Question about Samsung PCN5425R 54" Rear Projection Television
Picture is bending at the top and bottom and looks 3d
This is a samsung 54 inch hd projection tv, was working perfectly, then dad turned it on and I walk in the room and it looked 3d, like as if you where at a 3d movie and the top and bottom of the screen is bowing toward the middle.I'm a auto tech and repair every elec prob on cars but no tv experince. I did remove back panel and all three projectors are working and I did cover the red projector so dad could a least watch tv.
the bending of the picture is still there, please help
  • danny_sadler Dec 25, 2008
    My Samsung pcn5425r rear projection tv recently stopped working properly. The red tube is projecting a curved image that is shorter on the left than on the right. The auto-convergence mode does not help. I replaced the convergence module, but still have the problem. I can cover the red lens and adjust the set so that I can at least watch it in what looks like black and white images. The red tube appears to be the only one affected.
  • Samsung Master
  • 3,459 Answers
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
picture is bending at the top and bottom and looks - bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 03, 2010
My Sharp 61 inch projection HD tv has a blue band of shadow that dips below the image. Looks like 3D without the glasses.
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B misalignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Sharp 61RWP4H 61" Rear Projection...
The picture bends at the top and the bottom of the screen and is blurry where it bends at
The tv have a problems known as a convergence problems,it dead.Tv have colors R,G,B lines mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Picture has double exposure as well as curved, color also is distorted with pink at the top of screen. It is on a good surge protector. It was fine last night and just started it this evening when we...
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Mar 06, 2010 | Samsung PCN5425R 54" Rear Projection...
Convergence board is bad
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Dec 28, 2009 | Akai PTH5498 54" Rear Projection...
The screen looks out of focus and the top and botton bend inward.
Remove front bottom panel behind it is a small black control box top controls are focus controls for R/G/B and Bottom 3 controls are your screen drives adjust one at a time turn off G/B adjust red first,then Do Green and Blue fter adjusting focu to each tube leave them set then adjust screen drive turn color off adjust RGB for a Black and white picture get as close as you can then turn color back If after doing this you still have blurry looking picture look down into Tubes you should be able to see picture clearly in each one if you cannot see picture then projection Fluid need to be changed out. Call Mats 1-800-628-1118.
Sep 26, 2009 | Sony KP-53S65 53" Rear Projection...
RCA P52755BA 52 inch tv looks 3D
You have a problem with convergence and all you may need to do is replace a fuse. Look up convergence for your tv model and hopefully you will get an answer as to where the fuse is located and how to replace it. Very common for RCA tv's
Aug 30, 2009 | RCA P52926 52" Rear Projection Television
Picture on AKAI 54 inch HD ready tv is not square.
akai is not a good brand of tv to start with they seem to have alot of problems and finding parts is impossible to do
Oct 16, 2008 | Akai PT5598HD 55" Rear Projection...
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Top half of screen looks like 3D
the prob. described points to convergence amp failure. have qualified tv tech to repair..john
Nov 10, 2006 | Akai PT4298HD Rear Projection Television
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
321 people viewed this question
Henry  Thomas
Henry Thomas
