Question about Pioneer DEH-1800 CD Player
Need color codes of speaker connections,power connections etc...
Need basic installation connection color codes
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand. almost all Pioneer units follow the ISO standards for color coding their wires. Pls reference below:
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 15, 2008
How to connect aftermarket radio into 2002 toyota camry JBL radio (the standart wiring doesn't work).Thanks
Your aftermarket radio should have color-coded wires which identifies power, ground, speakers, etc. most depaetment stores carry a radio harness adapter kit. This will connect to your radio's exact color coded wires, and will plug right in to your factory's wiring plug. And don't forget electrical tape.
Aug 28, 2011 | 2006 Toyota Camry
I want to change my F-150 radio, basic, with a radio/cassette/cd, will I need a different harness?
You will need a harness adapter for your model truck. This you will want to solder and heat shrink over the solder joints (Dont just twist tem together) then just plug it in to the factory harness.
You will probably need an adapter kit also.
The wiring harness adapter should come with the color codes for the wires corresponding to your trucks speaker and power wires pinouts make sure you correctly connect them to the color codes of the stereo for proper speaker placement and voltages
Mar 13, 2011 | 2006 Ford F-150
My 1995 chevysuberban has no speakers and would like to know how to wier the speakers in my car?
The car is not important .Connecting speakers to any unit is basically the same. there should be a color coded wire harness connected to your head unit. The speakers are as such: White & White with black stripe (Front Left) Grey & Grey with black stripe (Front Right) Green & Green with black stripe (Rear Left) Purple & Purple with black stripe (Rear Right) The Solid colors are (+) Positive and the Stripes are (-) Negative. Connecting any one of these incorrectly will result in phasing problems. Hope this helps. dreamsystems
Feb 09, 2011 | Car Audio & Video
Need wiring color code for power &speaker
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Aug 25, 2009 | Sony CDX-F5710 CD Player
What color wires are what on this thing like i know yellow red and black but what are the speaker wires and rem etc.
Hello foxrider_911,
Orange is for illumination and connects to the "dimmer" wire on your vehicle wiring. Yellow/Black is the mute lead and connects to your bluetooth or hardwired audio mute function. Blue/White (terminated with a quick disconnect) is the remote wire and provides a 12V positive turn-on signal for a power antenna or remote amplifier. Speaker wiring follows the industry standard color code:
White - left front +
White/Black left front -
Gray - right front +
Gray/Black - right front -
Green - left rear +
Green/Black left rear -
Violet - right rear +
Violet/Black - right rear -
If you do not have a copy of the installation/user manual, you can download a copy from Crutchfield. It will have the complete wiring diagram and color codes as well as operating instructions.
Hope this helps.
Jun 29, 2009 | Pioneer DEH-P47DH CD Player
No identification of wiring color code
Usually it's....
black = ground
red = switched battery power
yellow = constant batery power (for clock...etc)
orange = illumination
blue = amplifier turn on or accessory (electric antenna, amps etc)
green/white/purple/grey are speaker wires.
May 09, 2009 | Car Audio & Video
Connection diagram for XR-CA300 SONY car stereo
Hello eliasrvc2,
Sony's support site shows the color codes for wiring both a 9-pin and a 16-pin harness. Click the appropriate harness to bring up the color code table.
Hope this helps.
May 05, 2009 | Sony XR-CA300 Cassette Player
Trying to install pioneer cd player in street rod.
You need:
a 12v + source from the battery (yellow wire)
a 12v + switched with the key (red wire)
a Ground (black wire)
then you need your four speakers hooked up, i'm unsure of the color codes on them but they are usually pairs i.e. green and green with black stripe for one speaker white with black stripe for another etc.
other wires such as illumination (orange) and power antenna (blue) are optional
the illumination (orange) you would connect to 12v + from a headlight switch and it would cause the unit to dim when you turned your headlights on
The power antenna (blue) is used, as the name implies to control a power antenna if you have one, or more commonly as the signal to turn an audio amp on (on the remote connection)
Hope this helps
Feb 15, 2009 | Pioneer DEH-1600 CD Player
Radio wiring color codes
u need the colors of the radio or the car wires.... here are the car wires and the radio are below that. I suggest however gettiing a wiring kit..They are around 8 dollars and well worth the money. It makes is so easy to connect a radio.
RADIO 12V|orange + at radio
RADIO GROUND Black
RADIO SWITCH yellow
POWER ANTENNA dk. green at radio LF SPEAKER tan - gray at radio or LF speaker
RF SPEAKER lt. grn - dk. grn at radio or RF speaker LR SPEAKER brown - yellow at radio or LR speaker
RR SPEAKER dk. blu - lt. blu at radio or RR speaker
Radio wiring
constant power yellow
switched power red
power antenna/amp turn on blue
illumination is orange
all speakers the one with the black stripe is the negative connection.
right rear is purple
left rear is green
left front is white
right front is grey
hope that helps ya...
Aug 30, 2008 | 1999 Oldsmobile Alero
Installing visonik bass system
Here is a link to visonik to download manuals.
http://old.visonik.de/en/downloads.php
If you let me know your model number of the sub, vehicle make and model, and brand and model of headunit or CD player you have then i can provide wiring color codes, recommended wire routing locations, etc...
Jan 03, 2008 | Visonik 10" 500-Watt Single Bandpass...
Pioneer DEH-1800 CD Player Logo
856 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
