Question about Canon PowerShot S3 IS Digital Camera
Canon s3is lens error, it turns on but wont zoom...
It does kind of, and i just took a bunch of snow pictures with it, but now i go inside and tried taking some pictures through my window and it wouldnt zoom. it beeped 4 times and then turned blank and said, lens error, restart camera. so i turned it off and tried it again. it zoom a liiitttlle bit. but then did the same thing. now it will only do it somtimes.. and only a little bit. but it says the same thing after every time.. HELLPP!!!
  • 2 more comments
  • debij37 Dec 21, 2008
    The lens stays out. Will not retract. I turn off camera, took out the batteries, charged batteries. nothing works - every time I turn it on- it says lens error. Any ideas would be great!
  • maryanno486 Dec 21, 2008
    This just happened to me today. The lens sort of goes in and out until it reads, lens error, restart camera-Restarting doesn't help either.
  • Anonymous Dec 22, 2008
    Mine had the same message. For a while I could fiddle with the camera and it would eventually pop the lens out. But finally, no dice.
    I had a shop look at it. Henry's in Toronto. They said the lens gearing was probably broken (stripped?) and that the standard repair (out of warranty) would be something like CAD$200.
    I bought a DSLR instead.
  • takeneml8482 Jan 01, 2009
    I am also having this same problem which sucks bc i have come to love this camera so much...
    My lens will not pop out at all and has the same message about lens error and to restart camera which surprises me cause i just used it the other day.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Sep 23, 2012
2 Suggested Answers
BillB-SA
  • 2761 Answers
SOURCE: lens error
If you've recently dropped the camera you may have damaged the lens tube (housing) or jarred the zoom mechanism off of its track. Either one of those problems will require professional repair. If it hasn't suffered from a drop, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may be to weak/worn to properly power the camera, or the camera may require professional repair.
Posted on Oct 16, 2009
Error 18
Something is bent or jammed service will probably cost nearly as much as a replacement camera. Sorry. You can try to cycle the zoom button on the camera a few times before you again try to power off and retract the lens but I am not optimistic of any solution short of repair or replacement.
Nov 30, 2013 | Canon G7 G9 S3is S5is S2is
Fujifilm finepix j38 series reads zoom error and wont take a pic.
If you have some skills, you can open the camera and cline your zoom lens with toothbrush and compressed air. Try to separate zoom lens from the electric motor. usually is 2 or 3 screws. You will see a lot of sand inside the camera and lens. And next time when you will go to the beach, you will take more care about your camera.
Solution 2, and more easy is to buy another zoom lens from ebay.Or another camera same model with broken LCD or other technical problem than zoom lens.
May 31, 2010 | Fuji Cameras
Camera wont turn on. Says lens error and restar camera
If the camera has recently been dropped you may have lens damage that will require professional repair. If it has not been dropped, your problem is likely due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the camera may require professional repair.
Oct 19, 2009 | Canon PowerShot S3 IS Digital Camera
Lens error
Oct 16, 2009 | Canon Cameras
Camera dropped in snow
Where on earth do you find snow this time of year ? If moisture has got inside the camera, chances are it's ruined, I'm afraid.
May 22, 2017 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon S3IS
It's about $124 repair charge if your camera is out of warranty. I called Canon and the guy said to be sure the batteries are now wearing down (which I charged mine last night thinking that was the issue and it doesn't appear to be, however, I'm going to buy some new ones JUST to be sure), but other than that it would have to be serviced because it's something internal. The only place to have it serviced is in Illinois, so it's a send off, he said other Canon shops only service SLR's, not these little automatic ones. HTH...it really stinks to have my camera malfunction at the end of ball season!
Jun 16, 2008 | Canon PowerShot S3 IS Digital Camera
Have a powershot sd550
After many complaints Canon posted this on their web site: "The E18 error code may be displayed if you apply pressure to the zoom lens, lens barrier or surrounding area when handling the camera. Hold the camera so that your fingers do not touch the zoom lens."
There is a lot you can try...
Here is a list of pages with help on the E18 issue:
http://www.e18error.com/repair.html
http://www.bitnet.cx/canon.html
http://blogs.yucs.org/~dwallach/2004/08/canon_e18_error_repair_instruc.html
Mar 07, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Zoom
IT WONT...DIGITAL ZOOM IS IMPOSIBLE TO TAKE OFF I YOU DONT HAVE OPTICAL ZOOM
Feb 21, 2008 | Canon PowerShot S3 IS Digital Camera
Canon PowerShot S3 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
