Question about LG DLG5988 Stainless Steel Gas Dryer
LP gas conversion on an LG dryer
How do I get to the gas works where I have to convert out new dryer to LP...I already have the new nozzle. Thx.. Mr D
  • 1 more comment
  • Anonymous Mar 16, 2009
    Same problem. all resellers of LG and even LG are worthless. I dare say 50 of gas dryers are on propane, LP. No instructions whatsoever how to get to the regulator and back is welded on. Unit is worthless unless this 20 cent part is installed. Nine hours on voice mail machines only to talk to idiots!
    They were supposed to deliver are LP dryer. sent a natural gas with no conversion kit. Two weeks for that and must dismantle the entire unit to insert it. How do you dismantle the front?
    John
    stokes@z600.com
  • Anonymous Mar 17, 2014
    lg lp gas dryer flame burner lights then goes right out
  • Anonymous Mar 25, 2014
    Can I convert the electric dryer to a gas one?
    President:
  • 878 Answers
Mr. D, make sure you have a little time, you have to remove a few things. 1. Remove the 3 screws in back which hold the top on. Slide the top back and lift off. 2. Remove the two screws on each end of the control panel frame. (inside). Disconnect the control panel harness, pull up and foward, place aside. Remove the 4 screws on the top of the front cover, disconnect the harness for the door switch and it should pull foward. Now I believe you can get at the gas valve on the lower right. Make sure to reverse the limiter as well as putting on the new orfice. If you need any further help, e mail me at catriver1@gmail.com Will be home this evening. Catriver.
Posted on Mar 17, 2007
    New Friend:
I just did this, but there's no 'limiter' to reverse. I've seen this on a stove, but not on the dryer.
It's not igniting, no heat at all
thoughts appreciated
Posted on Jul 04, 2015
Try calling your gas supplier if you need to ask you should not even try.
Posted on Mar 19, 2008
I start the dryer and it makes a horrible noise like the berrings (SP) are out...also the sensor does not work...the clothes are wet when the machine goes off...
Posted on May 30, 2008
Admiral dryer
Who did the conversion to lp? Do you have the old part from the conversion still? If not you can order a kit to put it back to stock which is ng. Not hard for a guy that's handy but time consuming. 2-2.5hrs.
Feb 08, 2014 | LG DLG7188 Gas Dryer
How do I convert a gas dryer model # (DLG2302R) to LP ? Does the required Installation kit come with the unit upon delivery
Here is a link to the conversion kit you will need. It comes with the instructions you will need to do the conversion to LP gas.
Dec 01, 2010 | LG Dryers
I have a LG model# DLGX2502V gas dryer and I want to convert this dryer to LP. Need to know where to locate gas valve and how to get to it. Also steps to take to do this. I have already purchased the...
I'm surprised they didn't give you instructions with the kit. Gas vale usually at floor level behind dryer. Sometimes you have to remove the lower drawer in stove it there is one and reach through there to turn off valve. After you pull the stove out I would remove the flex line and put a good plug on the valve..
Sep 22, 2010 | Dryers
Maytag Dryer conversion From LP Gas to Natural Gas
Get a nat gas conversion kit using your model number. Now this link shows how to convert nat to LP you would do the opposite.
Basic Dryer conversion 101
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 21, 2010 | Maytag MDG2706A Gas Dryer
Convert Natural Gas Dryer to LP Gas
A dryer is a dryer. Most cases they all work the same. You will need to get an LP conversion kit for that model to complete the task.
Jan 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Need instructions for Natural Gas to LP Gas for GE Dryer
You can get the conversion kit. It will tell you how to convert the dryer. I recommend that you get a technician to do it though.
This gas dryer is equipped with a Valve & Burner Assembly
for use only with natural gas. Using conversion kit
WE25X0217, your local service organization can convert
this dryer for use with propane (LP) gas. ALL CONVERSIONS
MUST BE MADE BY PROPERLY TRAINED
AND QUALIFIED PERSONNEL AND IN ACCORDANCE
WITH LOCAL CODES AND ORDINANCE
REQUIREMENTS.
Good Luck and Please Rate FixYa!
Jan 19, 2009 | Dryers
Lp conversion
You guys like things that go boom. My advice is to get a certified gas tech. To change the orfice to LP you have to take apart the unit from the front.
Sgt 48
Jan 30, 2008 | LG DLG5988 Stainless Steel Gas Dryer
LG 6988 gas dryer conversion
you will need to get to the gas valve right front after the panel is off the orfice is in the end if the burner
Jan 25, 2008 | LG DLE0332 Gas Dryer
Lg gas dryer lp conversion
On the regulator on the burner you remove cap and turn upside-down and reinstall.
Nov 18, 2007 | LG DLG5988 Stainless Steel Gas Dryer
LG DLG5988 Stainless Steel Gas Dryer Logo
2,082 people viewed this question
Top LG Dryers Experts
jimorris77
Craig Butler
Craig Butler
Marvin
Marvin
Are you a LG Dryer Expert? Answer questions, earn points and help others
