List of wireless connections available
Hi: You've already fixed 1 problem for me. But now I've another. Under the list of wireless connections, there is a linksys which is barely there and I can't move away from the router and stay online. There is another connection which I'm sure is mine but there is a gold lock next to it. How do I unlock this, or how do I make a new wireless connection?
Thanks for your help.
Sonja
  • sonjamdecker Dec 20, 2008
    I don't understand what you mean by " re-set your router to the device thats receiving the signal". How and where would I do this?
    Sonja
Try this first,re-set your router,there should be a small hole behind the router,you will need a safety pin for this,now you will have to re-set your router to the device thats receiving the signal,see if this works for you.
Posted on Dec 15, 2008
I have a Toshiba A105-S101; just had to reinstall XP Pro on this laptop.. my internet is hooked up to my desktop and I need this laptop to connect to my wireless internet. What can I do to get it, Im...
Good day.
Since you already have a wireless connection, it would be easy for you to connect to the wireless network as long as you know your Network name(SSID) and wireless key which could be WEP or WPA. On the lower right hand on part on your desktop,also called the system tray,please look for the wireless icon which looks like an antenna with radio waves. Right click on that icon and please click "View available wireless connection," your network should appear on the list. Please click on your network name and click "Connect" to start your wireless connection. If it prompts for a wireless key or password, you could contact your Internet Service Provider to provide you with the password.
I hope this has helped you today.
May 12, 2011 | Computers & Internet
My Router Has Done This Probably Like 4 Times Already It Works When It's Plugged Up To The Laptop(Ethernet) But It Doesn't Show Up On The Wifi Connections To My Laptop I Reseted It, Took The Power Cords...
Goto control Panel -> Network and Sharing Center
Click on Connect to a network
It Will open a Small window on the bottom right corner of the screen
If it shows Not Connected , No Connections are available then
make sure that the wireless switch on your Laptop is ON
If it says Not connected, Connections Are Available and if its not showing your home network on the list of available networks , then
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
Tom
Dec 20, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How to work my ipad?
  • Turn on your iPod Touch or iPhone by pressing the top button. Wait for your iPod Touch to boot and slide your finger across the lock slider to unlock the device. You will now at the iPod Touch home screen
  • Press the Settings icon on the iPod Touch Home screen to change your system settings. Click on Wi-Fi near the top of the Settings menu. A list of available wireless access points will load.
  • Find your Linksys wireless access point from the wireless device list under the Wi-Fi menu. If you have already setup an security key for your Linksys router, you will be asked to enter the key after selecting it from the list. Press OK and wait as it connects to the router. Enjoy the added benefit of having your iPod connected to the Internet.
  • Oct 11, 2010 | Computers & Internet
    Vpr Matrix 220A5 wireless network not working
    Please follow the mentioned step to check if the Wireless card is installed properly
    Step 1 :
    > click on start (assuming it to be a windows OS)
    > right click on "my computer" and select "Properties"
    > you will have the system Properties window pop-up
    > under the Hardware tab, click on Device manager button
    > under the device manager list look for network adapters
    > you should now be able to see your wireless card under network adapter - check if the adapter is enabled ( if not kindly enable by right clicking on the adapter)
    > once the adapter is active - it will have a green icon with not error on it.
    Once you complete the above task you may follow the below mentioned step.
    Following the below mentioned step will help the Microsoft to take control over the card and try to connect (instead of the software provided by the card manufacturer to control the device)
    Step 2 :
    > click on start
    > Select Run - new window will pop-up
    > type "Services.msc" - new window pops up
    > scroll down to the bottom of the list
    > right click on "Wireless Zero Configuration" and Start (if not already started)/Restart the service.
    > now close all the windows and search for wireless networks again
    you should be able to find it
    May 07, 2010 | Network Associates Symbol Wireless...
