Question about RCA P52960 52" Rear Projection Television
Rca 52" p52960 convergence bows
The convergence bows at all sides is there an easy fix or do i need to replace modual and if so what does it look like
  • fixit2man Mar 03, 2008
    nO DIGITAL CONVERGENCE, IT HAS TO BE THE SUPPLY, REPLACED THE STK 730-130, worked for 30 minutes, possibly the +13 volts from the digital board is weak, I'll replace chip again and check other possibilities, wish I get the kit, rCA made a late production where they added an fet and a regulator to replace the Big IC, actually the 250688 is the old, and the 250686 is the late model, I purchased the CD for service, if all else fails and I can get the parts, I will try to adapt the old supply to the new specs....RJ
    Genius:
  • 1,694 Answers
Check power supply voltages that run convergence circuit.(small PCB mounted above main PCB's with Stk 730-020 on it ???) Note:Free estimates are usually worth the same amount you paid.....An accurate diagnosis by a senior tech is usually worth it,esp.if your intention is to repair and the diagnosis fee applies to the repair cost.
Posted on Oct 08, 2007
    Sergeant:
  • 308 Answers
I wish it was that simple. On this chassis there are many parts that have gone bad in the past to cause this very symptom. So many in fact that there is a repair kit available that contains common failure parts p/n 250686-KIT. This is NOT a DIY project as many of the parts are small and would be hard to locate and impossible to replace by anyone not having superior soldering skills. It would not surprise me if the repair on this set would set you back about $350. If you can get a free estimate, great, but if you can swing it, you may be better off putting that money towards a new DLP rear projection NON RCA HDTV. I have had good luck with Toshiba sets for the last several years, and Consumer Reports seem to agree with me.
Posted on Apr 12, 2007
I was given a P52960 ,2002 rca 52 projection tv and the sides of the piture are concaved in.Can this be fixed easy enough,i am good with electronics/wireing..iI was told by the old owner that the solu
concave or bloated pictures on crt projection tv's are corrected with what's called a 'pincushion' adjustment. Look for it in the menu under video controls.
Dec 22, 2012 | RCA P52960 52" Rear Projection Television
My RCA P52960 52in. rear projection tv has what looks like a slight Fisheye lense look to it,the center being perfectly fine but all around the edges is a slightly blurry and can see all three...
We calling convergence problem.
Re solder fly back terminal ( transformer)
Replace pico fuse 400mA(little red box fuse) beside fly back.
Go to set up, convergence, select auto convergence and your TV will work perfect.
I will be here for any future question.
Thank you for visit fix ya.
Aug 04, 2011 | RCA P52960 52" Rear Projection Television
My screen has a slight bow shape
its probably convergence -
here is my tutorial
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
rca hint at the bottom.. it probably needs a convergence power board, easy install.. 4 screws and 2 plugs(wires)
Jun 18, 2010 | RCA P52960 52" Rear Projection Television
Could use some help with a "bowed" picture on my RCA P52960
Is the convcergence ( Alignment) also off which gives the TV a 3D look around items on the screen? If so replace the STK730-130 on the convergence power supply
Jun 23, 2009 | RCA P52960 52" Rear Projection Television
Replacement STK numbers for convergence amps
This unit does not use the STK series convergence amps.The convergence power supply is what you need.I will provide that number for you after while.
Jan 19, 2009 | RCA P52960 52" Rear Projection Television
RCA P52960 Problem (bowed picture)
Normally this is either bad connections on the convergence ICs or defective ICs. If you can solder, you should be able to fix this. First locate the convergence ICs: large black ICs attached to a heat sink that shouldbe marked STKxxx. Try resoldering the pins on these ICs first. If that fails, replace the ICs.
Keep me posted.
Dan
Nov 20, 2008 | RCA P52960 52" Rear Projection Television
Rca 52 inch convergence
You have a opened fuse FL231 next to flyback transfomer are 3 Fuses they look like small brown squares/ Fuse in the middle is bad when you do not have convergence listed in menu.You can pull the top off of these fuses .
Nov 06, 2008 | RCA P52960 52" Rear Projection Television
Bowed picture with RCA p52960
This is a convergence problem and can be either bad connections at the convergence ICs or defective ICs. Try resoldering the pins first. If that fails, replace the ICs. These ICs are large, black and attached to a heatsink. It should be marked STKxxx.
Keep me posted.
Dan
Oct 24, 2008 | RCA P52960 52" Rear Projection Television
Bowed Picture
This is a convergence problem. If you can solder, you should be able to repair this yourself. Please update this to confirm the model as P52960 and whether or not you wish to attempt the repair and I will supply additional details and instructions.
Dan
Oct 06, 2008 | RCA P52960 52" Rear Projection Television
RCA P52960 52" Rear Projection Television Logo
580 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
