Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
HCN4226WXIXAA like a month ago my just stop working will not power on the fuse is good any solution
  • heav4 Dec 06, 2008
    when i hit the power button the light around the power button on tv turns red and the tv does not power on. any clues on what part to buy to fix myself?
    President:
  • 3,130 Answers
Good be just about anything. This set is common for the regulator IC, the STR-X6456 regulator IC to go bad for starters, the flyback transformer goes bad and takes out the horizontal output transistor sometimes and then blows the main 10 amp fuse. I have also seen the convergence IC's go bad then the set dies because the main fuse blows out, the power supply will go bad because of a surge. If you have no TV repair knowledge, play it safe and have the set looked at by a pro. Good Luck
Posted on Mar 30, 2007
2005 toyota corolla horn doesn't work
You can replace the horn. Check to see if the wires connected to the horn have power. Check with a test light. If power is present then the horns are bad.
Apr 19, 2012 | 2005 Toyota Corolla
The horn, cigarette lighter, power locks, dome light and radio light stop working at the same time. the fuses seem ok, what causes this problem?
use a fuse tester(can get at local automotive store). the fuse may seem okay but look closely at the fuse maybe cracked off inside of the fuse. i had the same problem a couple of months ago
May 20, 2011 | 1989 Chevrolet Celebrity
Dryer is not heating
i replace the thermal fuse kit 2 month ago and my dryer was working good but 2 days ago stop heating again so i did replaced the thermal fuse again and i did some lint cleaning but this time it only last about 20 min. and stop heating again.what could be the problem?
Mar 01, 2010 | Whirlpool Inglis IP8200 Dryer
The Rear Wipers on my 2001 1500 Chevy Suburban Stopped working
Unplug the connector at the rear wiper motor, turn the switch on and probe the wires with a test lamp, if you have power back there you more than likely have a bad motor. If there is no power start checking fuses they are all labeled easily on the back side of the fuseblock covers both on the dash and underhood. Good Luck!!!
Mar 15, 2009 | 2001 Chevrolet Suburban
Power windows not working
Remove the door panel on a non working window and at the window motor hook a multimeter to each of the 2 wires then try it at the master switch. IT should be 12V. You can also try hooking it to a battery one way is up the other is down. Usually if it is an intermittent power window it is caused by broken wires inside the drivers door flexible rubber between door and interior.
Feb 10, 2009 | 2003 Mercury Mountaineer
My tefal avanti stopped working
something had been gone short due to the power socket.let the socket be ok but sometimes due to heavy voltage this could possibly happen.just check if somme parts is burnt ,turned black or smelling foul oudor,or when you on the machine now it passes burning fumes from some where.
Aug 11, 2008 | Tefal OT806000 Avante Elite 1600 Watts...
GE 1339BW002 Microwave stopped working
Yes, there should be a ceramic (tubular) fuse under the cover on the top side where the power comes into the microwave.
Dec 11, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1339BW002 Stopped working
Dec 11, 2007 | Microwave Ovens
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
198 people viewed this question
Jerry Greenberg
Jerry Greenberg
