Question about Dynex 32 in. LCD Flat-Panel HDTV
Dynex 42" HDTV - pressed "Comp" button now cant get back to TV
Dynex 42" HD TV - I pressed the "Comp" button and now cant get back to TV.
Comp button says: "Component 1" "Component 2". I thought if I kept pressing it it would eventually return me to the TV mode. I cant get out of the Comp mode.
I was trying different buttons to shrink the picture down on the TV screen. Its too large now and will not allow me to see the score at the bottom of the screen when watching a football game.
  • Anonymous Jan 11, 2009
    compre un tv de 42 ' en octubre del 2008 y lo instale en diciembre la tarjeta de audio esta quemada , vivo en ecuador y necesito comprar esta tarjeta donde la compro es urgente
Press the TV button on the remote. You are confusing the Comp button with the Input button which allows you to switch between input ports.
Posted on Jan 09, 2009
Need tv code for Dynex 19" for Radio shack 8-in-one remote
i have a 42 inch dynex tv and i have a LUMINOUS JUMBO REMOTE on the top of the remote it says 8 FUNCTION REMOTE and i cant find a code that works for the tv can someone help me plezz
Sep 23, 2010 | Dynex 19 in. LCD Flat-Panel HDTV
The picture on my new 32" does fill the screen. What should I do to correct this problem?
I assume you have pressed the zoom button on the remote control that came with the tv. If you have a cable box or satellite tv box press the # button or hd zoom button or aspect button or format button on that remote control. If you are connecting a high definition cable box or satellite tv box to this television make sure that the high definition cables are connected to the right high definition inputs on the television and that the television is switched over to the right corresponding input. If all else fails and this is just happening on one hd channel it is the hd channel.
May 06, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Headphones on my dynex 42-inch tv the speakers are still on
Use the MUTE button on the remote to mute your TV speakers and then you can still use our headphones. You can continue to adjust volume with the remote and it will only affect your headphones. You may need to do this each time you turn on the TV and use headphones, but that is a small annoyance.
Dec 26, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Just bought a 42 inch lg tv and cant programme my
please follow the steps below with you sky remote:
TV
RED + SELECT (hold these down until it flashes twice)
TV
0056
Try the volume button if this works then press SELECT. If it does not work then press TV again then try the volume ( repeat this step until the volume works. Dont forget to press the SELECT button to save the code to the remote.
This should sort you out. Please leave a thumbs up when you get it working.
Cheers Little Dish Fitter
Sep 24, 2009 | LG 42LC2D 42 in. LCD HDTV
Cant find component 1 on samsung tv
Use your input/source select button. Should display input 1,2,3,4 comp 1, comp2 etc in order then repeat. Make sure your using the correct component input. Most sets have 2. Turn on the device first so you'll know your there when you see the picture
Aug 06, 2009 | Samsung 50" Slim-Depth DLP HDTV
I have a 42'' dynex tv, without an instruction manual. The picture is too large for the tv and I need to find out how to fix the pixels, I have tried every button and even all the choices in the menu....
You can get your manual here:
http://www.retrevo.com/support/Dynex-DX-LCD42HD-TVs-manual/id/22974bh131/t/2/
This is for the DX-LCD42HD-09.
The ZOOM button on the top of the remote is the one you want to keep pressing until you get the picture size you want.
If you are using a HDMI cable for HD, the HD channels should fill in the screen automatically. The non-HD channels would have the empty spaces on the sides for 4:3 screen format.
Best to keep it on normal mode, so the top and the bottom don't get cut off.
May 15, 2009 | Televison & Video
No picture on new Dynex 42" lcd hdtv
Do you have cable or DVD player connected yet? If not, connect your cable to the back of the LCD via Coaxial cable. Next turn channel to 3 or 4 whatever channel you use for cable. Then use auto programming to find all of your cable channels. If no cable connect the DVD outputs to one of the AV 1 or Av2 inputs on the back of your LCD. Power on the DVD player and change your input to which ever AV you connected it to. You should see a blue screen and your DVD Player Icon.
May 13, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Remote code for comcast
Dynex has a website with the codes. It worked for me the first try.
I have the 42" LCD HD code 0463 for Comcast also 10463 if your remote takes 5 digits.
Nov 28, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Program a universal remote for the Dynex 32" 720p Flat Panel
Try using the codes listed for Orion products. Worked for me.
Jun 26, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
HD PICTURE
Use your input button on your television's remote control.... you should have plugged the wires into the COMP 1 area on the back of your TV.  You will also need to make sure your red and white audio cables are plugged in as well (Five total plugged wires) Press the input button until you see COMP1 at the bottom of the screen... there you will find your picture and sound.
Oct 19, 2007 | GE D52GW12 52" Rear Projection HDTV-Ready...
Dynex 32 in. LCD Flat-Panel HDTV Logo
282 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
