Question about Panasonic SC-AK200 CD Shelf System
SA AK200 does not appear to turn off completely
When I turn the system off it says goodbye, in a few seconds it clicks and the display read hello and starts running Heavy, Vocal, etc.???
  • babette_p Dec 15, 2008
    Thank you!!
  • 10,594 Answers
HiFi system actually turned Off when you press power button and display of hello, heavy, vocal etc is demo mode of this system and it activates when unit goes to power off.
You can change its settings like not to show demo mode etc and this procedure is described in owner's manual.
Thank you.
Posted on Dec 15, 2008
Parrot ck3100 stuck on goodbye screen any way to reset it ,thank you
Found this on the net, not sure if it works or not:
"Hard reset the CK 3100 by pressing all three buttons for two seconds and then pressing them a second time (warning initializes factory settings)
2. hard reset thisback to factory settings"
Straight copy paste out of fixya website
and the link to the source:
Parrot CK3100 Bluetooth car kit hard reset
Oct 08, 2016 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Hi I am having problems with my Panasonic SA-AK200 stereo system when in AUX mode. What happens is when I play through AUX mode The Sound only comes through One speaker usually the right one but when on cd...
Looking at your question, it appears that the problem is not always on the same channel (right/left). This makes me wonder if the problem is the source or the cables you are using. The easy way to test this is to connect everything, check which speaker is not working, then swap the left and right cables at the aux jack. If the same speaker does not work, then it is a problem with the SA-AK200. If the problem switches to the other speaker, the SA-AK200 is not the problem and you should try replacing the cables or suspect the source (whatever you are trying to connect to aux) is at fault. If the SA-AK200 is the problem, I would suspect bad solder connections at the input jacks. Good luck
Dec 12, 2017 | Panasonic Audio Players & Recorders
SA-AK-37 Music system showing 'F-61'
its got a door problems a part in the cd deck bracks off and its basturd to fix.
Mar 20, 2010 | Panasonic SC-AK200 CD Shelf System
Reads "Goodbye" and I cannot turn it back on. Have tried to sync from phone numerous times. Its not that.
If the display is stuck on goodbye then you will need to reset the brain box by disconnecting for a couple of minutes.
Nov 16, 2009 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Toshiba sd-kt50 dvd player turn on open/close hello appears protection appears and goodbye comes up turns it self off. we had two second power offs not associated with a storm
the sudden power cut-off can either blow the fuse or corrupt the system of DVDs.but, some DVDs has protection for this occurrence.try not to use it for sometime.then if it's well rested try turning it on see if is resets it's protection circuit.if not, a new unit or call a technician for it.
May 07, 2009 | Televison & Video
Service manual for Panasonic SA-PM16
When I turn the machine off, it says, "Goodbye." Then five seconds later it turns itself back on again, including the EQ button. Is it doomed, or can I find a cure out there???
Mar 22, 2009 | Panasonic SC-PM16 Shelf System
Switching off of SA-AK-37 Music system
Do you have the manual, I think panasonic put some of there fault codes in the back.
Seems to have lots of people saying it could possibly be a power supply fault, an amp fault or shorted speakers.. Some people have gone to the extreme of actually buying new components and trying to unsolder and resolder to try to fix it themselfs.
Try contacting Panasonic, they will be able to advise you better ot possibly repair / replace the system.
Jan 31, 2009 | Panasonic SC-AK200 CD Shelf System
Panasonic SC-AK200 CD Shelf System Logo
603 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