    Unable to connect netgear wg111 adaptor to orange livebox for internet connection
    Hi, follow the steps below:
    1. Right click on My Computer icon and go to Manage.
    2. Go to Services then go to Service and Applications.
    3. Double click on Wireless Zero Configuration.
    4. Change the Start Up Type to Automatic and click on Apply.
    5. Click on Start and press OK to close the window.
    6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
    7. Right-click on the wireless Network Connection icon and select 'Properties'.
    8. Go to the 'Wireless Networks' tab.
    9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
    Now please perform the following instructions to connect to the wireless network:
    1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
    2. Right-click on the wireless Network Connection icon and select 'Properties'.
    3. Click on the 'wireless network' tab.
    4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
    5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
    6. Look for the SSID (aka Network Name) of the Wireless router or access point.
    4. Highlight thee SSID from the list that you want to connect to.
    5. Type the security Key here and click on the 'Connect' button.
    6. You should have successfully established a wireless network connection.
    Aug 31, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
    Wireless router not validating my identity
    Hi, Follow the steps below to configure settings :
    4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
    4. Highlight the SSID from the list that you want to connect to.
    I hope this information allows you to resolve this issue.
    If I have helped you, please help me, and rate this suggestion with the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
    Regards
    Anand
    Jul 30, 2009 | NetGear WNR834B RangeMax NEXT Wireless-N...
    Netgear wgt624 with WGt111 usb wireless connection showing red no connection when using netgear wizard programme
    Follow the steps to configure wireless connection :
    Jun 08, 2009 | NetGear WGT624 Wireless Router
    No wireless adapter detected ad wireless button ot turning on
    First u need to make sure ur adapter is installed correctly.
    1. Click on Start-->Run-->Type in "devmgmt.msc"
    which will open device manager.
    Under device manager , u should find network adapters, make sure ur adapter is listed under it without any yellow exclamation mark or red cross which would mean that the drivers are not installed correctly or the adapter is disabled. In this case u need to reinstall the drivers via the CD.
    2. Secondly u need to goto start-->run-->type in "msconfig"
    which will open the system configuration window. Now under the "startup" TAB. Find the service for ur wireless card and disable it by unchecking it and then apply the settings and OK.
    Reboot computer once
    3. After reboot, goto start-->run-->type in "services.msc"
    It will open the services windows . Find an option for wireless zero configuration . Rt click on it and start it.
    4. Goto start-->run-->type in "ncpa.cpl"
    It will open network connections window.
    Rt click on Wireless network conection and enable it .
    If it is already enabled , then rt click on it again and click on "View available wireless connections"
    It will give u a list of all the wireless connections available in ur area.
    Click on the one which is ur connection and then click on connect.
    It might ask u for a wireless key if it is a secure connection. Enter the key and it should all work fine.
    May 25, 2009 | Acer Aspire 5520-5579 Notebook
    How do I check that I have service pack 2 installed on my Windows XP home edition. I have service pack 3 and many updates which have been done automatically. I need help with getting my computer to talk to...
    HI,
    Did you reinstall the drivers for your wireless adapter? please check the device manager and confirm that wireless adapter is getting listed under "Network Adapters". and if the driver package includes a software which helps to configure the wireless adaptor , you can find it under Start-> All Programs menu. if there is no software provided with the driver package, follow the instructioss:
    1. click Start and Run.
    2.  in the Run command box. Type "services.msc" hit enter.
    3. in the list check for a service named, Wireless Zero Configuration. check the status, if it is disabled, right click on it, go to properties and  select the startup type as "Automatic". click apply and click start.
    4. now go to control panel and go to network connections, . if the drivers are properly installed for your wireless adapter , you can see a computer icon with a red x marx which has the name of your wireless adapter. right click on it and select the option view available networks, it will scan for signals and will give you a list of wireless netwok available in the range, select your network and connect, it will ask you for a key if its a secured network, enter the key and it will connect without any problems,
    Hope this will help you.
    Thanks,
    Vipin
    Mar 16, 2009 | Computers & Internet
    Computers & Internet Logo
    41 people viewed this question
    David Payne
    David Payne
