Question about Pentair MINIMAX NT TSI IGNITER
Pentair Mini-Max NT Pool Heater does not get very hot
The heater has worked great until tonight. I normally set the temperature to 98 degrees and it's quite hot. Tonight I had to set it to 104 degrees and it was warm but not hot. The heater is about 4 years old and has never had a problem before, nor has it had any maintenance. Is there a thermocouple or something easy to fix? Also, is there a repair guide I could purchase or download?
Thanks,
Ed
  • 22 Answers
The thermistor is a common failure on this heater. With a setting of 104 and the heater shutting off early, the sensor is bad. If you have a digital display, check the water temp with a thermometer and compare that ot the display. Odds are that they are different. The thermistor plugs into the back of the thermostat board and is a thin whire wire set or thibker yellow wire. The white wire sensors are old and most have fialed by now.
Posted on Dec 21, 2008
Heater only warms water to 98 degrees
temp sensor or if control box make sure heater set to 104
Nov 27, 2013 | Sta Rite Sr333na Max E Therm Pool & Spa...
My minimax nt only heats till 90 degrees. I set it up to 104 which is the highest and it only stays at 90 degrees. Everythig seems to be working well, no errors either. Please advice.
Either the thermostat board is defective, the temperature sensor is defective or not enough heat is being produced by the heater. . I recommend you call the Pentair technicalsupport at 800-693-0971 and they should be able to help you figure this issueout. I hope this helps.
Please vote on this answer. Thank you.
Aug 25, 2011 | Pentair Minimax NT Heater
I have an mini max nt w 6800 controls ignitor
The voltage to this ignitor should only be 120 volts. If you are getting 240 volts to the ignitor, there is something really wrong with the wiring to the heater or in the heater.
Jul 27, 2011 | Pentair Minimax NT Heater
Have a brand new Master Temp 400K Propane with an Intellitouch and the heater shuts off at 84 degrees. Do I need to set a max temperature from the heater control panel?
If this heater has pool mode and spa mode as an option, and you need the water higher than 84 degrees, you must set it to spa mode even if it is a pool. As a regulation, these heaters come pre-set to max out at 84 degrees as a safety feature. However, in spa mode it can reach 104degrees.
Jan 11, 2011 | Pentair Mastertemp Heater
My pentair mini max display is indicating a "LO" .
The pentair mini-max only displays LO when the water temperature is at or below 58 degrees F.
The heater is set to not fire at this temperature due to the condensation that can occur.
If the water is above this temperature and you are still getting this code, the temp sensor is installed incorrectly or is just bad.
If you need futher advise, e-mail me here.
adamh@newconceptchem.com
Nov 15, 2010 | Pentair Pool & Spa
Pool Heater Mis-reading Temp.
Your temp sensors are on the heater, a small tube that slides into the water manifold, usually on the left side. On the remote it will be in one of the pipes coming from the pump or the filter. If it is after the heater you should move it to between the filter and heater. It will be a tube that is in the pipe with a stanless steel clamp holding it in place.
To find out wich one it is you will need to remove the remote from the system by takeing the wires that go to it from the wireing inside the heater and wire nuting the wires in the heater together. If the heater runs normal then it is the sensor for the remote if not it is the sensor for the heater. Let me know how you do and if need be we can get a little more specfic for your system. good luck.
Mar 29, 2010 | Pentair Minimax NT Heater
Digital display shows LO what should i do
LO is a limit string open. This is what I refer to as a saftey circut. It will peobally be a dirty filter or a plugged up basket. The heater need enough water flow to run or it will overheat and cause damage to the heater. Without enough flow the saftey circut shuts the heater down before this can occur. If it is more than this it is probally time to get a repairman involved. Good luck and remember this is a box full of fire that runs on high voltage.
Mar 05, 2010 | Pentair Minimax NT Heater
My pool heater will not start. The power light is off and the pressure sw is lit.
You must turn on the pump and let water circulate through the pool and the heater before you turn on the heater otherwise you will ruin the heater
Apr 16, 2009 | Pentair Minimax NT Heater
Pentair Heater shuts off prematurely when warming spa
check gas pressure could be running out or overheating
Mar 06, 2009 | Pentair MINIMAX NT TSI IGNITER
Pentair MINIMAX NT TSI IGNITER Logo
1,154 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
