Question about Panasonic PT-52LCX65 44" HDTV
My pt-52lcx35 has a red dot and a green dot on it what's wrong?
  • jorolston Dec 15, 2008
    Samething
  • macbirddog69 Jan 26, 2009
    I have the same problem with a PT-52LCX65 - A red circle in the top right hand corner of the display - Is this a bulb issue???
The spots will continue to multiply. I had to go through several people at the panasonic customer service center, but they finally admitted that it was an issue that they were aware of and were covering - they sent a technician out who hooked up a device to the back of the tv and the spots went away after about 10 minutes. No charge, and tv works good as new.
Posted on Feb 18, 2009
  • 3 Answers
You need to have the TV re-calibrated.
Posted on Feb 13, 2009
Where is the air filter located on panasonic tv PT-52LCX35
Download the manual. It should tell you there. You may need to locate the Repair and maintenance manual, not the user manual (and surely not the quick guide)
Oct 24, 2015 | Panasonic PT-52LCX35
AFTER REPLACING THE LAMP, I HAD TO PUT THE COVER ON AND NOW THE SCREEN HAS TINY BLUE DOTS AND THE POWER LIGHT STAYS GREEN. THE LAMP LIGH IS NOW ON AND RED
The blue dots are due to a failing optic block. The lamp is only making them show up more obviously. The TV is probably failing as the blue dots will get larger and eventually take over the screen.
Sep 12, 2015 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic pt 52lcx35
We recommend that you test other inputs and devices on the TV to see if the lines appear only on 1 device or type of cable connection.
Keywords: thin, red, pink, line, lines, bars, bar, vertical, up, down
Oct 22, 2013 | Televison & Video
Tv is pink
YOUR TV HAS A CORRUPTER MICRO CONTROLER
YOU MUST GO TO A SERVICE CENTER THE SERVICE CENTER WITH A SPECIAL TOOL THATS AVAILABLE BY PANASONIC WILL REPROGRAMME YOUR EEPROM THIS SHOULD NOT COST MORE THAN 100 DOLLARS IT IS NOT NECESSARY TO OPEN TV
Jun 12, 2010 | Panasonic PT-52LCX65 44" HDTV
I have a pt-52lcx35 and there are lines of either green or orange that appear and move about in various locations on my screen
Jan 22, 2010 | Panasonic PT-52LCX65 44" HDTV
My 52" PANASONIC PT-52LCX35 does not come on after a power surge went off due to lightning. I press the Power Button to turn TV on, but green light just blinks a few times then stop without any sign of...
Remove the Lamp and look for a white fog inside. It is bad if it looks that way.
If thats not it, Call a good TV Tech to troubleshoot the problem. Lightning can do about anything to electronics.
Jul 29, 2009 | Panasonic PT-52LCX66 Projection Television
Repair on problem blue dot
Good Day, flavrlen;
This is your fix it is not costly and if you handle a screwdriver you can do this in 30 minutes:
PANASONIC:
MODELS: PT-44LCX65, PT52LCX15, PT-52LCX65, PT-52LCX35, PT-61LCX65,
PT-61LCX35.
SYMPTOMS: 1. FUZZY SPOTS
2. FUZZY SPOTS
3. FUZZY SPOTS WITH STAINS
4. FUZZY SPOTS & UPSIDE DOWN
5. FUZZY SPOTS WITH LINES
CORRECTION: SYMPTOMS CAN BE CORRECTED BY EEPROM
CORRECTION TOOL; (LSUQ0100).
Good Luck, big IRISH.
Jul 09, 2008 | Panasonic PT-52LCX65 44" HDTV
Red, purple and green dot
Its the light engine. Had a tehnician come and look at mine and was told it would have cost over $600 if I didnt have the warranty. Panasonic called 2 weeks later and told me that parts are no longer available for my model and are upgrading me to a 50 inch tv.(from 44 inch)
Nov 29, 2007 | Panasonic PT-52LCX65 44" HDTV
Dots on screen
you have to get a repair guy to come out. When this happened to me the guy changed the bulb (which didn't work) and the actual internal projector (which did work). But he had also said there was a software fix for this problem that is considerably cheaper.
Nov 29, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-52LCX65 44" HDTV Logo
347 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
