Question about Ace Hardware Hi-Tech Circuit Detective Circuit Breaker Identifier
15 amp Gould breaker trips every 24 to 48 hours
Breaker trips periodically and will immediately reset (no buzzing or retripping). It is ever so slightly warmer than the others. No changes in load in well over a year. It started this a couple months ago and trips were about a month apart. Now it is tripping every day or two.
  • 5,568 Answers
As seemingly with everything else, these devices were once very reliable but now fail early in life.
Assuming that this is no GFI (Ground Fault Interrupter) equipped breaker, you must  have a bad one. If it is, you may have some stray currents tripping the breaker.
While finishing up on our new home and putting breakers in the main box for the first time, one brand new breaker refused to stay set even though the circuit was OK and no loads on that branch connected at all. In the two years we have been here, we had to replace a second one acting just as you describe.
Posted on Dec 15, 2008
Keeps tripping breaker after using for an hour or so. I have already replaced gfi and breaker. Advice please.
Usually when a breaker trips it is either loose wire or the what ever is running uses too much current or is failing.
Mar 20, 2015 | Electrical Supplies
Why does dewalt 55155 keeps tripping motor reset. Plenty of current on a 20 amp circuit
Place amp meter into circuit to determine amp draw at time of reset trip. If higher than 15 amps suspect leaking check valve or failing capacitor. If it trips at lower than 15 amps suspect weak reset breaker. Good luck
May 28, 2014 | Dewalt Air Tools & Compressors
Gould 200 amp main breaker gets hot
Branch loads that are fed by the Main are pulling the amperage to make the breaker warm. Breaker should trip if over 125% of rating
Jan 03, 2013 | Square D Trilliant 100 Amp Circuit Breaker...
15 AMP breaker keeps tripping
do a amp check on the compressor and fans.That will tell you exactly what is overloading.
Apr 21, 2012 | Kenmore Freezers
When turned on it just humms and blows the 15 amp breaker in the panel
you have a dead short! Check the compressor you are plugging in. Check cord for damage to wires. If cord looks good and compressor is in good shape where you are plugging in is overloading circuit and tripping breaker. Does the breaker hold for any period of time when you reset it?
Jan 19, 2012 | Air Tools & Compressors
I had a breaker WLL3F340 (4000 AMPS ) and i need to reset ( back on) please i need you help , thanks.
A 4,000 amp breaker that has tripped indicates a a load greater than 3200 amps has been connected continuously for an extended period of time. A 4,000 amp circuit breaker is rated to carry 80% of the load - or 3200 amps continuously. Up to 4000 amps may be carried for a short period of time. A 4,000 amp breaker that has tripped can be a warning sign of a major problem.
First, 4,000 amps is a substantial amount of current. The reason for the breaker tripping should be determined and cleared by qualified persons before attempting to reset. Many circuit breakers this size have internal motors to charge a spring mechanism to close the breaker. Unlike the much smaller 15 to 50 amp breakers in your electrical panel in your home, these circuit breakers are also not designed for repeated tripping and resetting.
Second, no one is going to tell you how to do this either on the web or even over the phone. It is simply too dangerous to simply go for a reset without checking and clearing the cause of the fault.
Third, you should contact an electrician that has experience with large, commercial or industrial electrical service equipment. Not every electrician knows how or has worked with equipment this large, so be sure to ask first.
I hope this helps & good luck to you.
Jul 08, 2011 | Siemens Hammering
How to reset Cutler Hammer 1 pole 15 Amp
Turn handle to off position and then back on. Same as any other breaker. The red test button can be pressed which will trip breaker. If it trips immediately,unplug all devices on circuit and try to reset. Reconnect each device and see which trips breaker. If this goes to outdoor receptacle, check behind cover for moisture.
May 25, 2010 | Cutler Hammer 1 Pole 15 Amp Ground Fault
I keep reseting my 15 amp breaker daily. I even moved the unit.
No. The unit is only supposed to pull 9.1 amps. (wattage divided by voltage equals amps) Your unit has a short, or your breaker is bad. Turn on the unit, when it trips the breaker see if the breaker is hot, If so, thats an indication the breaker is bad.
Apr 11, 2010 | Danby DMW112 Microwave Oven
I have a ruud achiever uaka outdoor central air system, the first time i ran it this summer it tripped the breaker. It stayed on for a good hour as it cooled the house to the desired temp. then it turned...
start components are likely bad causing comp to pull high amps tripping breaker careful resetting the breaker they can explode stand off to the side
you need service all so have preventive maintenance done on the unit
Jun 19, 2009 | Ruud UAKA037 Air Conditioner
Ace Hardware Hi-Tech Circuit Detective Circuit Breaker Identifier  Logo
444 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
