Back to:
Tags:
Smartdisk - Peripherals - HARD DRIVE, CROSSFIRE 160GB EXTERNAL
How to Fix Bad Sectors on a Hard Disk in windows? (by 4 users)
By herself - usenet poster
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by aamirfalcon, posted on Jun 11, 2008
hi guys,plz help me out,when my pc turns on and disk checking comes it gets stuck at 39% and then i restart my pc and have to skip disk checking and then when my windows start and i goto my computer and right clikc on c drive and goto properties and click tools and scan for bad sectors it gets stuck at phase1 and the pc hangs so what should i do?or what software should i use?plz need ur help my hard disk is samsung sp0822n
Comment by santbir, posted on Mar 21, 2008
I Have a problem in my hard disk when i am install window in my hdd
and don't work properly and currupted after some time late i want fix this probem of bad sector
Comment by Guest, posted on Dec 27, 2007
my hard disk is making a regular noise
Best Solution
posted on Aug 10, 2007
FixYa! (100)
ShaC
Rank:Master Master
Rating: 93%, 69 votes
download the software hdd regenerator. This will help you to fix the logical bad sectors.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on How to Fix Bad Sectors on a Hard Disk in windows?:
I don't want to Accept this solution
Solution #2
posted on Dec 12, 2007
FixYa! (100)
bahloul
Rank:Apprentice Apprentice
Rating: 97%, 11 votes
il et perdu le code de bios nec versa c200 help me s.v.p ilya 15 jour
Comment by bahloul, posted on Dec 12, 2007
coman decodes le bios il fermes par pass word s.v.p help me contactes par email gladiateur.003@hotmail.fr merci a tous
Thank You!
Provided by HP STAFF
Solution #3
posted on Mar 17, 2007
FixYa! (100)
Bogdan
STAFF
Rank:Guru Guru
Rating: 90%, 414 votes
Hello herself,
A hardisk contains a special chip on it's board that contains information about it's operationg parameters and so on. Also there is a part at the begining of each cylinder that also contains a record of every sector. A phisical bad sector will be recorded there first, and the hard-disk will ignore it. This isn't something that you see in software utilities, it is being done by the hard-disk's firmware and microcontrollers. However when the space allocated for bad sectors recordings gets full, the visible problems get to appear. Only then you find out about bad sectors and only the bad's that appear after. What you see is something like the top of the iceberg. A back-up should be made, as it is going to get worse, fast.
There are 2 types of bad sectors.
1 Logical bad sectors. This occurs if a cylinder ( one of the disks inside of a hard-disk) is magnetised improperly due to errors. The hard disk works in the same way as od tape recorders. It magnetises at diferent potentials some portion of a disk to store information. If it does that rong due to some software errors or improper shutdowns it woun't be able to read the improper magnetised zones next time. The software (windows) will call this "bad sectors" and will mark them, never to be used. The software doesn't make the difference between logical bads and phisical ones, it just knows it can't read data from there. Logical bad's CAN be fixed, because they're just improper magnetised areas of the hard-disk. Utilities like hard-disk regenerator will help you with that by remagnetising those areas. Note that windows doesn't know how to get rid of these, it only marks them or attemt to read from it again, but doesn't actually do something to recover them.
2 Phisical bad sectors. They occur when the hard-disk heads touch the disks and scrach them. This is the more often case. Take note that hard-disk's aren't vacuumed and inside them there isn't ..void. They are presurised but they actually "breath" from the surrounding space. You may find on some hardisks some small holes with a sticker near them saying not to cover them.
When a hard-disk is powered on it creates some strong air currents inside it. The reading/writing heads will actually hover over the disk surface not touching them. When,however, due to changes in the rotating spead of the hard-disks this air curents are decrasing in intensity, the reading/writing heads woun't be able to "hover" and could come down closer to the disks and actually scrach them. This produces circular scratches over a disk, and those can't be recovered. Dust inside a hard-disk is just as leethal, as it will scratch the disks surface.
I hope you know have an ideea about bad sectors. If you need more assistance in bad sectors you may post back.
