Question about Sewing Machines
Friend lent me machine but no book. Need help threading Pfaff
Not sure where thread should go before it goes through needle
  • Sewing Machines Master
  • 1,388 Answers
Try sewusa.com site for help on threading a bewildering number of machines.
You have not specified make or model, so cannot be of more help I'm afraid.
Posted on Dec 15, 2008
Thread shred. Pfaff 463. Using 120/19 new needle. And Sunguard Anti-wick UVR bonded polyester thread for marine canvas. Why is my thread shredding?
From my past sewing experience (not an industrial machine), the thread will shred if the needle/thread/fabric are incompatible. Could be the canvas is too coarse and is wearing on the thread like sandpaper. Remember, the thread/needle will penetrate over 10 times before that section of thread actually forms a stitch, so that's a lot of friction going on. In regular sewing, a top-stitch needle has a larger scarf which acts to protect the thread, however, not sure that is a choice for your machine.
http://www.upholster.com/upholstery-forum/index.php?topic=11340.0;wap2
Is Pfaff 463 Suitable For Upholstery
Pfaff 463 Instruction Book
May 19, 2017 | PfaFF Sewing Machines
How to remove thread that has wound itself around the back of the bobbin case on a Pfaff tipmatic 1035. Is it possible to remove the top plate to get access?
Remove the bobbin case. If the machine has a free-arm cover, it should be removed also. On most older machines, there are multiple needle plates (zig-zag or straight-stitch) available so they are removable & exchangeable, but for your machine, you'd have to verify. You'll have to carefully remove the threads by cutting with a tiny pair of scissors and pulling the threads using needle-nose pliers or tweezers. If you are unable to remove all the threads, you may need to take it for service.
PFAFF Tipmatic 1014 Instruction Book Page 11
PFAFF Tipmatic 1035 Manuals
Pfaff Tipmatic 1035 Owner Manual Page 2
Dec 20, 2016 | Sewing Machines
I have a pfaff 2040 and when the needle goes down to pick up the bobbin thread the main thread wraps around the bobbin housing and jams. Doesnt grab the bobbin thread. How can I fix this?
Be sure to use a brand new needle because a bent needle could miss the bobbin thread.
Search the internet for sites and videos relating to sewing machine timing or take it for service.
Dec 02, 2016 | PfaFF Tiptronic 2040
How can I factory reset my PFAFF 7550 sewing machine ?
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Feb 28, 2013 | PfaFF Creative 7570
I have a PFAFF 207, with the same problem as above (top thread keeps breaking) but if I lower the tension, the bottom stitch becomes loose???
replace the needle-make sure the needle is inserted correctly
top thread tension 3 or 4
rethread the machine
some needles will not work with some thread-here's a tip
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 16, 2010 | PfaFF Sewing Machines
I have had my PfaFF sewing machine for close to 5 years now, but lent it to my friend about 2 years ago and just recently my machine was returned to me. Just this Halloween, I was trying to sew my...
Look in your instruction book, towards the back of the book where it covers oiling the sewing hook. Oil the hook and then turn the handwheel backwards until it frees up. You may need to exert a moderate amount of force to get it to break free.
Nov 02, 2010 | PfaFF Sewing Machines
Pfaff 260 bobbin thread not picking up
Hi. This can be terribly frustrating, but the most likely cause for the bobbin thread not catching is that the needle is inserted wrong. There is a flat side on the shank of every needle and that has to be facing a specific way on your machine or the needle's grooves can't make the stitch. On most modern machines, it's my experience that the flat side goes to the rear, facing away from the operator, but some of my older machines need the flat side facing to the left or to the right.
Another thing that can cause the bobbin thread not to pick up is a bent needle, but in my experience it's usually the needle not in correctly.
(Cost me $85.00 to find this out!)
Let me know if this works, ok?
Happy Sewing!
Robbie
Apr 01, 2010 | PfaFF Sewing Machines
The threaded needle will not pick up the bobbin thread. It seemed to be in perfect shape when last I used the machine, a Pfaff Tiptronic, but now, suddenly, it will now work. The threading of the bobbin...
Hi, here is a few suggestion...........
A few suggestions:
  1. Re-thread top of machine from scratch with the presser foot raised, i.e. remove thread completely from all thread guides & paths and start from scratch, making sure thread is securely seated between tension disks. Once the needle is re-threaded, lower the presser foot and give the tail end of the thread a tug to make sure there's tension on it.
  2. Make sure the bobbin is turning the correct direction for your machine - and that the thread tail is under the tension plate or bobbin tension guide (depending on machine).
  3. Blow out any fuzz.
  4. Insert a new needle, making sure needle is pushed all the way up.
  5. Oil machine (in locations recommended in your owner's manual).
If the basic cleaning and re-threading (above) don't help, your machine(s) may be out of time or have another mechanical issue that will require a repair technician. We recommend a tech trained on your specific brands - they'll be better trained and able to get any repair parts that may be needed.
Take care
Feb 21, 2010 | PfaFF Sewing Machines
Needle will not pick up thread from bobbin
Was the old needle picking up the bobbin thread ok? If it was, then there's nothing wrong with the machine. Check that the needle is inserted correctly--there's a flat side on the shank of the needle and where that goes varies widely by machine. Then check that it's threaded properly.
(I once had my needle in backwards and threaded wrong--took the machine to the shop cause I was sure my baby was broken. Cost me $85.00 to find out that on that particular machine the flat side of the needle faces left!)
Let me know if this helps!
Robbie
Jan 24, 2010 | PfaFF Sewing Machines
Pfaff 786 cannot get the second needle to form a stitch
Sorry to say I had the same prob and finally gave up on using 2 needles and 4 threads. Other than that I love the machine but will be replacing it soon due to inability to find replacement parts as it is sooo old. :(
Dec 27, 2008 | PfaFF Hobby 4260
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
