Question about Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum
Hoover Steam Vac Dual V brushes won't turn
Seems the square hole that the brush spindle fits in is frozen will not turn either, I ordered a new brush and that did not fix it of course. I love this carpet cleaner but am frustrated that I have used it approx. 7 times and it is broke already. reading the posts I do think it is the Turbine and a very expensive fix.
  • 2 more comments
  • Anonymous Dec 31, 2008
    I have used the carpet cleaner twice and the brushes stopped working. I cleaned out the screen on the bottom of the cleaner as it is suggested in the Manual. I am currently looking for the reciept for this item, in order to return it. I believe it could be the Switch for the turn off for the brushes could be the fault. I am not willing to fix something that I can still return.
  • elhickerson Jan 13, 2009
    I have used the Hoover Steamvac Dual V exactly 2 times and the brushes will not turn. As someone else mentioned it appears to be the switch as the turbine runs free but will not turn on. I think the linkage has come loose or is broken. Can you tell me how to remove the cover to look at the switch linkage?
  • Anonymous Mar 21, 2009
    basically the EXACT same thing and cannot find an answer on the net or anywhere.
  • deborah blackwell Jul 17, 2013
    I have 4 Hoover Carpet cleaners and the 4th was the last one I will bu because on all four of then, ther brushes will not turn. This last one was used 4 times. I love the cleaners but this is just too frustrating for me.
The brushes are driven with air pressure from vacuum motor. The switch merely opens a small door to allow air flow. usually there is a screen that is plugged that stops air flow which stops the brushes from turning. I too only used the appliance once and it broke. The round disc (turbine) had become jammed with no major obstruction. Cleaned anyway and put back together and it started to work again. I am so done with Hoover--no more of their products for me. To fix. the whole brush motor had to be removed and disassembled and cleaned. Not impressed at all!
Posted on May 11, 2009
  • ewil56 Jul 16, 2010
    2010-0716 worked like a charm, worth 1 1/2 of your life. Sure is, cause if I had to take it in to be serviced, wait, go pick it up, pay for it..... jes. Remember read the diagram and follow the screws... Female 54, oh yea, can still do it. Thanks for you information.
    New Friend:
Thank you for your advice. I will try to clean the motor and see if it just needs to be cleaned. However, I do want to say that this is the second identical cleaner we have had and we have had no problems with years of service. We gave our first one to our son who really needed it and it is still working after probably 10 years of service or more. They are easy to fill, have large tank capacity, clean the carpet like new, and we have 3 dogs who track in dirt and shed. I would buy another in a heartbeat, but will try to fix this one first. Again, thank you for your help.
Posted on May 29, 2014
Actually I did and do have this problem. I've taken the vacuum motor out and found that the bearing was rusted and would not allow the mechanism to turn. I cleaned it repacked it and it worked for about 8 months and now I have the same problem again. I also had to replace the upper tank for the cleaning fluid as it was cracked and leaked. I will now replace the bearing once I remove it. I have already returned one unit back to Sears for similar problems under warranty, but with it constantly breaking down - the only remedy seems to be to fix it yourself. It's the only way to keep the unit for more than 12 months.
Posted on Jan 07, 2010
I have the same problem right now,was about to clean my carpet but figuraute that brushes stoped turning...so i m going to remove the brush motor and try to clean it.
Posted on Sep 06, 2009
Buy products made ONLY in the USA if you can find one!!!
Posted on Aug 09, 2010
The brushes won't spin. I put new brushes on and it still doesn't spin.
Usually when the brushes won't turn it is due to a bad turbine. Insert a screwdriver into the square hole that the pin on the brush fits into, and see if it turns. If it is seized up, the turbine assembly will need to be replaced.
Jun 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
How do we get at the drive belt? The cover seems to be sealed.
There is no belt in a Hoover SteamVac. The brushes are turned by an air driven turbine. If the brushes are not turning, it is usually because the turbine has seized up and may need replacement. Insert a screwdriver into the square hole that the pin on the brush assembly normally fits into and see if it turns. If it doesn't, you will need a new turbine.
Jun 21, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
The Hoover steam vac dual v does not spin its brushes and I dont know how to dismantel it to view the belt .
