Smartdisk - Peripherals - HARD DRIVE, CROSSFIRE 160GB EXTERNAL
Problem for Smartdisk - Peripherals - HARD DRIVE, CROSSFIRE 160GB...
My harddrive went out on my pc. is there a way to by pass my harddrive so i can get online or burn ....
By Green1 - usenet poster
my harddrive went out on my pc. is there a way to by pass my harddrive so i can get online or burn cds on...?
Same Problem
Apr 02, 2009
-   my hd is dameg
-   Guest
Jul 06, 2008
-   this drive is very unstable. sometimes it reads..sometimes it is not. I can't use it until now as it is still undependable. How could i fix this. -   moonchingvee
Feb 15, 2008
-   nee to install motorola phone software. I don't have the disc.-   Neci
Dec 23, 2007
-   bios not recognizing ide name and number ,cant boot up laptop ,wont reboot using recovery disc also saying no operating system found
-   stum3769
Dec 18, 2007
-   NOT WORKING SUDDENLY GIVING SOUND LIKE TRYING TO WORK FOR FEW TIME THIN NOTHING-   Guest
Best Solution
posted on Jun 18, 2007
Very Helpful)
danesh
Rank: Apprentice
Rating: 100%, 1 votes
my hdd:pm-maxtor 2f04] is not boot and no partition ,i,m think, my hard some virus
tanks
Was this helpful?
Yes
No
Solution #2
posted on Jan 24, 2008
Helpful)
Tangoblue
Rank: Wiz
Rating: 83%, 113 votes
Check the freeware sites...there are tools that you might be able to use providing you install a bootable disk or another disk drive with your O/S on it. In addition.....if you have a a dos boot disk plus (preferably) a copy of Qdos (old but very valuable program) you can at least copy to your data to disks).....the combination of these tools along with the drivers (on the boot disk...or copy then to it for your CD....could give you what you are looking for...the time to do all this is 2-3 hours if you are new...alternatively there are dos commands you can use. Failing all that (perhaps you are not familiar enough with all mentioned) your best bet is to always....back up...back up....back up....drives have finite lives. Hope this helps. Tangoblue
Was this helpful?
Yes
No
Solution #3
posted on Aug 08, 2005
Somewhat Helpful)
Pasty
Rank: Apprentice
Rating: 0%, 0 votes
No. You need the software on your harddrive to use your burner as well as other programs
Was this helpful?
Yes
No
Solution #4
posted on May 15, 2008
Not Rated)
max3072
Rank: Apprentice
Rating: 0%, 0 votes
my hardrive does not turn on chked power cable and usb there is no power
Was this helpful?
Yes
No
Solution #5
posted on Mar 12, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
The hard drive is where the operating system is stored. Thusly, if your hard drive fails, you wont be able to do anything with your comp until you (a) fix your hard drive or (b) get a new one and install your OS on it.
Solution #6
posted on Mar 11, 2008
Not Rated)
tat4u
Rank: Wiz
Rating: 83%, 383 votes
your system searches for os(not hd)if it does find os it reports no drive found (default)
remove hd check for dust/debris on connections and connecter.replace hd.restart with os disk in drive,system say press any key to boot from cd,press any key.
choose install windows,next screen select delete partition , create new partition , format install
Was this helpful?
Yes
No
Solution #7
posted on Jan 18, 2008
Not Rated)
bizzyb0t
Rank: Master
Rating: 84%, 49 votes
I'm sorry to hear your HDD is dead. However, all is not lost. You can still use your computer and even burn CD's and browse the internet without a functioning HDD! There is a thing called a "BootCD" or "Live CD".
My favorite non-technical one is called "Ubuntu LiveCD" Here is a link: https://help.ubuntu.com/community/LiveCD
Good luck and have fun!
Was this helpful?
Yes
No
Solution #8
posted on Jan 03, 2008
Not Rated)
Delphiuser
Rank: Master
Rating: 94%, 18 votes
Boot to knoppix, or a bootable windows CD, and you can burn files to a CD using Deep burner (Google for it) froma pin drive.
I have used this to get files off of drives that are going, but not yet gone.
Good luck
Was this helpful?
Yes
No
Solution #9
posted on Oct 19, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
you might be able to use the knoppix bootable operating system cd
Solution #10
posted on Aug 23, 2007
Not Rated)
usuallyno
Rank: Master
Rating: 73%, 19 votes
What do you men bypass your hard drive? Your hard drive stores the operating system. You can't do any of those things without the operating system. Unless you get a linux version that can boot off a cd, but thats a temperary solution.
You need to get another hard drive.
Was this helpful?
Yes
No
Solution #11
posted on Aug 02, 2007
Not Rated)
Smooth_Gecko
Rank: Wiz
Rating: 81%, 168 votes
Well, you could, sort of
If you had two CD drives, you could even boot off Knoppix and then use a thumb drive or something, sort of tricky though.
Was this helpful?
Yes
No
Solution #12
posted on Jul 11, 2007
Not Rated)
TheRealHack
Rank: Master
Rating: 82%, 28 votes
Yes there is !
Download a live linux. This assumes that you have an additional drive to burn with but you can have a decent to exceptional experience computing without a hard drive. I would try mepis linux it seems to be the most hardware and user friendly.
http://www.mepis.org
boot from the mepis disk with your internet cable plugged in and you will be online when you hit the desktop.
use demo and demo as the login and password.
That is your "quick" fix.
If you are bored sometime compile your own bartpe disc i am not going to get into it now but google "reatogo" if you want the windows version of this fix.
Hack
Was this helpful?
Yes
No
Popular Solutions for Smartdisk - Peripherals - HARD
Questions and Unsolved Problems for Smartdisk - Peripherals - HARD
Do you recommend Smartdisk - Peripherals - HARD DRIVE, CROSSFIRE 160GB EXTERNAL (XG160F)?
Answer
Answer
I have Imac the apple I need windows 95 drivers and I don user. you  game to...
Answer
in my business contact manager/Outlook- in the history sectio it show all of my emails received, not... (More)
Answer
My flash drive will not work. When trying to access it, i am being asked to format the drive. I've... (More)
Answer
Hi, I have the same problem with a Smartdisk external HD that you reported in July '08, just... (More)
Answer
dear sir i have just bought one of your videosafe capture machines from pc world i installed the... (More)
6 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Dec 06, 2007
how to read what is on the external hard disk
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Hard Drives Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
