Question about Frigidaire FRS26H5AS Side by Side Refrigerator
"howling' noise coming from icemaker, not too load, but
Seems like the ice maker is "howling" or whooshing, in a pulsing type manner. Not overly load, but noticable. The unit makes ice and dispenses both water, cubes and crushed just fine, but the noise has been there, off and on for a few weeks ? GE side by side model # GSC23LGQB, BB
  • evikster Dec 28, 2008
    I have the same problem and have not been able to resolve. Any help is appreciated.
  • Anonymous Apr 13, 2009
    There i a fan in the back of the freezer, behind the panels. Ice forms behind the panels and falls on the fan. I have this fix down to a science, about 15 minutes. I need to find out why the ice form though. I think that I have a leak at the ice maker where the water comes in.
SOURCE: Icemaker problem crushed only not cubes
I looked at the plastic piece the solenoid was moving (from Guest's comment 03/07/08). Pushed the plastic piece up (had to push pretty hard) and it reset the solenoid to its' start/beginning position(-?) Plastic piece came back to lower position - was free to move up and down. The solenoid is working now (hear the loud clicking and see it pulling the plastic piece up) to get cubed ice, instead of putting it thru the crusher.
Posted on Mar 15, 2008
SOURCE: icemaker only dispenses crushed ice, not cubes
yea! I have been without cubes for 2 years. I slid out the tray, found the lever in the back where the rod went in, pulled it down, reinserted the ice tray, and IT WORKED! At first I thought I broke the lever, because I had to hold it down with a knife while I was inserting the tray, but it just must have been stuck. I am soooo happy!
Posted on Aug 10, 2008
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
  • 65 Answers
SOURCE: Ice Maker Issues-only crushed ice works, cubed comes out crushed
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
Posted on Jan 27, 2009
  • 296 Answers
SOURCE: Ice maker only makes crushed ice, no cubes
chek these sites
There is an opening next to the auger that dispenses the ice. In there there is a lever that must move up and down. It actually seats the metal rod on the bottom of the ice maker and controls cube or crushed. Make sure the lever is down (cube position) when you return the basket to the freezer. I had to hold it down while I slid the rod into the opening. Cubes again.
if satisfied plz rate this answer
all the best
Posted on May 27, 2009
Why is icemaker making a clicking sound?
Ice Maker Not Dispensing Ice ' ThriftyFun
Sometimes your refrigerator ice maker makes ice, but does not dispense it. ... If it gets pushed all the way back to the ice maker it prevents the metal arm from full ... Itry not to put anything on the shelf over the bin and also try to keep it pulled out just a little ... My ice maker is making a clicking noise and not making much ice.
Ice maker making ice, but won't come out thru door
If when you attempt to dispense ice (and it doesn't work) the whole refrigerator seems to .... Many have just bought a new refridgerator or don't use the ice dispenser. ... I'vetried to decrease the cold in it from the dial and that doesn't help. ... The motor was working and the auger would turn with no ice in bin but the added ...
Dec 25, 2015 | Samsung RH29H9000SR RH29H9000SR 29 cu. ft....
Amana French Door Bottom Freezer Refrigerator making noise but not making ice
hello sir
if ur ice maker
Makes no ice
Jul 08, 2008 | Amana AFD2535DES French Door Refrigerator
The ice maker is still working but has constant noise.
Thanks for your post, friend!
I see that you are experiencing some challenges with your Frigidaire refrigerator making a constant noise. Typically, you can have noises coming from your icemaker and they would be a normal operating sound. If it is a snap or click it could be the water valve calling for water. Additionally, the icemaker dropping ice into the bin can provide a loud noise as well. If you have your manual it lists normal operating noises. If you feel the noise is not normal I would recommend reaching out to a professional for proper diagnosis and repair. I hope this is helpful. -Matt
Sep 24, 2014 | Frigidaire Refrigerators
Howling noise
Check the help link mentioned below:---
Click the link:--
Ice maker is noisy and not making ice?
These will help.
Nov 21, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
My Kenmore refrigerator (596.52673200) is making a noise every 3 minutes or so for about 15 seconds. It seems like it is trying to fill the ice maker. There was ice in the little rubber tube leading to the...
Put the icemaker arm in the lock position to turn it off.
If it is the icemaker making the noise, the noise should stop.
If the noise stops,replace the icemaker.
If it does not stop,let us know.
Sep 22, 2010 | Refrigerators
I have a Uline model SP18 ice maker.Recently the ice maker continues to cycle,Filling with water and at the point when it should stop the compresor turns on then off as it continues to turn,starting the...
It does sound as if you may need a new ice maker. Other than that does the compressor come on to keep the ice cold? If so is it making any type of noises beyond the typical hum?
Jun 10, 2017 | U-Line Icemaker
GE GSL25JFR Freezer fan noise.
Replace the fan motor is my guess to cure the noise.
Mar 01, 2017 | GE Profile¿ 42" Built-In Side-by-Side...
Howling noise
I don't see anything located directly behind the icemaker on this model. Try to better isolate the location of noise if you can. If the icemaker is at fault, I wouldn't bother trying to repair. Order another one. One other thing to check is the water flow. When the noise happens again, stick your finger in the ice mold and feel for water. If it just filled, then problem may be in the water valve. Hope this helps,
Oct 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
I also had the same problem (gsh25jfta ww). It did that for a couple of months now the coils freeze up and fridge gets warm. Still looking for solution?
Jul 03, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Frozen ejector arm
sounds more like the heater in the ice maker is bad. The cycles of the ice maker are: 1. water comes in to fill ice maker. 2. water freezes in ice maker making. 3. heater comes on to help ice release. 4. motor comes on to eject the ice and start all over again. if the heater doesn't come on the ice will not eject. replacing the icemaker is typically what needs to be done in this case.
May 02, 2007 | KitchenAid Superba Architect KSCS25INSS...
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
107 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
