Question about D-Link DIR-625 (790069292637) Wireless Router
How do I open port 30000 in a DIR-625 router?
I need help in opening port 300000
    Problem Solver:
  • 15 Answers
Hello marquitos4,
Go to http://portforward.com/english/routers/port_forwarding/Dlink/DIR-625/DIR-625index.htm
and you will find all the info you need regarding port forwarding through your D-Link router.
The page is specific to the DIR-625 but just about any make/model is supported at http://portforward.com/
Enjoy,
FixThemAll......
Posted on Dec 15, 2008
I need to set my password for my di-625 router.
If the default password has been changed then -
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your computer's LAN port, open a browserand enter the D-Link's configuration URL. OR open the browser on your laptopand enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)
You can now configure the wireless settings.
Mar 18, 2011 | D-Link DIR-625 (790069292637) Wireless...
Just purchased a Vizio 37" HDTV with Netflix app
The Vizio does not have Internet capabilities. You need to hook up a computer via the VGA or HDMI port. Then youor computer controls what you do with the intenet.
Dec 03, 2010 | D-Link DIR-625 (790069292637) Wireless...
How to reset the security for a Dlink DIR-625 wireless router
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Apr 01, 2010 | D-Link DIR-625 (790069292637) Wireless...
I need help setting up my D-Link DIR-625 Wireless Router
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Feb 18, 2010 | D-Link DIR-625 (790069292637) Wireless...
Port forwarding with DIR-625 (wireless environment)
Does your modem has a NAT too? if not then upgrade the firmware of the router that usually fix the problem, if not then ask your ISP and see if they are blocking the ports. have you tried connection without the router to see if that will work?
Sep 09, 2009 | D-Link DIR-625 (790069292637) Wireless...
How do I initiate port forwarding on my dir-625
check the ip address of your router, you should do fowarding on the settings of your router.
You should open a port number not the same with an application on your computer. If we have counter strike which has a 1809 port number, then you shouldnt use that port number because its being used by counter strike.
Aug 16, 2009 | D-Link DIR-625 (790069292637) Wireless...
Dlink DIR-625 permanently stopped working. Connected directly to internet with dsl cable through sympatico and internet works fine but doesn't work at all when connected through Dlink DIR-625
you may need to reset the router and reconfigure the settings. please follow the steps below if you have a username and pw from sympatico.
1. Press the reset button for 30 seconds
2. Plug the modem to the internet port of the router. Check the internight light if lit; otherwise, use another known working cable.
3. Plug the PCs to the numbered port at the back of the router. Check the lights on the port number if lit; otherwise, use another known working cable.
4. Open a web browser and enter http://192.168.0.1 and press Enter. When the login window appears, set the user name to Admin and leave the password box empty. Click Log In to continue.
5. Click on manual configuration when prompted.
6. Select PPPoE on My Internet Connection and enter the username and password provided by Sympatico. Select Dynamic IP and Always ON options. Click Save Settings.
7. Click on Status tab and verify WAN status if connected. You should see WAN IP address when connected.
8. Try to open a browser and verify your connection.
Hope this helps!
Jun 25, 2009 | D-Link DIR-625 (790069292637) Wireless...
Unable to ftp from outside of the network. Went through all of the port forwarding setup. Still can't connect.
You need to setup a Port Forwarding / Virtual Server (FTP) in the router to forward port 21 (FTP default) to your FTP server's FTP port. You may need to setup a reserved IP address for the FTP server first in the router before the option comes up.
May 27, 2009 | D-Link DIR-625 (790069292637) Wireless...
D-Link DIR-625
What you need to do is long into your router's configuration. For the D-links, all you have to do is open internet explorer. Type in 192.168.0.1 on the address bar and press enter. Once you get into the log in page, type in your username and password (not the same one as your wireless password). If you don't know. Try admin for username and leave password blank. It should work if you have not change the default password. Once inside the configuration page. Go to Advance, click on QoS engine on the left. Input the IP address of the VoIP box in the "source ip" , type in a name for your rule and select 1 for priority and input your ports for your VoIP box. The best thing you want to do is put your VoIP box before your router. That way you get better quality.
Oct 02, 2008 | D-Link DIR-625 (790069292637) Wireless...
D-Link DIR-625 (790069292637) Wireless Router Logo
822 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
