Question about Thermador 30", 36" Silent Series Wall Hood, HSB
Thermador wall hood model HS36
The filter light is on. Cleaned all three filters. Still on. Can't find the original manual now. What is the next? Thanks.
  • 8,197 Answers
Here is the web site where you can get parts and the manual to help you out on filter problem.
http://www.thermador.com/site_tools/DocumentDisplay.aspx?menu_id=27&menulevel=0302&keyword=HS36
Posted on Dec 16, 2008
    New Friend:
Press the Filter button for 5 seconds. Worked for us.
Posted on Apr 30, 2013
Where is the fuel filter at on a 1993 Plymouth colt vista
Susan; It could be one of three locations, under car along frame rial, under hood engine compartment mounted on fire wall, or under hood mounted near shock tower. below 2nd link shows the filter assembly and partial harness to help identify location.
press the helpful button
Dodge Colt Repair Manual Service Manual Online 1990 1991 1992 1993 1994
FUEL FILTER 35 VISTA CZ for 1993 PLYMOUTH COLT
How To Replace Fuel Filter
How to Change Your Fuel Filter
Feb 05, 2016 | Plymouth Cars & Trucks
Hi I have a Rinnai RCE-29H (gas heater) that I just got off a friend and it is working fine however the Filter light comes on from time to time. Once the light comes on it generally stays on for a while....
No, Tina there's only the one filter. However, the filter should never be removed for cleaning while the heaters electronics are ON. If you're still getting the filter light. Turn the heater Off, using the Master On/Off Switch and unplug the electrical cord from the wall outlet. Leave the heater unplugged for 15 minutes. Plug the heater back in and turn the Master ON/OFF Switch to ON, the heater electronics should turn ON and revert back to the original factory settings. After that, you can reset them to what you originally had them on.
As far as an Owners Manual is concerned, I couldn't find one in my Rinnai USA data base, that matches the one you listed. If you don't live in the U.S. that's probably the reason. However, if you can provide me with the country you live in, I may can find one for you.
Hope this helped. Please let me know. Thanks.
May 16, 2011 | Heating & Cooling
Where can I purchase the 120V, 40w bulb for E27 base thermador hsb wall hood light
Try Reliable Parts Co. at 1800-666-0313. You will probably also need your model number off of the unit.
Dec 16, 2009 | Thermador 30", 36" Silent Series Wall...
We would like to replace or clean the fan filter
This is a charcoal filter and cannot be cleaned out. If your extractor is no longer working efficiently then you should replace the charcoal filter/s.
Nov 21, 2009 | Vulcan 36" WIDE ELECTRIC(Click Here): WALL...
Fan light flashing on thermador vent hood model HNW36YS
Grease Filter Saturation LED The speed 2 LED in Figure 1 in is marked with an F. This LED will flash to remind you when the grease filter needs to be cleaned after 40 hours use. Follow the instructions for cleaning filters in thisFollow the instructions for cleaning filters in this booklet. Once the grease filters have been cleaned, reset the display by pressing button A for
Sep 05, 2009 | Thermador HNW48YS Stainless Steel Kitchen...
My spacemaker keep dripping grease on my wall, what should I clean?
I would suspect a clogged grease filter (which can be cleaned) and/or charcoal filter (which cannot be cleaned and must be replaced).
You can download GE owner's manuals and installation instructions here.
The manual will give you the details.
Also be sure the hood vent exhaust fan is working correctly.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jun 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Jan 30, 2009 | Thermador Ovens
Replacement filter
I found the part on thermador.com.  Just click on "support center" then "purchase parts & accessorie" and then click the order button for "order accessories and additional parts", on the next screen type in the model "VCH 8" and then just click through the parts list.  The filter part is # 368815 (pos 105).  The part costs $28.40.  I have ordered it but have not received it yet.  Good Luck!   Timnbobbi
Dec 08, 2008 | Thermador Hood Control Housing - VCH8
Lightbulb Dacor Hood
simply remove filter screen from hood (might as well clean it while it is out), reach your hand through the opening, grasp the light bulb and turn clockwise to remove.
had same problem myself and this is what i did.
Feb 23, 2008 | Thermador 36'' HTSW Series Stainless Steel...
Thermador 30", 36" Silent Series Wall Hood, HSB Logo
728 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
