Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Liftmaster 1265 - Motor hums but nothing else happens.
The track dosen't move.
  • downundertek Jan 06, 2009
    I have a LiftMaster Model #1060-1 (1/2 HP) chain drive garage door opener that has the same problem. I opened the door part way up and I stopped it with the remote so I could close it before it reached full open. When I pushed the button again to close it it started going up again so I stopped it with the remote it stopped and the motor just started humming with no movement of the door. I had to unplug the power to it and release the trolley so I could close it manually. I am a master auto mechanic, so I checked it out the nylon gears were not stripped out. All teeth are good. I remove the motor and found it was tight to turn. I hooked it up to a power cord  and it still only hums when I apply power to the motor. I sprayed it with penetrating oil at the two bearings on the shaft of the motor and it turns more freely now but still only hums. I talked to my door opener man today to see if he had a new motor for it. He told me he has never replaced a defective motor on a door opener in over 30 years. I am going to take the motor for him to check, this Wednesday, 1-7-09. It might be the motor starter capacitor that is blown out. It might need to have the capacitor to give the motor a "Kick Start" to get it turning when it initially starts the motor turning. If you think I am going in the right direction please let me know. Thanks, John downundertech@sbcglobal.net
  • downundertek May 11, 2010
    I tried the capacitor. It was not the problem. The circuit board was burned out. My GDO tech showed me the burnt spot in it (brown spot in the green circuit board). It was very evident that was the problem. I bought a new GDO that has the safety sensors at the bottom of the door that I like much better. Thanks for your help.
I have had same problem. Replacing the motor start capacitor fixed it. Capacitors can go bad in an instant when they get old, particularly if they are perturbed while servicing other parts.
Posted on Jan 19, 2009
    Sniper:
  • 98 Answers
The Capacitor is a 53-64 MFD 220 VAC. A bad capacitor will cause what you are experiencing.
Posted on Jan 06, 2009
Lift-master 1265 Garage Door opener clicks but nothing happens
CHECK ON THE OPENER FOR A RESET BUTTON, IT MAY HAVE JUST POPPED.
Apr 10, 2013 | Sears Craftsman LiftMaster Chamberlain...
Door worked, 2 hours later didn't- just hummed good weather
If it just hums when a button is pressed it could be the start capacitor. This sits next to the motor and is about 5 inches long and about as big around as a silver dollar.
May 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener (liftmaster 1265) buzzes when attempting to open or close the door but the chain doesn't move
Remove the cover from the motor unit and check the drive gear. It is white nylon and is just in front of the motor. Most likely stripped.
Apr 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 1265 garage door opener, tried to
On the side of the motor unit you will find the 'down limit control'. Using a small screwdriver turn this control in the same direction as the arrow printed on the cover. Some tweaking may be necessary to get it just right.
Oct 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door doesn't open or close
You should check the gears inside the box, After years , the gears get dry and die, you can by online or from Sears the kit and replace the old gears. I just changed mine...not too difficult :) .
Mar 11, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Open case, & see if white shavings from gear stripped out are laying on bottom of case.
Dec 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
Door opener will not engage as mechanism moves along the chain track
Make sure the rope hanging down has not been pulled. If it has the door has been disengaged from the opener. You can correct this by flipping the metal part up (that the rope is connectd to) toward the drive track. Then open or close the door using the remote. The track should grab the door again.
Jul 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster security + model 1265 NOT CLOSING PROPERLY
wbuero, I had same problem two weeks. The door springs weaken over time and may need to be tightened - check opening force manually. Manufacturer also recommended reviewing install guide to be sure opener arm is attached at proper angle. The opener on my professionally installed door was not connected properly. It that doesn't work, the opener drive train or door track/wheels may need maintenence.
Jul 05, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
2,303 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
