Question about GE 29878GE1 Digital Answering Machine
How do I change the outgoing message?
I cannot change the outgoing message. Help
  • 1 more comment
  • Anonymous Jan 21, 2009
    I have lost the manual for this answering machine and do not know how to change the date & time or the outgoing message. please help!
  • Anonymous Feb 16, 2009
    I just need to change my outgoing message, but I have no idea how to do that. Help!?!?
  • manishchandr Apr 13, 2009
    the outlook2007 the outgoing message does not send i want to solve this this problem
How do I change message
Posted on Dec 15, 2008
How do I change my outgoing voicemail message?
Depending on your wireless service provider, the method for changing your voice mail greeting or voice mail password might differ. You should be able to access the options for changing your voice mail greeting or voice mail password when you check your voice mail. For more information, contact your wireless service provider.
Oct 02, 2014 | RIM BLACKBERRY TORCH 9800 TOUCH SCREEN...
Tip
Remote access for machine
This come from a previous model than I have (mine is a ol5870), but seems to work for this one in retrieving messages from another phone.
Default access code is 0000 if you haven't changed it (but you should); when answering machine answer dial in the 4 digit code while the outgoing message is playing.
Once in dial 1,2, or 3 to play messages (mail box number I believe)
You can dial * for a help menu
4 Repeat a message
44 Ignores a message (message won't remote retrieve next call)
6 plays next message (skip to next)
7 Deletes message
8 Lets you record a memo
9 Let's you change the outgoing message (5 stops the recording)
0 Toggles answer on/off
I hope this helps some people at least in part.
on Feb 14, 2009 | Olympia OL5870 Digital Answering Machine
Change outgoing message
Usually, the voicemail message is stored in the voicemail system, which is handset-independent. Call in to your voicemail (usually hold down the 1 key or look for the key with the envelope and hold it down - it will dial your voicemail account) and follow the prompts to set up your mailbox, and "change your greeting."
Dec 11, 2013 | Motorola Cell Phones
All outgoing emails are not being sent-- It comes back and says--- the message could not be sent because the server rejected the senders email address. Server : outgoing.yahoo.verizon.net is correct. ...
Try using ....outgoing.verizon.net.....and port 587 instead of 25(default).
From the "Tools" menu, select "Accounts."
Select your Yahoo! POP account and click the "Properties" button.
Click the "Advanced" tab.
Next to "Outgoing server (SMTP)," change port 25 to 587.
Click "Apply." Then click "OK" and "Close."
Hope this helps.
If this helps you resolve your problem, please
consider giving a good rating and a quick thanks
or good job.It will help me as well Thank you.
Oct 24, 2010 | Computers & Internet
I need to change the outgoing message on the main line. I can change the personal greeting, but I cannot find instructions regarding changing the main line's outgoing message
For Partner Voice Messaging....
Dial into voicemail. WHen prompted for the mailbox number
Enter 0 #
Pswd the default is 1234 followed by #
Option 3 is the record Automated Attendant menu prompt
the rest is self explanatory.
Nov 19, 2009 | Avaya Lucent Partner 616 Phone
Will outgoing message be erased when battery is changed?
it depends on the model u r using genrally they don't
bt i wud advise you to call up the company helpline for help
Sep 04, 2009 | Lands Phones
WE NEED TO CHANGE OUTGOING MESSAGE ON WORK PHONE DTU-16 NEC
voice mail procedure manual can be downloaded at www.natgtelecom.com/elitemailug.pdf
Jun 15, 2009 | NEC DTU 16-1 Corded Phone
Nseed to reset message on answering machine
There are two models - The TRU8885 and the TRU8885-2 -
For the TRU8885 the manual PDF form >>>Click Here<<<
The solution is on page 24 + 57 It starts on Pg 24 as...
Record Greeting allows you to record a personal outgoing message (greeting) which
the answering system automatically plays when you receive a call.
1) Enter the Answring Setup menu, and then the
Record Greeting sub-menu (see "Entering the
Menu" on page 16). To record greeting press
[STA RT] appears.
2) Press the START soft key. You will hear “Record Greeting.“ The message counter
displays 30 and then begins to count down.
3) Position yourself near the base microphone and record your greeting.
4) When you are finished recording, press the STOP soft key. Your greeting will
playback for confirmation.
Selecting Your Greeting (Base only)
Select Greeting allows you to choose between the two outgoing messages, a prerecorded
message or your own greeting.
1) Enter the Answ. Setup menu, and then the
Select Greeting submenu (see "Entering the
Menu” on page 16). P lay back greetin g
appears, and the current outgoing message is
played. LCD is an example if you recorded your greeting.
2) Once you have recorded a personal greeting, press the CHANGE soft key to
choose the greeting. The selected outgoing message is played. Each time you
press the CHANGE soft key, the phone switches the outgoing message between
the prerecorded and the personal outgoing message.
There is more on the PDF - Just ask if you need more
For the TRU8885-2 is essentially the same. The manual PDF form >>>Click Here<<<
If we need to dig further, just ask! :) We are just a mouse click away!
Thanks
Len
Mar 07, 2009 | Uniden TRU8885 Digital Answering Machine
Outgoing message
dont have amanual for the phones
Jan 02, 2009 | GE 25932 Cordless Phone
GE 29878GE1 Digital Answering Machine Logo
309 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
