Question about Panasonic PT-60LCX63 60" Rear Projection HDTV-Ready Television
Tepreture light comes on and OSD advising to clean air filter
  • 1,284 Answers
If you take off the front panel to access the lamp for replacement. there should be the air filter near by that you can remove. Carefully clean it by blowing through it but use no liquids. If it is too clogged then filter replacement is probably needed. I think you have to get the filter with the new lamp otherwise.
Posted on Mar 17, 2007
An OSD advising "AIR FILTER CLEANING" is displayed
You must remove the light engine then locate the filter by removing a black cowel looking device at top of engine held by 4 screws,then you will see the rectagular filter held with 4 screws you must pry out the filter it does not come out easy. Clean it with clear water and blow out with compressed air look at it through light to make sure it is clean. reassemble The sevice manual will show you how to remove the light engine.
Feb 10, 2010 | Panasonic PT-52LCX66 Projection Television
Panasonic pt-61LCX65 osd air filter cleaning came on screen and the unit shut down in 1 minute. I would like to know exactly where the air filter is where I can clean it myself.
This is stright from Panasonic.
The consumer is not able to change the air filter. It will have to be done by an
authorized Panasonic service center."
Jan 22, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
My unit freezes up after being on for few hours. please advise. thanx
make sure your air Filter is clean your Evaporator being Dirty will cause freeze ups also
after changing filter and unit is completely defrosted turn on indoor fan only and check airflow coming out of register if you do not feel much air coming most likely your coil is very dirty if Both Air Filter and Coil are Clean could be Low on charge those are the most common causes of freeze ups
Jul 01, 2009 | Friedrich WallMaster WS12A10D Air...
OSD Message Panasonic PT-50LC14 Air Filter Needs Cleaning
I had the same problem and the stupid tv would shut off after 1 minute. We opened the silver front panel , took the bulb out cleaned it, took the cover off the grey box to the right and very carefully vaccumed the filter and wiped it off with a microfiber cloth. It works great now!!! Make sure you unplug your tv before messing with it.
Sep 28, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Osd for filter needs cleaning
i had the same message come up on mine called a service co. they came over took the front panel off tv removed center door which exposed what appeared to be a lens of some sort sitting on top of a square box with a type of foam glued to it he said that was the only filter on that television he took a damp papertowel and wiped it off. message has not reappeared but that was just earlier today. Hope this helps.
Jul 02, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Air filter
air filter message is ussally generated by a tempsensor getting hot. could indicat falulty sensor.. is the fan running. a stalled fan could cause the problem but usaally when that happens it completley shuts down
Jan 29, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-60LCX63 60" Rear Projection HDTV-Ready Television Logo
155 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
