Philips magnavox remote model: rem212
I need the manual for this remote
ziraffa
  • 827 Answers
SOURCE: need manual for philips magnavox
here's a link to a download source for the manual. you have to enter your email and you'll get a link to download it.
http://www.2instructions.com/search.php?cmarque=PHILIPS&modele=REM212
laters
chris
Posted on Dec 15, 2008
I need philips v355,vcd remote control model number
Download the user manual to your DVD player. It will have the model number of the remote control, in its specification page. To download it, click here.
Jul 28, 2012 | Philips Magnavox Learning Universal Remote
I'm having problems programing my Philips RC19041006/01 remote that came with a Philips 15pf9936/37 15" LCD TV to work on a Magnavox MDV21001F7 DVD Player
Unfortunately, you will not be able to program your TV remote for the DVD Player. The MDV2100F7 was produced in 2010. Your Philips TV was has a manual with a copywrite date of 2003. Other documentation on the Philips site is from 2004 and 2006. (I am assuming that the MDV2100F7 is your model since no MDV21001F7 is listed at Magnavox or Funai (which made the unit).)
The codes in a universal remote control are only for devices released 6 months or more before the remote was programmed. A DVD player released 4 years later is likely to have a different set of control frequencies.
You need a newer remote or control everything with separate remotes. I wish that I had better news for you.
(The manual for the Philips TV is available from the Philips product site. For the Magnavox DVD player documentation, see the Magnavox (http://www.magnavox.com ) site or the Funai support site (http://www.funai.com/us ). At Funai, search for the model number but leave off the brand. They make units for a number of brands.)
Oct 04, 2011 | Philips Rc1904100601 Remote Control
I have lost the manual for my Crest model Po5094-2 remote. I need the code for Philips model 29PT468A TV. Can you please help?
Hello
four digit remote codes for Philips are:-
0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141
Four digit remote code for Magnavox are:-
PHILIPS-MAGNAVOX ..... 0062 0204 0207 0183 0226 0288
Three digit remote codes for Philips are:-
003/ 004/ 006/ 008/ 062/ 068/ 069/ 074/ 075/ 076/ 086/ 087/ 089/ 133/ 163/ 183/ 184/ 205/ 206/ 207/ 208/ 212/ 213
Three digit remote codes for Magnavox are:-
PHILIPS/MAGNAVOX Codes: 183/ 184/ 208/ 213
NB: Switch OFF and switch On the tv with its front panel power switch each time before gointg to an other code.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Ok
Jan 15, 2011 | Philips Universal PH301S Remote Control
Need manual Philips Magnavox PM8TSMD Universal 8 Device Touch Screen Remote Control
You can get the manual on the link below. Scroll down to Product Details then click on the manual.
Magnavox-PM8TSMD-Universal-Control/dp/B00007B8UB">http://www.amazon.com/Philips-Magnavox-PM8TSMD-Universal-Control/dp/B00007B8UB
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 31, 2010 | Philips PM8TSMD LCD Touchscreen Remote...
Cant find codes for rem 110
I have the same remote. I googled "philips magnavox universal remote rem110" and found the manual here: http://www.rockabilly.net/files/manuals/REM110.pdf
Sep 29, 2009 | Philips Magnavox Learning Universal Remote
Need manual for philips magnavox rem212 remote control
laters
chris
Dec 15, 2008 | Televison & Video
Need instruction book
I was unable to locate your specific model using the information you provided however here is a link to the Philips website.
http://www.support.philips.com/support/html/index_us_en.html
They have a diagram to identify exactly which numbers they need to identify the appropriate manual. From there it should be a simple download to get the information you need.
I hope this helps, good luck!
Kym McC
Oct 11, 2008 | Philips Magnavox Learning Universal Remote
Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Feb 03, 2008 | Philips Magnavox Learning Universal Remote
I need the codes
I have a Magnavox dvd/vcr player and a Phillips universal remote. I was able to get the two to talk to each other by using the code for the brand Funai. This was discovered by entering the model number on google and searching. Magnavox must use their name on the unit but it is in fact a Funai dvd/vcr player.
Nov 13, 2007 | Philips Magnavox Learning Universal Remote
Televison & Video Logo
244 people viewed this question
Top Televison & Video Experts
Electro Med Services...
