Question about Nintendo NES Console
When I put a game into my Nintendo (riginal), the screen on the tv just stays black. I have taken it apart completely and changed the 72 pin and it still does the same thing. Is there any way it could be a bad connection?
    Problem Solver:
  • 8 Answers
It was probably on the wrong channel or bad connection... but if you took it apart you could have damaged it further... so good luck...
Posted on Dec 15, 2008
I have 2 Nintendo NES systems. One I thought didn't work and needed the 72 pin piece changed, but when I turned it on the other day, it sort of worked. The people in the games came up with letters and...
Secret trick: take NES cartridge, press cartridge down and waggle the cartridge inside the NES and then hold the NES down and shove the cartridge onto the pins. An alternate solution is to take a Q tip, dip it in rubbing alcohol and clean out all the dust inside your game.
Mar 23, 2015 | Nintendo NES Console
Nes pink screen no blinking power light
Try cleaning the game packs out with autopsy and rubbing alcohol to see if it helps
Apr 04, 2013 | Nintendo NES Console
The red light flashes on my NES and on the TV screen, it keeps on changing colors. Do you know whats wrong?
The NES is touchy like that, sadly-- your problem isn't uncommon. My NES, and the NES of nearly every friend I have who still owns one, plays this little trick on them from time to time. Here's what we do:
1. Turn off the NES console.
2. Blow into bottom of the game, near the chip that connects to the NES.
3. Wipe away any excess dust from the game itself.
4. Blow into the console of the NES.
5. Wipe away any excess dust.
6. Re-insert the game and try again.
If this doesn't work, try placing the game in more delicately, or with more force. It's just a matter of trial and error, and sometimes it will work faster than others. Hope this helped!
Mar 12, 2011 | Nintendo NES Console
Nes wonnt turn on, but when it does red light is flashing
Did you replace the 72 pin connector while it was apart? This is the number 1 reason for NES to fail to load or flash. A brief search of "72 pin connector" on eBay should net you a new connector for about $5 US.
If you have already done this, and the problem is really bad then recheck your work and make sure everything is connected tight.
Also consider that allot of nes games were not taken care of very well, so if the problem is specific to a couple cartridges, consider cleaning them as they are probably not connecting well.
Good luck.
Apr 02, 2010 | Nintendo Super NES Console
Hi, I was wondering...how do you fix a NES which has been blinking? Like the screen flashing and restarting the game?
Replace the connector, these wear out over time. Here is a place I found thru Amazon that sells them:
http://www.amazon.com/New-Nintendo-72-pin-Connector-Guarantee-DS/dp/B000A3IA0Y
It will require you to take apart the system and to take out the old connector and replace it with the new one and then put the system back together and it will be like you have a whole new NES again.
Jan 23, 2010 | Nintendo Video Game Consoles & Games
Nes flashing black and white and making a horrible sound
a 'front load' nes ALWAYS does this, even if the connector pins inside the console are new. the cartriges on a Front Load nes rarely completely seat, as Nintendo redesigned the Famicom very poorly for the US market. try this 1. put the cart in as usual, but hold it all the way down 2. slip an unwanted/extra cart in on top of the metal hoop above the cart your using. this gives a better contact for the cart. try cleaning the cartrige pins as well. some won't read right if there's ANYTHING on the pins.
Dec 03, 2008 | Nintendo NES Console
Please help! NES problem, and it's not the 72 pin connector.
It sounds like the pins on the game or the 72 pin connector in the console is dirty. Nornally the game connectors get dirty and when you put it in the console that transfers the dirt to the 72 pin connector. You need to purchase a cleaning kit from your local gamestop or other such store. Do Not Use Alcohol to clean your games or the console.
Jul 28, 2008 | Nintendo NES Console
Nintendo NES Repair
It's as simple as unscrewing the console by removing all the screws from the bottom. Once inside take off the metal piece over the area where the game is inserted. Once under there you can remove the two screws that hold the 72 pin connector in and pull it out and slip a new one in. Put it back together in reverse.
Mar 26, 2008 | Nintendo NES Console
Oringal NES
It's still not getting full contact with the game cartridge. Try cleaning the contacts on the games with a q-tip and rubbing alcohol.
Dec 01, 2007 | Nintendo NES Console
Nintendo NES Console Logo
87 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
