Question about Refrigerators
My fridge functions normally, but when the motor shuts down, sometimes (1/2) it makes a loud "knock" when it stops. What is the problem and how can I fix it
  • 85 Answers
The support spring that hold the motor in place inside of compressor has failed so when the compressor stops the motor bangs off the inside of the steel shell of the compressor. the only resolution is to have the compressor replaced
Posted on Dec 15, 2008
My fridge knocks when running
Your fridge's compressor motor is suspended inside the compressor housing on three or four springs. These springs are designed to hold the motor load in a vertical position. Transporting a fridge on it's side can stretch or break these springs which can cause a shudder stop condition (the fridge makes a shuddering banging noise everytime the compressor stops and sometimes when it starts).
It's a good idea to let a fridge sit for a bit anytime it is moved. Over night won't hurt but an 8-10 hours is more than enough time some say less.
the internet consensus seems to be that you should limit the amount of time the unit is not upright. And as stated above, leave it upright at least overnight before starting it. Apparently damage can arise from mixing of lubricant and coolant, so damage is more likely in an older unit with worn seals.
Apr 11, 2015 | Hotpoint HSS25GFP Side by Side...
Loud knocking noise engine
Air inlet or outlet may be clogged, check air filter and catalytic converter, as possibles!
Jan 17, 2014 | Chevrolet Malibu Cars & Trucks
How do I stop the loud knocking noises coming from my refridgerator?
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
Feb 05, 2012 | Kenmore Refrigerators
My fridge is making a very loud noise coming from the rear and bottom of box.we have already shut it off for four hours it stopped making noise for a couple of weeks,but now started again,we shut it down...
THERE IS A FAN IN THE BACK OF THE FRIDGE , INSULATION GETS LOSE AND HITS THE FAN. REMOVE THE LOSE ISOLATION OR WHATEVER IS HITTING THE FAN.. I THINK THIS IS THE PROBLEM..JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jun 27, 2011 | LG Refrigerators
Kenmore Coldspot 69182990 - knocking noise
check te rubber mounts at the bottom of the compressor
the rubber rots after some time and the compressor moves on shutting down as the knocking could be that noise
May 20, 2017 | Kenmore Refrigerators
Whirlpool Gold Refrigerator Buzzing sound when motor is on
some thing could be toching the fan at the back of the fridge or freeze fan making noise
Apr 02, 2009 | Refrigerators
Knocking/banging sound on compressor start up
Check the compressor mounts. They are usually springs mounted with rubber. If they are two loose the compessor wil hit some other metal part when starting up. Shakle it and see what it is hitting. Ajust accordingly.
Dec 27, 2008 | Refrigerators
Compressor makes a loud grumble an vibrates when it shuts off
There are springs inside the compressor that suspend the motor. When one or more of those springs break then the motor will knock against the casing when it shuts down and loses centrifuge motion. The compressor will continue to run up until the point the it beats itself to death, which could be next week of next year. There's no way to tell. The only solution is to replace the compressor.
Oct 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
I have a GE ZIS480D - side by side with compressor on top. It had an even tempo knockng sound coming from comprssor area. I asked my repair guy (at his shop) wat it could be. He shruggs and says "dont know, I'll have to come out and see it for $65." Just give me an idea of what it might be. He says "could be the timer or the motor knocking on something. I'll have to come out and take a look".. I'm a very highend custom homebuilder and have built hundreds of homes with every possible issue imaginable. When a repair guy says "dont know need to see it" it means I have no idea but by the time I leae your house I'll come up wih something. When something doesn't make mechanical sense I just pound on it or give it a good smack. I do it with my truck, my computer, my doors that stick and even sometimes my wife (kidding about the wife, she'd take me out in a heartbeat. Anway, I got up in the compressor ares and smacked it a couple times from every direction and sure enough it stopped knocking. I have been called a genius before but all I do is force into submission and it works. A good smack with the palm of your hand will not hurt the unit. Give it a shot
Mar 19, 2007 | KitchenAid KBFA25ER Bottom Freezer French...
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
