Question about Connex 3300 240-Channels Base CB Radio
Changing swrs open and close door changes tried running a ground to different places didn't change
  • s60six May 11, 2010
    what antennas and coax are you using....what type of vehicle
  • 52 Answers
If the SWR changes by opening and closing the door, I would suggest to check the grounding, although you have already done this.
However, a slight difference noticeable can be normal.
Is the antenna cable in tact ? Is there corrossion on the base mount ? Is the antenna placed on the vehicle over a magnetic base or fixed to the chassis ? Check the ground connection on the PL259 both sides, the antenna and the rig.
The position of the antenna and it's grounding is also important.
Posted on Jan 01, 2009
How to diagnose which door is causing the door ajar warning on dic for 08 pontiac g6 4cyl 4dr
It should tell you which one .
Driver Door Ajar Malfunction
Passenger Door Ajar Malfunction
If not a scan tool would be the best way.
Ignition ON, observe the scan tool Driver Door Ajar Sw parameter while opening and closing the driver door. The parameter should change between Door Closed and Door Ajar
? If the parameter does not change, refer to Driver Door Ajar Malfunction.
With the passenger doors closed, observe the scan tool Door Ajar Switch parameter while opening and closing each door. The parameter should change between Door Closed and Door Ajar.
? If the parameter does not change, refer to Passenger Door Ajar Malfunction
Ignition OFF, disconnect the harness connector at the driver door latch.
Test for less than 5 ohms between the ground circuit terminal 8 and ground.
? If greater than the specified range, test the ground circuit for an open/high resistance.
Ignition ON, verify the scan tool Driver Door Ajar Sw parameter is Door Closed.
? If not the specified value, test the signal circuit terminal 6 for a short to ground. If the circuit tests normal, replace the BCM.
Install a 3A fused jumper wire between the signal circuit terminal 6 and the ground circuit terminal 8. Verify the scan tool Driver Door Ajar Sw parameter is Door Ajar.
? If not the specified value, test the signal circuit for a short to voltage or an open/high resistance. If the circuit tests normal, replace the BCM.
If all circuits test normal, test or replace the driver door latch
Dec 26, 2016 | Pontiac Cars & Trucks
Door opens randomly on its own!
can you change the toggle switches in the remote and door controller to a different code than it is set on now. Like the two devices must match but hopefully the neighbor code for their door will then be different. Also can you change the frequency ?
Nov 20, 2015 | Genie Garage Door. SilentMax 1000 3/4 HP...
Chamberlain 9902 won't close at times
Does the motor run? Does it make a noise. What actually happens?
Apr 09, 2012 | Sears Craftsman LiftMaster Chamberlain...
Have a 4-5 yr old Canon S2 IS PowerShot A75 Digital Camera. The batteries are new &/or charged but the camera won't always work reliably - says to change batres. but if I just open the bat. door...
Sometimes, the lower contacts get bent downward after years of use, causing the batteries to ride low in the compartment, and thus making poor contact when the battery door is closed. Try lifting/bending these interior battery contacts upward, so that the batteries ride higher when inserted.
Oct 29, 2011 | Canon PowerShot S2 IS Digital Camera
Refrigerator door does not stay closed. When the freezer door is closed the refrigerator pops open.
The fridge and freezer share their airspace, so when you close one there is a slight increase in pressure in the other unit. (Much like opening a window can cause a door open/close in your house due to pressure change/air movement) The magnet in your seal of the door is weak and unable to resist the pressure change. The seal should be changed.
Could also be that the door is not shutting properly in the first place due to sagging or skewed hinges that need adjustment/replacement and while shutting just may not be getting a complete seal that it should be.
Sep 02, 2010 | Refrigerators
My Minolta CF1501 is showing error COF 34
Before doing above open and close the front door. The code is for the Auto Toner Density Control the black image unit if it comes back after opening and closing the front door the image unit needs replacement. You can't change the developer it is all one unit. the fuser has a different code 500 series. Dont mess with gain let machine run stablize.
Dec 24, 2009 | Minolta CF1501 Copier
Garage door will only close with keypad code it will not open
UNPLUG THE UNIT AND WAIT 5 MIN.
WHEN YOU PLUG IT BACK IN CLAER ALL CODES BY HOLDING DOWN THE PROGRAM BUTTON FOR 20 SECONDS.
NOW TRY TO PROGRAM EACH REMOTE AND KEYPAD - IF THERE IS STILL A PROBLEM CHANGE THE BATTERIES AND REPEAT THIS PROCEDURE.
I HOPE THIS HELPS
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener 1/2 HP
You may have a model that requires you to reprogramme your PIN after changing batteries...
Jul 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Connex 3300 240-Channels Base CB Radio Logo
48 people viewed this question
Top Connex Radio Communications Experts
AnyMHz.com
AnyMHz.com
Iron
Iron
Steve
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
