Question about Dell U0636 Mouse
I have a dell 4700 computor with a wired mouse. Does it have a battery and if so how do I replace it?
  • bigggmike00 May 11, 2010
    If Its wired It more than likely has no battery. Is it a scroll "Ball" Or optical "Red Light"?
    whats the problem u are having?
    -Mike
  • 26 Answers
Hi
almost all of muses work with battrey power.to change the battrey you need to go back to manual book and see the instructions how to instal or uninstal the battrey. becouse mjarety of mouses are difrent then the other one.but as a genral ,either they have slider to open them or have battrey door with scrows.
Posted on Dec 15, 2008
MOuse batteries wired incorrectly
Mcyman,
Can you please provide more information on your post about the mouse batteries being wired incorrectly? I can then look into the issue.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 29, 2016 | Dell M787C Wireless Mouse P/N: M787C -...
Tip
Dell wireless mouse M787C batteries are wired in Parallel not in series...
Hello All, I just received a Dell All in One Computer with the M787c wireless mouse. I installed 2 fresh batteries and noticed after 3-4 minutes one of the batteries was getting warm? I removed that battery and the mouse LED light was still working. SO the M787c mouse was working as it should with only ONE Battery!
I checked wiring of the batteries and found that the Batteries were WIRED in Parallel. Wiring batteries in parallel is not a very good Electrical practice, at all!
I am sure that many owners of this mouse have gone through many batteries because of the miss wiring.
If you mouse does not work with properly with one battery if you are mechanically inclined you can disassemble the Mouse and rewire the batteries in SERIES.
There are 4 screws on the bottom of the mouse, 2 in the bottom underneath the front gliders, and 2 in the top. Happy fixing. Rob
on Feb 29, 2016 | Dell M787C Wireless Mouse P/N: M787C -...
Reset bios dell 4700
Turn off and unplug, Remove CMOS battery for 15 minutes replace and restart.
If this does not work try the setting jumpers on m/b method (you will have to look this up)
21.June.2015
Apr 21, 2014 | Dell Dimension 4700 PC Desktop
I have a dell computer. when i turn on the tower and monitor i get just a black screen on the monitor. i have pushed a few buttons on the bottom of the screen and it just says power save mode please use...
No, it's the Power Supply.
Power Supply has a weak voltage power rail.
The monitor goes to Power Saver mode because it is not receiving a video signal. (No Signal)
This is because the computer is not working.
Dell Support > Dimension 4700 desktop computer > Service Manual,
http://support.dell.com/support/edocs/systems/dim4700/sm/index.htm
Click on the heading - Advanced Troubleshooting
Is the Power On LED light blinking Amber? (Yellow)
Post back in a Comment.
Regards,
joecoolvette
{You can also test the power coming out of the Power Supply.
The Power Supply in your computer is an SMPS.
Switched-Mode Power Supply,
http://en.wikipedia.org/wiki/Switched-mode_power_supply
It converts the AC electricity from your home, or business, into DC electricity.
There are three main voltages produced;
A) 3.3 Volts (3 point 3)
B) 5 Volts
C) 12 Volts
All are DC voltage
Two D cell flashlight batteries produce 3 Volts DC.
(In case you are worried about being shocked.
The 'bad' electricity is contained inside the Power Supply's case)
If you do not have a multimeter, an economical unit can be purchased for around $8 to $12. A LOT of stores carry them. An auto parts store is one example.
Orange wires are 3.3 Volts
Red wires are 5 Volts
Yellow wires are 12 Volts.
ALL 3.3 Volt wires end at the same 3.3 Volt power rail in the Power Supply.
Same with 5 Volt wires, and 12 Volt wires.
You can test ANY Orange wire, or any Red wire, or any Yellow wire.
ANY Black wire you see is a Ground wire.
The red probe lead of the multimeter is the Positive lead. The black probe lead is the Negative lead.
The Positive probe lead is touched to a positive wire.
Orange, Red, or Yellow.
The Negative probe lead is touched to ANY black wire. ALL black wires are a Ground wire.
The function knob on the multimeter is set to DC voltage. (Dotted line over a solid line, with a dotted line under the solid line. The curved S line over a solid line is for AC voltage. This = No)
If there are different scale settings, set the function knob to 0-50 Volts. (DC)
Aug 24, 2011 | Dell Dimension 4700 PC Desktop
Mouse skips. changed mouse three times. Still skips. Changed usb input location. Still skips. Any ideas?
try a ps2 port mouse,,if that stops it,then go into your setup and change usb settings from medium to high power,
Jun 21, 2010 | Dell Dimension 4700 PC Desktop
I start the computor and i hear 1 click but the screen clicks on for one sec then nothing eycatcher@yahoo.com
check 1. CPU utilization in BIOS and what is the CPU Temp.. using. 2. Remove Hard disk and ON the system if not restart the system than there no problem with CPU / SMPS. 3. If the system restart. 4. Check the CPU, SMPS problem.
Feb 08, 2010 | Dell Dimension 4700 PC Desktop
My dell 4700 pc does't let the mouse or keybord
Make sure the connections are OK if they are wired. If they are wireless, you may have to sync them so the device is recognized by the computer. Likewise, make sure the batteries are strong if wireless. If they are after market, you may need to install drivers for them, which should have come with them. And after all of that, right click on MY COMPUTER, go to PROPERTIES, then DEVICE MANAGER, and look for any yellow exclamation points or question marks. If there click on it and look at the properties. The drivers may be corrupt (it happens) or need to be re-installed, rolled back, or updated. If you want you can right click on the yellow marks and uninstall the device. When you re-boot, windows will re-install the device and the driver. Good luck and I hope this helps. Please vote accordingly and leave a comment.
Oct 29, 2009 | Dell Dimension 4700 PC Desktop
I need help setting up my 4700 dell desk top.
Where is the rest of your question? From this no one could help you. If you update your question I am sure that one of us could help you.
If you are looking for the manuals or drivers, click on this link
http://support.dell.com/support/topics/global.aspx/support/product_support/product_support_central?c=us&cs=19&l=en&s=dhs&~ck=mn&SystemID=DIM_P4_4700
Feb 01, 2009 | Dell Dimension 4700 PC Desktop
Dell U0636 Mouse Logo
344 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