There is no belt on the steam vac - it operates on air flow. Remove the brush and insert a flat screwdriver into the square hole. If it does not turn, the turbine has seized up and must be replaced. Remember that the brush will not turn unless the lower tank is in place, and the handle is tilted back.
Jan 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Brushes on Hoover steam vac dual v do not turn
(1) Assure the Brush Control on the hood is NOT set to the OFF position.
(2) Remove the brush assembly by pulling/unlatching it from base on each side.
(3) Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism.
(4) Remove and clean the intake filter. One the base of the cleaner, behind the brushes, squeeze the two red abs together and pull the panel down to access the screen. Clean the hair/debris off the screen and reassemble.
Nov 19, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover stean vac dual with 5 brushes
I think this is the same unit I have, I might have a couple of solutions. No, there is not a belt that turns the brushes and there is not a fuse.
First of all, make sure the brushes have been clicked into the machine properly. The entire plastic housing unit for the brushes can be removed by pulling on the casing gently. It should pop out. Make sure the pegs and clips line up with the holes in the machine when reattaching the brushes. You should hear it click when they are on properly.
If the brushes are attached properly and they still won't spin here is another possible solution. This happened to mine.
The plastic pegs on the housing unit for the brushes might have been stripped out. The pegs are supposed to be squared tip to click into the square hole of the machine. If the pegs aren't the same shape as the hole, the machine can't grab them to spin the brushes.
The tallest peg on mine somehow got stripped to a rounded shape. I tried wrapping tape, plastic, etc around the peg to make it fit in the hole snug, but it only worked for a few seconds and broke again. I am going to have to replace the brush set. You can order parts from Hoover but I haven't priced them yet.
I hope this helps you.
Aug 30, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Brushes will not spin while locked in machine..
I have the same problem and think I know the solution.
The plastic pegs on the housing unit for the brushes have been stripped out. The pegs are supposed to be squared tip to click into the square hole of the machine. If the pegs aren't the same shape as the hole, the machine can't grab them to spin the brushes.
I hope this helps you. Certainly is cheaper than replacing a motor or machine.
Aug 23, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Brushes not rotating on my Hoover Steam Vac Dual
The brushes are all connected to a single shaft. This square shaft is connected to 2 sets of gears and then another shaft which is turned by an impeller (suction from the vaccum pump is used to turn the impell and thus the brushes). There are 2 bearings that the impeller shaft turns on. It's likely these are rusted up and just need a bit of WD 40. Took me 30 min to take apart, lube, and put back together. Remember, its plastic. If things won't come apart, look for another screw. Mine was a brand new unit and the top bearing was rusted.
Sep 22, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Steam Vac Spin Scrub
Remove the brush block, is the shaft on it or broken off. Replace the block if broken off. Turn unit over, with brush block removed, handle tilted back, is the square hole turning, if not then the turbine is bad, this is what turns the brushes.
Sep 01, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Brushes won't spin on hoover steam vac ls
I have the SteamVac Dual and there's a screen on the underside of the unit. It's beneath the brushes and it's red. You have to pull and wiggle it to get it out. With the machine unplugged, lay the unit with the handle on the floor. In the owner's manual ( http://www.hoover.com/pdfs/manuals/F7222900.pdf ) this is shown on page 10 figure 3-2. Clean that screen.
If they still won't spin, then take the brushes out. Again, with the unit on the floor, you simply grab the unit firmly and pull towards you. It's much easier to remove than the screen. I took the brush unit outside and blasted it with the house. You'll have to pull out whatever fur balls are clogging it but eventually you'll see that the brushes spin freely with the water squirting on them. Plug the brush unit back in and - in my case - they started spinning.
Jun 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes not working
Check the filter from the bottom, it has a red frame, pull it out far enough to clean it, if it is clooged, then the brushes won't spin. If it is clean, pull the brush block out, make sure the shaft that goes up into the turbine is not brokked off, if it is replace thebrush block. With the brush block out, turn on the machine and look up where the brush block goes, there is a square hole, if it is turning, then it is ok, if not, then the turbine is either clogged up or the turbine has gone bad.
Jun 20, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum Logo
5,287 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
