Question about Vtech V.Smile TV Learning System
No sound i get no sound unless i wiggle the 3 cords that plug into the t.v. and the volume still wont stay.
  • 8,596 Answers
Try a different red, white and yellow port on your television - see if the sound works on that. If the sound works fine on the other ports, then the problem is with the TV. If the sound doesn't work on the other ports, then the problem is with the V.Link.
Things you can try to get the V.Smile TV Learning System to work:
1) Press the Reset – Press and hold the ON button for about 10 seconds
2) Make sure the game is inserted far enough into the system, and that it is pointing in the right direction. You may occasionally need to clean the contacts.
3) Also, make sure you are using the supplied power cord/adapter, not batteries. Batteries cause more problems than they’re worth.
-Tha Mp3 Doctor
It may still be possible that the a/v cables running from the V.Link are faulty, but I would try all of the above first.
Posted on Jan 04, 2009
How do I connect these two together so I hear it from my surround sound?
You'll need some type of amplifier to drive the speakers. The Samsung TVs mostly have a line out and a headphone out, but that wont drive speakers unless they are powered speakers like PC speakers or a powered sound bar. (Like the Pioneer SP-SB23W soundbar/subwoofer) If you have some of these get a mini 1/8" stereo plug to RCA plug adapter from BestBuy or similar. If you have PC type speakers, You'll need a 1/8" mini stereo patch cord to go from the line out to the speaker input. (Set the audio out on the TV to variable so you can control the volume with the TV volume.)
Jan 15, 2016 | Pioneer Audio Players & Recorders
Emerson CR202EM9. The video on video 1 and 2 are not working. I am trying to connect my xbox, and the sound works on both video channels but the screen is black. whats wrong? the yellow video cable is...
Try wiggling it the video cable. I have a TV with a messed up video plug-in from pulling cords off it, and when we wiggle it then the screen will flicker the image and we keep wiggling it till the picture stays on the TV screen.
Nov 02, 2010 | Emerson CR202EM9 TV
I plug my input in and my guitar wont play on the amp unless i wiggle the cord and unplug it and plug it back in a million times
The input jack is likely broken... a COMMON problem.
To avoid this in the future, loop your guitar cable through the handle so when cord is yanked it doesn't break the jack by yanking it sideways.
Sep 11, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Won't turn on unless wiggle cord
Had the same problem and cord wiggling worked for a while then no lights anyway I tried. I opened up the handle, and the 3 screws below the handle, to disassemble that part and looked into the little circuit board. The little on/off switch worked directly from the cb so just re-seated everything and Wiola! it works now. Seems like the little silver on/off button at the top loses contact with the actual switch inside and in my case re-seating restored that contact.
Hope this helps..
Feb 11, 2010 | DeLonghi WR25 Retro Belgian Waffle Maker
Very low volume output even with the volume turn all the way up. I connected the system to different computers and came up with the same problem. The volume on the computer is also turn all the way up and...
I had the same problem and found the root cause to be the RF speaker connector at the back of the subwoofer. The male and female connectors are OK. It is the 5 male pins inside the connector and the way they connect to the female holes that is the problem. Wiggle the RF speker connector as you move it in and out until you get 100% of audio voilume back. Once you get it back, do not move the connector. Have not found a permanent solution to date beyond this.
Jan 08, 2010 | Dell ADA745 Computer Speakers
Drill doesnt work unless shaken
It sounds like a bad cord, or a loose electrical connection inside the handle, or the switch.
Instead of shaking the drill, try wiggling the cord where it goes into the drill handle, then wiggle it where if plugs into the wall.
If this doesn't cause the drill to run, try pressing the switch repeatedly to see if that causes it to run. If that doesn't work, it's probably a connection inside the handle.
Try these procedures and please let me know the results. We'll take it from there.
thanks...
Charlie
May 09, 2009 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
Charging issue
It’s either the plug on the AC adaptor (might have a broken wire) or the laptop’s input jack that the adaptor plugs into. The input power jack is soldered onto the motherboard. Could also be a problem with the charging circuit on the motherboard (would need to replace motherboard to fix).
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Jan 15, 2009 | Dell Inspiron 9100 Notebook
Vtech V.Smile TV Learning System Logo
83 people viewed this question
Top Vtech Toys Experts
Nikki  Mclean
Nikki Mclean
Are you a Vtech Toy Expert? Answer questions, earn points and help others
