Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Frigidaire side by side refrigerator beeps 3 times when plugged i
It beeps at me 3 times when plugged in, only the freezer light comes on. No displays at all & no refrigerator lights, Found some corrosion on the connector for the control board, while trying to unplug the connector, the refrigerator came on momentarily and went back off. I cleaned the corrosion on the circuit board solder joints for the connector and the connector but now it doesn't even come on at all but it still beeps 3 times when plugged in.
5 Suggested Answers
  • 213 Answers
SOURCE: ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
Posted on Nov 29, 2007
Master_Tech
  • 770 Answers
SOURCE: freezer won't freeze
is the fan running ion the freezer is the compersser runing and the cond fan >??
Posted on May 10, 2008
  • 125 Answers
SOURCE: Frigidaire Upright freezer with Beeping Display
the thermistor is most likely bad. you would have to take an ohm reading of the thermistor and check the tech sheet to see if it is in range. The thermistor is $50 to $75 part.
Posted on Jun 25, 2008
  • 190 Answers
SOURCE: Frigidaire Side-by-side not cooling or freezing
Dear customer,
We suggest u to do the follwoing checks,
  1. Hissing and popping is normal on frost free refrigerators, it is the defrost heater
  2. Check that the refrigerator is level
  3. Check the drain pan
  4. Check the condensor fan
  5. Check the evaporator fan
  6. Inspect the compressor mounts
As for th freezer's problem checkout the,
  1. Check the temperature setting
  2. Assure that there is enough room for air flow in the freezer or freezer
  3. Check for air flow restrictions in vents
  4. Test the temperature control
  5. Clean the condensor coils
  6. Check the door seals
  7. Test the door switch
  8. Test defrost heater
  9. Test defrost timer
  10. Test evaporator fan
  11. Check for a clogged drain tube
  12. Check for refrigerant leak.
Thank you. Plz rate the solution..
Posted on Apr 08, 2009
  • 111 Answers
SOURCE: Frigidaire refrigerator side-by-side freezer making loud noise
fan motor probably rubbing in something
Posted on Jun 19, 2009
Samsung rb215abbp won't stop beeping. I recently switched the door from the right side to the left. Now my fridge says 66 degrees but is cold. Light is on only when I unplug and plug it back in.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Sep 30, 2016 | Samsung Refrigerators
Panel beeping and nonresponsive
Jan 30, 2016 | GE Profile Stainless Bottom-Freezer...
Model E402b. Why is the alarm going off?
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jun 02, 2015 | Fisher and Paykel Refrigerators
There is a constant buzzing noise coming from the lower freezer ice maker. It is producing very few ice cubes. The control bar is down and in proper position to make ice.
May 21, 2015 | Whirlpool Gold Series GB2SHTXTS (219 cu...
I have a frigidaire side by side model GLHS37EHSB7 refrigerator makes a continuing beeping sound what could be wrong?
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
May 11, 2015 | Frigidaire Refrigerators
Fridge & freezer lights and the water display light beep and flash 10-12 times every few hours. Simultaneously a fan motor starts and stops. Any one know what needs to be done to remedy this?
Apr 25, 2015 | Refrigerators
Open door 18 beeps lights flash red green fridge not cooling
Mar 14, 2015 | Refrigerators
Beeps about 6 times when fridge door is opened.
Mar 11, 2015 | Refrigerators
Flap won't stop humming buzzing
Oct 07, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
Why does my Hotpoint ff187e frost free fridge freezer lights flash and the alarm sound even after reseting them as per manual. rest them ok for a while but then restart what's the problem?
Jul 27, 2014 | Hotpoint Refrigerators
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
78 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
