Pc hardrive seems to be working more than usual
I have a two year old pc with a duo core, 2GB ram, 360 GB hardisk and lately the hardrive is working much more than usual. A month ago when I used to do a virus scan with my AVG virus checker or other programmes, the hardisk was not spinning and all was quiet, but now the hardisk is spinning at its maximum causing unneccesary noise and I believe uneccesary wear and tear.
Any idea what could have happened, have I deleted something, unticked a box that I shouldn't.
Any help is greatly appreciated.
Many thanks in advance
Spacedout.
  • Spacedout Dec 15, 2008
    Hi Jaddude,
    Thank you for trying to help resolve my problem, but I have not changed the power options and neither did I change the harddisk settings. AVG did pick up a couple of virusus but I deleted them. Any other solutions is greatly appreciated.
    Many thanks,
    Spacedout.
    Hi Larry,
    Many thanks for trying to solve my problem. Once I close the programme that is causing the drive to run all the timel, the drive does slow down, but I have many programmes that is causing this problem one of which is the world known virus checker AVG which never caused this problem in the past. Any other solutions are greatly appreciated.
    Thanks once again,
    Spacedout.
    Problem Solver:
  • 5 Answers
Press and hold the Ctrl key and the Alt key then press Delete.
Choose "Task Manager" and on the applications Tab you can see what my be running. Once you find out what is running you can select it with your "Right" Mouse button and choose "End Task".
If the drive quiets down then you will need to find a setting in the software to stop it from running all the time. If it is unwanted software then you will need to remove it in the Control Panel.
Also, search www.microsoft.com for "Malicious Software" you can find a free remover written by Microsoft.
Posted on Dec 14, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 144 Answers
See if in your power options what you put for the amount of energy devoted to your hardisk
also see in your system about your harddisk setting
to assume the worst you have abnormal operation/a virus
and it would cause your system to use it harddisk more
but i don't think you should worry
harddisks are designed to work hard
hope to help
Can the LG Xnote RD405 laptop intially with 1gb RAM be upgraded to 4 gb using two 2gb RAM's ? Please help me by providing an answer clearly, Thanks in Advance.
Here is the memory specifications from LG.
Maximum Size: Each slot is 1024MB and can be expanded to 2048MB.
SO DIMM Type for Memory Expansion: DDR2 SDRAM SO-DIMM (256MB, 512MB, 1024MB)
It can take a maximum of 2 gigabytes of ram. It will take two 1 gb sticks. It uses DDR2 laptop ram. You need to check to see if you have one stick that has 1 gb or 2 sticks that have 512 mb each. That will tell you if you need to buy one or two sticks of ram at 1 gb each. You will be able to tell a difference going from one gb to two gb of ram. I think it would be worth the investment if you plan on using the computer for another year or more.
Oct 05, 2015 | LG Computers & Internet
My DG41TX works perfectly with dual core processors, but with core 2 duo not, do 3 beeps and dont show any video, what i must do?? my core 2 duo is E8400 my dual core is E2180 Bios Version:...
The POST beep code - 3 short beeps mean RAM failure.
Try reseating the RAM modules.
If this does not solve your problem then remove all the RAM modules and insert one RAM module at a time into memory slot 0 (1st memory slot) to determine which is the faulty RAM module.
Jul 07, 2011 | Intel DG41TX Motherboard
Hello sir, Does NVIDIA 9800 supports my system configuration ----------> intel core 2 duo intel original dg31 motherboard 2 gb RAM ddr2 250 HDD
YES! In fact I have an Intel core 2 duo motherboard and I have an nVidia 9800 video with a 2GB RAM. It works great!
Thank youfor visiting FixYa! We answer yourconcerns promptly for FREE. Please spare a few seconds toclick on YES button in return. Havea good one!
Jun 22, 2011 | Computers & Internet
Problem while upgrading my RAM
some systems require matching pairs, so since you are using mismatched, it may only recognize 1 GB of the 2gb module
Sep 27, 2009 | Dell Latitude D630 Intel Core 2 Duo T7250...
Upgrading My hp530 laptop
It is working.
Tested first with one new module with 2GB RAM, then with 2 modules, 2GB (new) + 1GB (original). Post and Windows are showing 3GB.
The HP 530 notebook is working OK.
Sep 12, 2009 | HP Compaq 6720s Notebook
MacBook Pro 15'' RAM Problems
The earliest MacBook (Pro) models have a limit of 2 GB. To check the specific model, in the Apple menu select about this Mac. Then press more info... . Look at the line like "Model Identifier: MacBook5,2" for my white early 2009 MacBook. If the numbers are 1,1 then for sure you have the oldest model and are memory limited to 2 GB, as the sum of both cards.
That's just like my wife's, it was a Core Duo and not the current Core 2 Duo. Works fine. I was ready to up its memory but read about this in the Apple Support Forum. It came originally with 1 stick of 512 MB, IIRC. I upgraded it to 2x1 GB for a lot more than the 2x2 GB in the newer. BTW some of the Macs between these only take 3 GB but will work with 2x2 GB just throwing 1 GB away. -Ken
Jul 26, 2009 | Computers & Internet
I have two notes,1xp p4 other core 2 duo vista
its depend how much programs are in startup in your OS.... difinatly core2 duo is fast....
Mar 28, 2009 | Toshiba Satellite P15-S4091 (PSP10U0DUJP6)...
Adding Ram
The RAM should be fine running along side each other but make sure you check the motherboard specs install the RAM leave running for 5-6 hours see how it goes also try memtest86 on your system here is the link
http://www.memtest86.com/
Regards,
Spud
Jun 18, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
