Question about Dryers
I have a ROPER (WHIRLPOOL) model REX3519PQ0. When running the dryer, it will run for about 10 minutes, then shut off. We restart it, it will run for another 10 minutes, and then shut off again. We don't have to reset our fuses or anything, just restart it. It is an electric dryer. We DONT have a vent that goes outside, rather, it just vents into the garage. We hav 5" of clearance behind the dryer. We cleaned the dryer out, top to bottom, and got rid of ANY dust whatsoever, and the problem continues. Our garage isn't that warm at all, so I'm not sure if it's overheating or what... In any case, I'm curious if a new thermostat is the answer to the issue? If it was a FUSE issue, the dryer wouldn't work at all, correct? There's no issue with the belts or with the heating element itself... It's plenty warm! Any help would be MUCH appreciated, as I'm having a lot of trouble trying to identify the exact issue!
  • Dryers Master
  • 8,220 Answers
Most likely the motor getting hot. If this is the case motor replacement is inevitable. The good news is the motor is cheaper than a newer model dryer.
Posted on Dec 15, 2008
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
Roper dryer runs for about 5-10 min. then shuts off. After 10-15 min I can restart, but same thing happens. What up?
disconnect vent tube and run dryer, if it finishes the cycle then there is a restriction in the vent tube
Dec 26, 2010 | Whirlpool Dryers
Dryer shuts off after 15 minutes
make sure the top is not bent down
Jun 15, 2010 | Whirlpool LGB6300 Gas Dryer
Dryer shuts off after running two or three minutes
When you try to restart does it make a urghhh noise and then maybe restart two hours later?If so bad motor
Jun 20, 2009 | Roper REX4634KQ Electric Dryer
Shuts off after 10 to 45 minutes
Weird timer problems are a pretty common occurance try this link! hope it helps ps don't forget to give me a ranking THANK YOU!!
http://fixitnow.com/wp/2008/09/27/weird-timer-problems-in-a-whirlpool-kenmore-dryer-with-electronic-control/
May 06, 2009 | Whirlpool 6.5 Cu. Ft. 5-Cycle Super...
Whirlpool LER8620 electric dryer, shuts off at random. When it
Whirlpool Dryer Won Start
Sounds to me like a thermal fuse. The link gives you multiple scenarios and you can even order replacement parts. I have used it myself with success on washers and dryers. Good luck!
Sep 13, 2017 | Whirlpool LER7646E Dryer
Roper RGX4634KQ will run for 3 minutes then stop.
if you can restart after it stops but have to wait 30 mins or longer suspect bad motor
Jul 21, 2008 | Roper RGX4634KQ Gas Dryer
Dryers Logo
129 people viewed this question
Top Dryers Experts
