Question about Toshiba Libretto 50CT Notebook
TOSHIBA LIBRETTO 50CT NEEDS LINUX
I want to run LINUX on a TOSHIBA LIBRETTO 50CT mini laptop- For applications I would like to connect to the internet and run a small office type suite- I have hardware including modems- Has anyone ever set up a system of this sort-
  • rburley Dec 15, 2008
    I intend on trying your solution in the next few days-
    THANKS, Bob
  • Toshiba Master
  • 4,806 Answers
Hello there
If you haven't got it already, download "Freespire" its a free linux download and really easy to use!!!!!!
It comes equipt with all the software you will need and a automatic updater which will download anything you need for the system.
Its easy to set up your internet and use office software (you can even view microsoft docs), with this you can even connect and chat to MSN, Yahoo etc
give it a go you will like it!!!!!!!!!
Kind regards
Posted on Dec 15, 2008
Toshiba libretto 50 ct wont boot
I haven't encountered multiple beeps on shutdown - but multiple beeps on startup is usually an indication of a memory issue. Frequently can be resolved by simply taking memory modules out and re-inserting them.
If problem continues, may need to replace memory chip. If more than one chip, put one in at a time and startup to see which chip is causing the problem.
Not sure, based on your description of the problem, if this is the issue - but certainly worth a try.
Best of Luck!
Jan 03, 2013 | Toshiba Libretto 50CT Notebook
Reset to factory default
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
May 19, 2012 | Toshiba Libretto 50CT Notebook
I have a single vertical blue line on my 50CT Libretto screen. It does not show on an external monitor. Any ideas what's causing the blue line if it can be fixed? Thanks Mike H
Just a bad screen. There's not a cost-effectve fix for these things due to the age of this laptop and on top of that, these screens were incredibly rare even when they were first sold. If you must replace it, then your best bet would be to hunt down a whole unit (eBay would be your best bet) - it might take a while but your target price should not be over $20 delivered. That'd be your best bet.
Sep 08, 2011 | Toshiba Libretto 50CT Notebook
My toshiba libretto laptop won't turn on how do i fix it
first, I will advice that you check the adapter, see if its still working. The adapter might be the reason your laptop is not working.
If you have confirmed that the adapter is still good, let me know so that I can direct you further.
Take care.
May 28, 2010 | Toshiba Libretto 50CT Notebook
The machine will not boot up. The green power light is on and the hard disc light comes on just for two or three seconds and then goes out.
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
Mar 03, 2010 | Toshiba Libretto 50CT Notebook
Need to boot into BIOS to change IDE setting. No Floppy drive.
hi
To enter the BIOS during start-up press the ESC-key while switching power on
hope this helps :0)
May 19, 2009 | Toshiba Libretto 50CT Notebook
Upgrade the Toshiba Libretto 50 CT
if you want to improve the speed of your laptop you could buy a faster harddrive with an higher rpm per minute than the one installed in the unit, that WILL speed up the system:), and yes its possible to boot from the 2gb flash card but i recommend if you are going to use a flash card you get a bigger one:)
Cheers
Jan 04, 2009 | Toshiba Libretto 50CT Notebook
100Ct
Hi, Depends on what OS you are using. For this particular model (Libretto 100CT), it is probably either Win9X or RedHat (or some Linux variation). In Win9X, you might try F8 & run it in DOS and run: Scandisk c: /autofix /surface; Scanreg /fix If it is beyond repair you have to have access to the OS installer CD. Sometimes Win9X installer is also saved in the HD. Try checking if it is inside your HD and run setup. Hope this be of some help. Pls post again how things turn up. kind regards.
Jul 24, 2007 | Toshiba Libretto 100CT Notebook
Need diagnostics disk (floppy image) referenced in service manual
Hi You may try the following site for a diagnostics disk: http://www.bootdisk.com/bootdisk.htm Regards Harry
Jun 13, 2007 | Toshiba Libretto 50CT Notebook
Toshiba Libretto 50CT Notebook Logo
268 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
