Question about Kenmore 24032\24036 Top Load Washer
Kenmore 700 series, almost new
I had a leak in the drain hose, so I replaced it. afterward the mortor refuses to run. The machine will fill with water but only buzzes when it tries to do any thing else.
The mortor truns east if you manually turn the tub. but it does not even offer to turn when engaged.
so I think it is getting some power (it also gets warm) but it will not turn.
    Problem Solver:
  • 5 Answers
I would start by taking the pump off the motor and starting the washer if your washer agiates something is probably in the pump if the washer still does not work with the pump unattached to the motor you could have a bad motor
Posted on Dec 20, 2008
Kenmore series 700 won't fill with water just humms lid locks but add garner light stays on any help would be appreciated thank you
remove the screen from the supply hose and clean it... it is possibly clogged from mineral deposits. Try an experiment and fill the washer with a bucket and see if the light goes out. (I am willing to bet, it does, so the issue is the hose supply in the cold water side. Replace the hose, if you need to... Ace Hardware is best.)
Sep 02, 2017 | Kenmore Washing Machines
My Kenmore top loading series 700 type 580 is given me a LF code can u help
LF is the error code for Long Fill.
Sometimes a bad or plugged water inlet valve YOU MAY need to replace the water valve.
In SOME cases the drain hose wash may be siphoning the water out of the washer as it tried to fill.
pulled the drain hose up out of the stand pipe a little to keep it from siphoning
Read more: http://appliancejunk.com/forums/index.php?topic=10002.0#ixzz3bkyrg7TS http://appliancejunk.com/forums/index.php?topic=10002.0#ixzz3bkyrg7TS
May 18, 2015 | Kenmore Washing Machines
My Kenmore 700 series washer has been leaking water. When the tub is filling with water, water seems to leak along the front bottom edge of the machine in several areas. I'm left with a huge puddle of...
First ck to see if your water pump is leaking. It normally leaks when the machine is running not just filling. Also look at all the attaching rubber hoses under the machine and see if water is leaking down the back right side of the machine and then running around the frame to the front long shot but possible.
Aug 11, 2010 | Kenmore 15864/15862 Top Load Washer
I have a kenmore washer 700 series. Water is
Yes its true that this washer not worth repair.... Better you can go for a new washer..
I have a question - is there any error code on the display control?
thanks
Jul 07, 2009 | Kenmore Washing Machines
Kenmore washing machine will not fill with water.
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
Jun 01, 2009 | Kenmore Washing Machines
Kenmore 90 series washer is leaking water from the pump. How do I remove the pump to repair or replace? Thanks!
Hi, You can change the pump by disconnecting power, water fill hoses, & take drain hose out od drain. Lay the washer on its back (use some padding under machine so that you do not damage threads on inlet valve. The pump is located on motor and has two clamps holding it. Just remove those clamps and the two drain hoses from the pump. The pump should release from the motor shaft. If the motor shaft is rusty, the pump might not want to come off ease and the shaft will need to be cleaned with sand paper or emery cloth so the new pump will go on easy. Failure to get the pump on all the way will cause the new pump to leak also.
Put your hoses back on the pump and everything should be ok.
I hope this helps you some.
Vic
May 10, 2009 | Washing Machines
Leakage of water from underneath when filling machine up
it's prabably your pump it has two metal strips that snap on from the motor to the pump un-snap them and undo your hoses and get yourself a new pump
Apr 03, 2009 | Washing Machines
Kenmore series 70 will not fill
Ive only run across this a couple of times in my years of appliance repair. This sounds like you do not have an air gap on the drain hose. Where the hose hangs into the wall drain pipe make sure you do not have that sealed air tight with duct tape around it or something. It needs to have a gap all the way around the hose and just hang freely. If it is sealed off then it creates a siphon effect and sucks the water right out of the washer tub into the drain.. Hope this helps.. Thanks
Feb 18, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 series leaking
well you can try filling the outer tub separately.with what you mentioned, the problem is certainly not with the drain hose or the pump. fill the tub separately with some water and if the leak is seen then the problem is certainly with the outer tub corrosion or crack on it.
Dec 13, 2008 | Kenmore 24832 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
110 people viewed this question
Sal De
fordexpert
Robert Rankin
