 tweak the oven control by turning the clock selector slightly to the left ( counter clockwise ) this may stop the flashig message / beeping and clear the display window. " try it and pray mm .
Posted on Dec 09, 2009
SOURCE: Thermador Pro Harmony Range--> Blue Lights Blinking
thermador rang, blue light blinking. Oven is not working,
Posted on Feb 05, 2010
Daniel S
  • 4323 Answers
SOURCE: my thermador pro grand PRD486EDG range's blue
Hi
The issue seems to be with the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Feb 20, 2011
SOURCE: PRD486EDG doesn t heat up Oven light blinks once
PRD486EDG Oven doesn't heat up. Oven light blinks twice, then the heat light blinks twice. Tried reseting the power
Posted on Apr 23, 2011
My HBS-900 headsets have a blinking red and blue light that blinks when it's on and off, it won't pair with anything, and when I put it on charge it blinks red and blue
Usually this means there may be too many Bluetooth devices in range to connect to and cannot connect so the blue and red flashing lights indicate an error. A second possibility is that the device is broken. This might sound strange but sometimes several sharp firm raps to the side with the charger port and lights along with a few power cycles often snaps it out of error and back into operation. Good luck.
Dec 28, 2016 | Radio Communications
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
May 10, 2011 | Thermador Pro Grand PRD486EDG (Dual Fuel)...
Oct 03, 2009 | Thermador Pro Harmony PRG304EH (Gas)...
We have a Thermador PDR484GG with flashing blue lights!!!
one thing i found with the little blue flashing light is the main board in the back of the range not fun
Jul 01, 2009 | Thermador PDR304ZS Dual Fuel (Electric and...
Mar 18, 2009 | Thermador Pro Grand PRD486EDG (Dual Fuel)...
Blue blinking lights
I'm Neil
No problem
Check your Manuel
Call The Manufacturer you have a warranty!
Please rate my solution!
Jul 22, 2008 | Thermador PGR366 Gas Kitchen Range
Thermador PDR30 4ZS/05 duel fuel
It's the motherboard. You must have had a power surge. I just replaced mine. Motherboard + shipping 200.00. its not easy to replace but not so difficult.
Mar 11, 2007 | Thermador PDR304ZS Dual Fuel (Electric and...
Blinking oven and heating Lights
for no reason the cleaning light went on, even though the oven was not on. The oven light and heating light were alternating each blinking 5 times. The door locked up, too. It seemed to think it was in a cleaning cycle. Any way, problem solved by throwing off the main breaker and all is working fine since... except now, for no reason the oven fan, not the exhaust fan, stays on all the time!
Feb 12, 2007 | Thermador PG486GEBS Stainless Steel...
Thermador PDR486GDZS Gas Kitchen Range Logo
402 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
