Question about Philips 23PF5320 23 in. HD-Ready LCD Television
Snowy picture on certain channels and only sometimes
Recently the Comcast cable had a problem with service and the cable kept going on and off ever since then certain channels have been really snowy/fuzzy and other channels somewhat fuzzy, could it be a problem with the TV now or could it be the actual cable , it used to never be snowy/fuzzy, is there any settings we can check on the tv
    Sergeant:
    Champion:
  • 326 Answers
Hello, the best option for you is to put another (small) TV instead of plasma to check whether your cable is OK. If you need more info please advice. Arpi
Posted on Apr 26, 2007
I just bought the tv, hooked it up to my new cable box using HDMI cable. i get some picture and sound on some channels but no HD channels at all
Try to go under the setting with the cable box and see if it has a switch to choose HD channels first. What cable companie do you have?? It could be possible that you will need to call to get HD service.
Sometimes the HD channels tend to be be late in the programming guide(I have comcast of Virginia and most channels are 700+)
send me a message in the comments and I can help further
Hope I could help!
Mar 18, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Am i getting hdtv with just cable feed?
Depending on your cable provider, some of the HD channels may be present. If so, these are ususally located in the upper channel numbers. It sounds like you are receiving some of the HD lineup. A cable box will probably allow you to view more HD channels including the premium HD channels if you subscribe to them. You should not be noticing a delay with the HD channels only. If this is what you are experiencing without a cable box, then it would be an issue with the HD tuner built into your TV set. LG customer service can let you know if there are any software updates available for yourmodel that can resolve this. Additionally, if you are getting your sound from an Home Theater system then you will notice an echo if using the TV's built in speakers at the same time. This is sometimes mistaken as an audio delay. If you are using a home theater system, be sure to disable the speakers that are built into your system.
Jan 04, 2009 | LG 37LG30 37 in. LCD HDTV
Snowy picture on VCR with only certain channels
In all likelyhood, you have a bad ground somewhere in the cable. Try other channels through the VCR. If the ground is the problem, there will be a cluster of channels that are snowy with the rest being clear. Check the cable itself and all of the connectors along it.
If the cable and connectors are good, the tuner or power supply of the VCR could be faulty and cause this as well.
Dan
Dec 24, 2008 | Sony SLV-N50 VHS VCR
Snowy picture
Usually a snowy picture means that you have a bad ground connection. You should see that some channels are beter than others. Verify that the cable connection is good. Try a different cable if you can. If that has no effect, than we need to start looking at the tuner itself. If you can change channels but just have a poor picture, chances are that a resolder of the tuner section will resolve the problem.
Keep us posted.
Dan
Jul 29, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Snowy picture
.u need to replace the tuner of ur tv set...its a technical work better call service technician
Jun 28, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
I recently install a cable line for my lxi tv and installed a vcr/dvd player. Now, I have no picture or a few channels are snowy. I do not have a remote and must use the hard buttons. I did notice that...
Hi Chara77,
There maybe a couple issues that could be causing your problems.
a) Check your cable lines to make sure there are no cable breaks, or loose connectors. Tightening down connectors will sometimes assist with that as well.
b) Depending on how you change the channels there maybe an issue with the television not receiving the full signal from the vcr/dvd player and you may need to change channels only from it.
P.S. SAP stands or "Second Audio Programing" it usually allows secondary audio tracks such as bilingual programing. It should not affect your picture.
Cordially
Jon
Go Ahead. Use Us.
Apr 21, 2008 | Televison & Video
1996 RCA Color TV model G27720tn
If you are on cable, first run the cable wire from the wall directly to the TV, eliminating any cable box and/or VCR. If channel 2 is snowy but the rest (especially 3-6) are clear, it is most certainly a cable problem and not a TV problem. The TV uses the exact same circuits for channel 2 to 6 (VHF-LOW) so if the tuner was bad and 2 was snowy, 3, 4, 5 and 6 would be snowy too. Bring a second TV into that room, disconnect the cable wire from the RCA and connect it to the second TV. Is channel 2 on the second TV as snowy as it was on the RCA?
Aug 18, 2007 | RCA 24V511T 24" TV
Intermittent snowy pictures under Channel 51
Probably needs a new tuner or something associated with the tuner.
May 31, 2007 | RCA F36673ET 36" TV
Snowy Picture
You could have a bad spitter or a fitting could have come loose.First thing to do is to take another TV set right next to the bad TV set and plug in the cable to the other TV set to see if the same issue happens. If it does there is a cable issue. If it does not have a snowy picture, then you should call the store where you purchaced the set for exchange or service. Good Luck
Mar 16, 2007 | Philips 23PF5320 23 in. HD-Ready LCD...
Philips 23PF5320 23 in. HD-Ready LCD Television Logo
173 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
