Question about Canon PIXMA MP470 All-in-One Printer
The printer says it has error code of 5100 what is that?
Also the color cartdrage sticks out bout half inch further then the black one is that supposed to be that way?
  • pj2816 Dec 16, 2008
    does any one know what this is even????
  • 4,041 Answers
Hi You can Try 2 things.
Yes think it need a good clean
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
Cannon Pixma ip90 printer mechanical failure code 5100. Printer works for about 2 inches then stops with failure code 5100
The error 5100 actually means nothing. You need to look at the printers green and orange lights. they will be flashing in a certain sequence. Count the way the lamps flash ie.Green are mechanical faults and orange are operator correctable faults. When you have the info repost and i will help you further.
Jul 27, 2011 | Canon Office Equipment & Supplies
Error code 5100 i have turned off machine, unplugged at electrical source. After 30 min replugged in to electrical source, turned on printer. Pressed print button. Machine processes for a few minutes...
Hello and Welcome
Error 5100 means that the cartridge can not be detected by the printer.
Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps. I hope it works
  1. Turn off printer
  2. Remove both the cartridges from the printer
  3. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  4. Return the cartridges
  5. Turn on the printer.
Error will be removed
Further assistance i am here to help
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Mar 11, 2011 | Canon PIXMA MX700 All-In-One InkJet...
MX850 - error code 5100 = can you help please.
Hi You can Try
Error Code 5100
Solution 1:
Solution 2:
Dec 06, 2009 | Canon PIXMA MX850 Multifunction Printer
Canon printer error code 5100 while attempting to put in the color and photo cartridges. pix ip6220d is the printer model number
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width) The unit is not homing, check for obstructions.
Nov 21, 2009 | Canon Office Equipment & Supplies
Selphy DS 810. Shows error code 5100. I want to
Hi You can Try
Error Code 5100
Solution 1:
Solution 2:
Only gave it a go
Nov 19, 2009 | Canon SELPHY DS810 InkJet Photo Printer
I keep getting an error code 5100.
By your description, you probably have read that the 5100 error means that the movement of the print head holder is blocked. I get this error occasionally and handle it by turning the printer off and then on. The last time it happened, I heard something like a belt snap. Try opening the printer top and seeing if you can gently move the holder. Are you hearing sounds from the printer that are new?
Jan 28, 2009 | Canon Pixma MP500 All-In-One InkJet...
Error message 5100 on Canon i560 printer
Hi You can Try
Same old errors
Error Code 5100
Solution 1:
Solution 2:
Oct 27, 2008 | Canon BubbleJet i560 InkJet Printer
Error code 5100
Here's what worked for me in solving this error code 5100 problem. Not only was I unable to print anything because I kept getting that code, but there was a thunking sound when the carriage stopped moving, and every time I turned the machine on it was feeding through one sheet of blank paper. I was about to go out and buy a new printer of a different brand because the Canon was unusable.
Then, fooling around with the machine's menu and settings buttons, I came across an option, I think it was in the Maintenance menu, to Restore Factory Settings. I chose that option and it asked me again if I wanted to restore the original factory settings, Yes or No. I said Yes, and immediately the printer started behaving itself. No more 5100, no more funny noises, no more blanks sheets of paper. It is back to its old self again.
That still doesn't solve the problem of spending a fortune to buy ink cartridges, but I just hooked up my old Panasonic 24-pin dot matrix printer to the printer port of my CPU (a ribbon lasts me a year and costs less than $15), and the Canon to another port, so now I can print the day-to-day stuff on the cheap dot matrix and use the Canon for the important stuff.
I don't know if restoring the factory settings will work for you, but it was the solution in my case. Hope it helps you out.
May 04, 2008 | Office Equipment & Supplies
PHASER 8500DN ERROR CODE: 09,038,46.8515
That is a black ink stick count failure.
It is not seeing the black ink stick.
See if a stick is broken or not in place. One may be twisted or just jammed.
Outside chance you would need an ink loader because the sensor is not detecting the ink
Check the black sticks see if you can clear it by moving them around or sliding them up and out and reloading.
Mar 08, 2008 | Xerox Phaser 8500/DN Printer
Canon PIXMA MP470 All-in-One Printer Logo
99 people viewed this question
old marine
old marine
