Question about Maxtor DiamondMax Plus 8 40 GB Hard Drive
Harddisk not detected
I had Fedora Core 5 which i then had to get back to Windows Xp, i was unable to format my harddisk and replace it with Windows, a blank screen appears if i try to install Xp. anyhow, the harddisk droped down by mistake and is not being detcted at all by the Xp setup Anyone have any ideas on how to fix this?????
  • Anonymous Apr 29, 2008
    my harddisk got hang first time when i use to format my pc...........
    and when i again restarte it setups normally
  • 102 Answers
Is it detectable by your System BIOS ? If it is detectable, there is two solutions, Hardware one and Software one. The Hardware one, is to remove the HD's Board and replace it with another one. you only have to unscrew 4 or 5 screws, it's simple. The software one, is to Get Hiren's Boot CD and use a tool there called MBR Tool. Start it in DOS mode and Press the Recover/Restore MBR. You should try the software part first. and Before trying anything you should look for cracks or hits (caused by the fall of your HD) on the HD Board or the Body of the HD.
Posted on Mar 16, 2007
    President:
  • 2,961 Answers
You can try and install it on another pc as a slave drive and see if the bios and windows recognises it, but if you have droped it, it is likely that the platelettes and the head parking arm are damaged and unrepairable.
Did not see second sata harddisk
To know if your Hardisk is detected follow this steps:
In Windows XP
1. Open Control Panel
2. Go to Administrative Tools
3. Open Computer Management
4. Double Click Storage
5. Open Disk Management
All the list of Hardisk is here, your hardisk is not formatted that's why, so you have to proceed to format just right click that unformatted hardisk and choose format, specify the label for your hardisk or simply leave it blank.
Jan 11, 2010 | HP dc7600 Small Form Factor P4 640...
I want to remove Fedora 8 and install Win Xp.
press F2 to enter setup while booting up. find "Harddisk Mode" and select "Compatible". Save and re-start. You may now install windows XP.
Oct 15, 2009 | Acer Aspire 5315 Notebook
Windows not booting
Regarding on your problem, the main issue their is the booting problem of XP after you delete the fedora operating system. That's common problem especially when the computer are in dual boot OS then you delete the other OS. Now, the reason why it usually fall into this problem its just because the XP is your core OS then you install Linux Fedora inside in XP so whatever changes you have done in fedora particularly deleting Linux OS inside XP affects the overall performance of your XP and eventually if you delete the Fedora without proper unistallation process done by Linux OS then the Boot Loader of your XP will also corrupt or delete that's the main cause of boot failure in your XP OS. Now the best solution there is to repair your XP by inserting the XP CD Installer and boot the CD to repair your OS or you can reinstall the XP OS without formatting the storage to prevent the lost of your data that has not yet already copyed a back up.
Please do this recommendation to save and restore your XP.
thanks
Sep 04, 2009 | Microsoft Windows XP Professional for PC
Unable to delete data or format or partitioning samsung HDD
Have you tried booting from a Windows XP CD? If you have one available you can boot from it, delete the partition and format it. Works all the time for me.
Jul 30, 2009 | HP Computers & Internet
My dvd rw is not detected
Sounds like you need your manufacturer's SATA drivers.
This problem exists a lot when installing Windows from scratch on SATA hard disks. When you start the installation, Windows prompts you to "load additional drivers". It's at this point you put a floppy disk with the SATA drivers in.
If your install is already working, but just stopped as you say... then you could hunt around the BIOS for a SATA "compatibility" mode, which will get you booting straight away. Install the SATA drivers and you can then put the drive back into normal operation instead of compatibility mode.
This is also the reason why your other hard disk with Windows can see the SATA disk and optical drive... it probably has the SATA drivers installed.
Aug 20, 2008 | Microsoft Windows XP Professional With...
SATA Controller type for the Intel Desktop Board D102GGC2
u can use fedora core 6 or 7
do not install fedora 5 on D102
ithe display will be disorderd.
Jan 04, 2008 | VIA Biostar P4VTB PT800 P4 800MHz Busspeed...
Linux Not installing and Not detecting Harddisk
what version of linux are you using, suse, mandriva, fedora etc...
and which release is it (eg. suse 10.1... or whatever)
Dec 30, 2007 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Unable to install Windows XP on HP Pavillion DV2000 ( Built in Vista )
Best Solution is to disable Native SATA support in BIOS ,
Now Win XP will recognize the Hard Disk
Sep 05, 2007 | HP Compaq Presario V2000 Notebook
When installing SP2 version, you possibly corrupted the drivers for the DVD. It is possible there are different drivers for the DVD between XP and XP (sp2). Go to the laptop mfg website and download the newest drivers for the DVD.
Aug 20, 2007 | Microsoft Windows XP Professional With...
Hard disk not getting attached with Linux
Hi, I'm not too keen on Linux but I found this website that might help you. http://rajibchy.tripod.com/ Check it out.
May 24, 2007 | Seagate Momentus 4200.2 (ST9808210A) 80 GB...
Maxtor DiamondMax Plus 8 40 GB Hard Drive Logo
575 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