Also sorry for my bad english as I am from a non-english speacking country.
Thank You!
Solution #4
posted on May 19, 2008
Helpful (85)
k_keysha
Rating: 85%, 1 votes
I found a site dedicated to fixing the bad sectors try this to find more fix bad sectors
Thank You!
Solution #5
posted on Aug 08, 2005
Thanks for Trying (70)
Chandler
Rating: 0%, 0 votes
The minute your computer's hard disk starts to act flaky, make sure you have an up-to-date backup. Then you can do some simple diagnostics and repairs. Both Windows and Mac OS come with built-in hard-disk utility software that scans your hard disk for errors and attempts to fix them.
1. Double-click on My Computer to open the My Computer window.
2. Select the disk that you want to diagnose and repair.
3. Choose Properties from the File menu. You should see the Properties window for the drive that you selected.
4. Choose the Tools tab.
5. Click the Check Now button under Error Checking Status.
6. Depending on your version of Windows, choose either "Thorough" or "Scan for and Attempt Recovery of Bad Sectors."
7. Click on Start.
Thank You!
Solution #6
posted on Aug 31, 2007
sslumina
Rating: 68%, 7 votes
Whe your Hadrive doesn`t want to be regenerated do the following.
Step one:
Remove the hdd amd take it with you to the guarage.
Step 2:
Plase the HDD on a sterdy Work bench or on a metal service not on the floor it may leaf marks.
Step 3:
Get the larger Hamer that you may have in jou toolbox and Hit the living crap out of it.
Please Note:
This won`t help to repaer the drive but it is good for Stress releave and frustration that may be caused by the broken HDD.
PS....
Step 4;
Trhoug the HDD in the Trash Because now it is realy Broken. :-)
Thank You!
Solution #7
posted on Oct 02, 2008
Not Rated (0)
knowvejohnde
Rating: 0%, 0 votes
All Logical are bad
Thank You!
Solution #8
posted on May 09, 2008
Not Rated (0)
francis0211
Rank:Master Master
Rating: 82%, 14 votes
faulty hard drive.. go replace it.. im not kidding.. if its getting noisy.. replace it..
Thank You!
Solution #9
posted on Feb 16, 2008
Not Rated (0)
Rajendra777
Rating: 0%, 0 votes
disk error my mobile nokia n73 m 9822492777
Thank You!
Solution #10
posted on Jan 05, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
why if the PC is not recognicing the divece at all, how you fix it with out using window? I mean opening the hard drive and stuff
Thank You!
Solution #11
Not Rated (0)
bahloul
ban jour a tous j'ai un problem du pass worde de bios nec versa c200 iadi moi s.v.p
Thank You!
Solution #12
posted on Jul 24, 2007
Not Rated (0)
Thomas Hurt
Rank:Master Master
Rating: 78%, 19 votes
Hi there
I understand the problem. If you want to fix the bad sector in your Hard Disk Drive,all you have to do is
1. Insert the OS CD
2. Reboot the computer and boot through the bootable disk
3. Press the letter 'R' after the EULA,it will take you to the Recovery Console
4. It will ask for the user name and password, By default user name is Administrator
5. When asked for password just leave blank and press Enter
6. Type CHKDSK /R and press enter
7. It will take some time to complete the scan process
8. Once its completed type,it will return to C:\
9. Type command fixboot and press enter
10. Restart the computer in normal mode and now everything will up and running
Thanks & Regards
Thomas Hurt
Thank You!
Solution #13
Not Rated (0)
Guest
Rating: 0%, 0 votes
would help if a #8 was added that states to wait awhile for phase 4 to start and takes some time to complete
after phase 4--then what??
Thank You!
Can you Help with these Hard Drives problems?
Smartdisk - Peripherals - HARD DRIVE,...
Hi, I have the same problem with a Smartdisk external HD...
dear sir i have just bought one of your videosafe capture...
hello how do the the code of bad sector plz send me code...
i have hdd regenerator but the problem is to recover the...
elements power d external drive keeps coming up with...
Loading problems.
Repair Service
Find Hard Drive Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
