Question about Emerson EWF2004 20" TV
Emerson cr202em8 color trouble
My emerson tv I noticed today has alot of green color on the right side of the picture thanks Bill
4 Suggested Answers
  • 15 Answers
SOURCE: Emerson EWF2702 27" TV
I had the same problem it ended up being the speakers I had on top of my tv, so I had to move them. If you have anything on top of your tv with a signal move it. :)
Posted on Nov 23, 2008
  • 304 Answers
SOURCE: Toshiba 62; DLP 720P- Alot more red and green
You have probably have installed the wrong lamp or you installed a third party/off brand Lamp. If that is the case anything other than a Factory replacement Lamp will have a different color temprature. Install a Lamp that is listed from the manufacture.
Posted on Jul 17, 2009
  • 4 Answers
SOURCE: I purchased a used Emerson TV Model 3 CR202EM8 and
go here if you cannot access the site: here are the instructions:
Your password will be erased and return to the default
(0000) when a power failure occurs. If you forget the
password, unplug the power cord for 10 seconds to restore
the password to 0000.
Posted on Oct 28, 2010
What are the remote codes for the emerson cr202em8 tv
if u google tv remote codes it should give u a list of the most common, if its not listed there is a way remotes can be set up through trial & error but its different for each type, it should all be in the instruction booklet for the remote & the codes.
Aug 02, 2015 | Emerson New Original CR202EM8 Remote...
EmersOn TV has no picture when you turn it on, I noticed that the red light blinks 4 times after pressing on, I'm curious if that means something? Please help!
the 4 blinks are a error code means something wrong inside the tv
type your number and error code in google maybe point you in right direction
Jun 23, 2015 | Emerson Televison & Video
Emerson cr202em8 television I cant see any canal and we don't have the manual.
Try this link to download the user manual. http://tv.manualsonline.com/manuals/mfg/emerson/20digital_analog_television_cr202em8.html. Check this link too. http://electronicshelponline.blogspot.com/ Pull up older posts there, either by its left side bar, or see it in Timslide option.
Jun 23, 2013 | Televison & Video
The color is going green all the time
first check the color settings of your remote if still does not work send it back where you bought it or bring it to a closest technician maybe your tv accidentally catch a water and hit the parts inside the tv
Mar 10, 2011 | Televison & Video
LEFT SIDE OF PICTURE IS BLURRY AND COLORS DISTORTED
Does that set have whats called a color wheel, if so that maybe you problem, and replacement is how you fix it.
Apr 30, 2010 | Toshiba TP43H95 43" Rear Projection...
I have an Emerson SD 20 inch TV (its not a flat screen). SN# V12739168 & Model # CR202EM8. We purchased it 2007 (used it only 2 years). Suddenly it would go on and off by its self, then finally it...
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Jun 01, 2017 | Emerson EWF2004 20" TV
I have a philips 60 that leaked out oil need to replace
If you can still powerup the tv and see a picture and sound is fine, you can probably save the TV. Pull out the board that was drenched in oil and let it sit in a warm area for a few months, it will dry and should be fine. You will need to purchase projection fluid... see MCM Electronics.com. Then you will have to do complete convergence on just the one color tube that you replaced the oil. The code to enter to do this is 062597 MENU on the remote. You will see instructions to converge. Please find the technical instructions that should be stapled to the back of the tv. Or locate the service manual on this website to see what keys on the remote to work. Remember the only color you will be working on, is the tube you fill. Good Luck and be very patient.
Oct 16, 2009 | Philips Televison & Video
2 year warranty
the Majority of problems on this and all other LCD TV's are capacitor problems the power pack needs smooth power to work correctly however the warranty should be valid and you need the proof that you bought it and you need to know who to contact about the 2 year warranty it may be Emerson you need to speak with not Walmart. I would contact them next(Emerson), or whom ever the third party repair service is that will cover the Warranty.
hope this helps
Nov 19, 2008 | Emerson EWL2005 20 in. LCD Television
20" digital flat stero tv moel CR202EM8
It sounds magnetised. Is there a magnet near that side... like a speaker?
It probably needs degaussed. Many TV shops have a device that does this, at a cost to you. Also, the set degauses itself for about a second when it's first turned on after being off for a while. So it may go away by itself eventually.
Hope that helps...
Geno
Feb 27, 2008 | Emerson EWL2005 20 in. LCD Television
Emerson EWF2004 20" TV Logo
54 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
