Question about Toshiba Satellite A105 Notebook
Getting grey screen with wrong machine
Computer crashed tried to reformat with recovery disk i have a toshiba satellite laptop a-105 with xp will not boot recovery disks
  • Lavonia Ford May 11, 2010
    Have you changed the boot order, so the cd is 1st boot device?
  • 3 Answers
Create a bootable DOS disk and place it in the drive. Then restart the system. that should get you to a DOS prompt. At the DOS prompt you can tell it to change to the D: drive. You can tell if you have done this right because you will see a D: as part of the prompt. Insert recovery disk 1. If it does not start reading the disk type DIR at the D drive prompt. That will list all the files on the D: Drive. There should be one called autostart or install. Type in the name of the file including the extension. Hit enter.
A second approach is to hit F12 during start up and drop down to the second item and hit enter. That started the Toshiba recovery disk for me once when it would not read it automatically at start up.
Posted on Dec 15, 2008
Windows error recovery on toshiba satellite
Sounds like your hard drive has crashed. You will need to replace it.
You can try to run the Check Disk Utility to see if it can repair the drive.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 01, 2012 | Toshiba Satellite L305D-S5895 Notebook
I need satellite a 105 recovery
you have disk from toshiba driver and software so you reinstall satellite a 105 recovery by disk of toshiba
have nice day
you give me vote and rating also
Oct 07, 2009 | Toshiba Satellite A105 Notebook
Want to know the steps to reformat Toshiba - Satellite Pro
Your data - In order to ensure don't copy any infected data backup as few executables as possible. BEFORE restoring your data make sure you have antivirus installed and up to date. Perform a full scan after copying the data back to your lt. Put in the recovery disk and restart your computer. Look for a prompt on the screen to "boot from disk" while it is booting. Press the key it says to press and follow the directions from there. If there isn't a prompt to boot from disk try pressing Alt and F10 while it boots.
Jun 03, 2009 | Toshiba Satellite Pro 490XCDT Notebook
Toshiba satellite 2455 series unable to reboot windows xp/
whats the orig OS installed on your machine? where do you get that recovery cd's ? does it come with the laptop? maybe you've got the wrong OS/ recovery disk with you. Do you have an XP/VISTA installation disk?
Dec 30, 2008 | Toshiba Satellite 2455-S305 Notebook
Toshiba Satellite A 105
The best solution to your proble\m is use TOSHIBA RECOVERY DISK. Install it, it will reformat your hard drive and will reinstall Windows automatically.
Sep 26, 2008 | Toshiba Satellite A105 Notebook
Toshiba satellite screen blank
This could be that the hard drive has failed, and could also be the reason for the initial crash. Run a drive test in the bios or set up. If the test fails in any area then the hard drive is bad and will need replaced. If it passes, then reformat the drive and reinstall XP.
Jul 29, 2008 | Toshiba Satellite A100-S8111TD Notebook
Recovery Disk can not recover system
It could be a hard drive crash. Can you refort the hard drive and see if you get any errors.
Check to see if you have any scratched on the CD.
Jun 22, 2008 | Toshiba Satellite A105 Notebook
Recovery & apps drivers dvd "wrong computer" message
Go for system restore if you are using XP/VISTA.
Download and save your driver in CD/DVD.
May 27, 2008 | Toshiba Satellite A105 Notebook
TOSHIBA A105
maybe the shop formatted the hard drive including the recovery partition where all the files should be .so your disc cant find it .
if you can boot up into safe mode then use windows restore function to restore to an earlier time,if not you may have to get a set of recovery discs from toshiba
good luck
Terry
Mar 23, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Notebook Logo
90 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
