You probably got water under the cooktop while cleaning around the knobs. It causes a short at the 120 volt igniter switches on the shaft of each valve. Unplug the stove for 1 or 2 days and let it dry.
I don't have a Thermador cooktop but here is ma taught.
Could you unplug the two faulty igniters and see if problem remained
Could you plug one of the faulty igniter at the location of a good one. The goal is to isolate the problem. Is it the igniter or the electronic board.
Faulty ground problem may occur also after an spillover on the stove. In that case, use a cotton swab dipped in scrubbing alcool and clean the spark area on the igniter and the burner.
Hi
It sounds like somebody clean up the stove and the electric sending unid is wet, try this: the knob that correspond to the ingniter that it's clicking nonestop, take the knob out and you will see the sending unit, pull it out unplug it and dry it out and then try it again, it should work properly after it's dry.
Eddie Rentas
Tupper Lake NY
is this a sealed burner unit? if so the burner base (the heavy brass part under the burner cap) has to be sitting just right. you will notice that it has holes around the the sides make sure that where your ignitor sparks to it that it aligns with the lowest hole on the burner base. if you have a great flame all around the burner after checking what i mentioned i would replace the spark module. if it continues to drive you crazy with the noise - just unplug it. the burners will continue working fine without power.
If you have recently cleaned it, you may have gotten moisture behind the knobs and into the spark switches. Be very careful not to let moisture get behind knobs. Very dangerous. If this is the case, they may dry out themselves and stop sparking. If not you may need to replace a spark switch behind knob.
I've had the same problem for 2 years. Today I removed the four burner tops, the 15/16 inch bolt that holds the burners in place, took everything apart (simple connections underneath), completely cleaned and dried eveything. I also cleaned the 4 knobs and making sure the 4 swiches slide up and down freely then dried everything with a hairdryer. Is now works fine but if the problem comes back, I'll simply unplug the cooktop and light it manually. P.S. I stripped one of the large 5/16 inch bolt that had become weak and brittle. - Try using water or some liquid to loosen the bolts as necessary. Good luck, CHEERS!
sounds like you have a bad (elemnet)infinite switch. turn off the power before something really shorts out, replaceing the switch requires uninstalleing hte cooktop from the cabinet , removing the glass top and replacing the switch. first seeing which one is damaged
Had the same problem. All five burners were continuously igniting, after my wife had given the stove a clean. Turned off the power, removed the five knobs and corresponding rubber rings, and used a hair dryer on the five holes where the knobs were for about ten minutes in total. Hey presto, when I turned the power back on, the constant igniting had stopped. Thank you all. I love the internet :-)
