Problem with getting second wireless controller to funtion
We just purchased Tetris Worlds for our PS2 so we can compete two players on the same console, but cannot figure out how to get the second wireless controller to work.
Re: problem with getting second wireless controller to...
Theres a small button on the console press it and there is a small button on the back if the controler if you press them at the same time the console should connect to the controler
Maybe the disc is scratched (Check the bottom of it) which would explain the disc reading error, or the lens are dirty (Should get a DVD Cleaning KIT), which also explains it.
The PS2 has had some issues with PSX games. In any case, its probably a good idea to clean the lens on your PS2. If not, then you'll probably want to adjust it.
If you aren't knowledgable in how to do this, I can't really instruct you, but I can tell you to take it to a Play N Trade or anywhere that your console can be fixed, and inform them that you want to make an adjustment on the lens.
Due to the fact that other PSX games seem to work, my guess is the copies you got are either pirated copies in normal cases, or the discs are just broken.
I have one of these and what i usually have to do is plug the little part in which plugs in to the ps2 then let that load for a few seconds then try turning on the controller. Hope it helped =]
I bought the Multi-Tap. I have tried to set it up for 4 players and it doesn't funtion.
I have the right game and still it doesn't even respond. I checked the Version and it was a right one.
I plugged it into Port 1 and plug 4 controllers into the Multi-tap and a memory card into Multi-tap's Slot A.
What should I do? All I am guessing is that the product was deffective. Am I missing something?
