Question about Breville ESP8XL Espresso Machine
Breville Cafe Roma ESP8XL - cup is moving during the process
I just got this machine and I did a run with water only to see how it works.
I see tow problems:
1. The machine rattles and the cup is moving when dripping.
2. It does not drip equally through the 2 spouts of the filter holder. So if I want two cups, one will be full faster.
Is there a way to fix these or do I have to return the machine?
  • Anonymous Mar 29, 2014
    18 teaspoons is equal to how many cups, dry?
Once you've got the tamp right: no more rattles! The perfect tamp also makes a better cup of espresso.
The single hole is not a cheapo, lazy manufacturing defect.  The Cafe Roma has a "double walled" basket which is to produce a thicker crema.  The single hole is designed to allow pressure to build up behind it thus forcing a jet effect in the basket, giving the the coffee its crema.  This, by the way, is why it is also a sloppy/wet puck rather than a dry one.
The thump during steaming just gives me something to dance to in the morning.  "When the saints go marching in" always seems to come to mind;  perfect timing.
I am very happy with my Cafe Roma.  Just took some practice.
Happy espresso to you,
Posted on Jan 18, 2009
    Problem Solver:
  • 18 Answers
GET A NEW MACHINE. i just bought one used for $25. the previous owner said it had been sitting in his basement for over a year, and that he used it only maybe ten times (WHY, I WONDER?). it was not cleaned before being stored. let me preface my comments by stating that i have used a saeco-made starbucks barista machine for about 9 months now, and this one was supposed to be a backup. here are the things that i have issue with about this machine: 1) re: the thumping sound during steaming: the pump inside the machine is poorly mounted; it has a metal bar around it which, i believe (from examining the guts of the machine) has scarred an adjacent plastic piece from repeated impact, while causing the thumping sound everyone hears. one can feel the vibration on the outside of the machine by placing a finger or hand anywhere on it's surface. the cause: poor quality pump and poor manufacturing.
2) and in support of "poor manufacturing" theory: if you hold up the metal coffee filter basket to the light, you can easily see the hole. yes, coffee comes thru ONLY ONE HOLE in the filter basket. there are a score of other "holes" that you CANNOT see light thru-these are FALSE HOLES. comparing to an espresso maker that costs twice as much, every hole seen in the filter basket is in actuality a hole (light can be seen through each). clearly, the breville basket lacks a crucial/vital step in its finishing: the last step of drilling out each individual hole (instead of drilling only one).
to review: i spent $25 on this POS. how much did you spend? no wonder cust. service doesn't help!
Posted on Jan 11, 2009
I have a Breville Cafe Roma Machine. I made about...
have you tried to use the sharp pin and try to dislodge coffee grind from the filter cup? You will need to remove it from the filter holder to gain access.
May 20, 2010 | Breville ESP8XL Espresso Machine
How do I get my breville cafe roma espresso machine to pump water out of the water tank and through the machine? It won't create steam or brew coffee and the water level in the tank won't deplete when the...
Same thing happened to me and I had to push down on the water tank a little more firmly. It looked like it was seated okay but I guess it needed to be pushed down more to open the little spring-loaded opening at the bottom.
Dec 27, 2009 | Breville ESP8XL Espresso Machine
Breville Cafe Roma esp8xl
push down on the water reservoir. ours took a while to prime.
Aug 15, 2009 | Breville ESP8XL Espresso Machine
Cafe Roma producing more water than steam
you really need to decalc frequently, at least every 2 months. after it goes too long, you will see that problem. have not figured out yet how to fix it.
Jun 18, 2009 | Breville ESP8XL Espresso Machine
Cafe Roma Expresso/Cappucino machine
My understanding is that this is normal with units like the ESP8XL which use a pressurized portafilter. Non-pressurized units will leave a dry puck of used grounds.
Nov 28, 2008 | Breville ESP8XL Espresso Machine
Plastic baffle came out of drip tray when moving.
I think it should fit in the back of the driptray.
Oct 04, 2008 | Breville ESP8XL Espresso Machine
Breville ESP8XL Cafe Roma does not pump, or build up enough pressure to push the water through the coffee. Help.
Make sure the filter is clean, that in the holder and in the machine. If it is clean then i think your pump have to be replaced:-(
Jul 21, 2008 | Breville ESP8XL Espresso Machine
Breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
Mar 06, 2008 | Breville ESP8XL Espresso Machine
Breville ESP8XL Espresso Machine Logo
686 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
