Back to:
Tags:
IBM 61H0031 - Drive Cage Drive Case
IBM 61H0031
posted by romanwind on Mar 16, 2007
There is someone who can help me with this case?
I've removed it from an old IBM330 and I would use it with a new raid controller. When I start pc I have everything ok, but I don't "see" disks at the end of the procedure.
Thanks in advance
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 14, 2007
Not Rated (0)
warewolf2001
Rank:Wiz Wiz
Rating: 82%, 98 votes
have you installed the drivers for the raid controller that allow you to see the disks and if you have then the disks not getting enough speed check in control pannel and Administrative Tools Computer Management then disk management and see if their there.
hope this goes well
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on IBM 61H0031:
I don't want to Accept this solution
Can you Help with these Drive Cases problems?
Drive Cases
I have a bytecc backupstar me-808 and the drivers will not...
Drive Cases
I need to remove the hard drive from a Maxtor personal...
Drive Cases
I forgot to mention that the old hard drive in the...
Drive Cases
i need to fit seagate hard diive into new enclosure
Drive Cases
the connector to the plug appears damaged, blue light...
Loading problems.
Repair Service
Find Drive Case Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
