Question about Acer TravelMate 512DX Notebook
My acer lap top keeps shuting down so i tryed to run the recovery disks and it shut down in the middle of the recovery now it doesent show windows xp it just sayes fault protection can you help me and try to get it from shuting down even if i just turn it on after a few minutes it shuts down it was doing this before and i sent it to the manufacture and they said they replaced the mother board and worked fine for 3 months but now this i dont know if it is a bug or software problems can you help ? if i can get it to stop shutting down i can run the recovery disks please help?????
Try getting into your bios setup and changing your boot device from the HDD to DVD or Flash drive. On most Acer's you should be able to get into the bios settings by pressing the f2 key several times at power on stage.
Posted on Jul 24, 2012
  • 95 Answers
Test your harddrive and make sure you don't have any bad sectors.You can do this through the bios on some machines.
Posted on Dec 15, 2008
I have a IBM Think pad laptop running Windows xp that keep shutting down, it go through the POST OK. then 2-3 minutes it shut down. The fan is OK, and the cooling system is ok, so what do I do next.
Hi
its either a software problem or a hardware problem
normally over heating shuts down older style laptops
try using a lap top cooling pad
sometimes its a faulty hard drive
Try reinstalling XP windows again
cheers
May 21, 2015 | IBM Computers & Internet
Biostar TA790GXE 125M keeps shuting down when I boot windows, on SATA and IDE hard drives
Run the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 31, 2012 | Biostar TA790GXE 128M 5.x Motherboard
Medion mim2330 keeps clicking off before booting
run the check disk utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 29, 2012 | Medion Computers & Internet
I could not shut down my lap top it is just stooping at shutting down in windows 7 so i have changed the os now using windows xp but still the problem conitnues so i am holding power button for a while to...
It could be a problem with your disk-drive -- Windows XP (or previously 7) is trying to write some files, but the files cannot be written, and so the shutdown process never completes, and it never tells the motherboard to turn itself off.
Try a different disk-drive.
Feb 19, 2011 | Computers & Internet
My acers aspire 3690 laptop boots up to windows xp home perfectly but the usb ports do not work,it shows that it is working but when i plug in a usb device it does not try to reconigse it, i cannot find...
The partition D is actually a back up partition that has factory image for the original Operating system that was installed in the computer.
factory recovery ( DATA LOSS )
if the computer is booting to windows, then click start and open a folder named as 'acer' listed in ' all programs '.You will find the ' Acer e-recovery managent ' in that folder.You can open it and click allow for the user account controls.Please click 'restore ' for the next screen and the select the first option, 'completely restore to factory defaults '.Follow the on screen instruction to initiate the Recovery.
The Alternate method for starting the Recovery on startup is using the combination of ALT+F10 ( some models its ALTgr ) on startup.Press and Hold down the ALT( Left hand of space ) and at the same time keep on tapping the F10 key till you get the message " Windows is loading files".Just follow the On screen Instructions to start the Recovery.
Oct 22, 2010 | Acer Aspire 3690-2196 Notebook
I HAVE ACER TRAVELLMATE 6231.NOW IN THIS LAPTOP OS IS CORRUPTED,SO I WANT TO REINSTALL OS BUT WHEN I INSERT BOOTABLE CD IT SHOW ME "SETUP DID NOT FIND ANT HARD DISK DRIVES INSTALLED IN YOUR...
You are trying to install windows xp? The normal windows xp cd will not have drivers for newer laptops. You will get this error message.
What you need to do is to try using acer recovery instead.
Acer machines should have a build in recovery, hold down ALT and presson F10 repeatedly when you power on the machine, keep pressing every 2seconds until acer recovery comes up, if it doesn't come up then yourmachine probably doesn't have that option, the laptops mostly have it.
If you are unable to do the above then you may be able to order recovery discs from ACER --https://secure.tx.acer.com/RCDB/Main.aspx?brand=Acer
Sep 20, 2010 | Acer Aspire One PC Notebook
Received a blue crash screen, Alt,F10 for erecovery, showed copying files, then tried to reboot and shut down without completing reboot. Now when try to start, showes windows small window and moving dots...
You can use a torrent site like isoHUNT, to download a copy of the Acer OEM vista disc, this is a little illegal, but if you use your own Windows key from your COA sticker, it should register and activate ok.
You may have to download your drivers seperatly from from ACER.
You will need a torrent client like UTorrent, and the download could take a day or so
Aug 27, 2010 | Acer Aspire 5100 Notebook
I have no Acer Recovery disks My lap top is giving me 5 options Systems Repair - tried this doesnt work Systems Restore - tried this doesnt work Windows Diagnostic Tool - tried that took bout ten mins and...
Could you look at solutions other than running a system restore? What is the initial issue that is requiring you to run the restore?
If you're at the point of needing to run a restore, you do need to get your hands on the discs, I would recommend borrowing the discs from someone else with an Acer, or purchasing them from the manufacturer. Trying to borrow discs from someone might be an issue as Acer no longer provides physical recovery discs, the process is run directly from the laptop and the files are on a partitioned section of the harddrive.
Dec 08, 2009 | Acer Aspire 3000 Notebook
Recovery Manager
This may be a corrupt OS try removing the ram module (First remove all power sources including batteries) then clean the connection of the RAM modules using a pencil erraser replace them very carefully then reboot if this does not help buy a USB IDE connector converter you could basically open all your files in another computer to do this you need to remove your lap top hard drive buy the compatible USB IDE or SATA which ever fits you hard drive then connect it to a PC like using a USB Flash disk or Card
May 31, 2008 | Acer Aspire 5100 Notebook
Lap top not going past password entry
Go  safe mode with system administrator and from run + msconfig + startup and then desable all applications on start up
Oct 15, 2007 | Acer Aspire 5100-5033 Notebook
Acer TravelMate 512DX Notebook Logo
105 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
