Question about Kenmore 35912 / 35913 Progressive Upright Vacuum
The indicator lights are not working
When I turn on my inteliclean button it does not move up to the green level no matter what. I have it raised up and it still has a red light and it should be green. The vacuum is sucking up dirt and cleaning but the lights are not working and the vacuum is not changing the level of suction so the motor is always running at high speed.
  • 1 more comment
  • phillyk48 Jan 02, 2009
    I have the same problem. My lights never go to green and the motor keeps running at high speed. I can turn it off and on, and it still does it.
  • Anonymous Jan 19, 2009
    Same problems here ..
  • Deniselynn68 Feb 02, 2009
    Same problem here.  When I got the vacuum the dirt indicator lights worked fine but last week they stopped working.  There is nothing wrong with the suction and it picks up dirt but I like having the dirt indicator light to tell me when I am picking up dirt and when it is finished picking it up.  I have two dogs and it is hard to see their fur in our dark coloured carpet.  This is one of the reasons why I got this vacuum.
    Problem Solver:
  • 6 Answers
The dirt sensor is just inside where the bag attaches. It shines a beam of invisible light across the bag discharge tube. It will always show dirty if dust gets caked on it. Try wiping the area clean. This fix did not work for me. Remove the 3 screws that hold the hose assembly to the back of the vacuum, check to see if there is a piece of hair snagged on the end of the hose. This was the case for me. When running, the hair would wave back and forth by the sensor and set it off.
Posted on Mar 07, 2009
Wow! This worked like a charm. Thanks for the info
Posted on Jun 08, 2009
What are these 2 blinking lights on my irobot roomba?
"The Charge Indicator Light is located immediately to the right of the power button on Roomba Red and Roomba (sage). On Roomba Discovery and Discovery SE, the Charge Indicator Light is incorporated into the power button. Please refer to the table below to determine what the Charge Indicator Light is telling you.
* Pulsing Amber - Charging
* Green - Fully Charged
* Amber - Partially Discharged
* Red - Almost Fully Discharged
* Flashing Red - Fully Discharged"
At the end of a cleaning mission, Roomba will tell you if it has successfully completed it's mission or not:
GREEN = MISSION COMPLETE
YELLOW = MISSION ABANDONED (Check robot's brushes, etc.)
YELLOW RED POWER BUTTON = BATTERY DEPLETED (Scheduler Models)
RED YELLOW POWER BUTTON = BATTERY DEPLETED (Discovery Models)
number of beeps after ?uh-oh? :
No beeps: A wheel is stuck or is not touching the ground. Pick up the robot, place it down securely on the floor and touch the clean button to restart the cycle.
1 beep: The main brushes cannot turn. Turn over Roomba and remove the brush guard by pushing the two yellow tabs. Remove the brushes, clear any obstructions, and replace them again.
2 beeps: The side brush cannot turn. Turn over Roomba. Look to see if something is wrapped around the side brush. Remove the side brush with a screw driver and check for string or hair that may be wrapped around it.
3 beeps: The vacuum cannot run Remove and empty Roomba?s bin.
4 beeps: A wheel motor cannot run Your Roomba may be stuck or something may be wrapped around a wheel. Look for something wrapped around the wheels. Push them in and out and make sure they turn easily.
5 beeps: The cliff sensors have failed or are blocked. Turn over Roomba and clear any debris that might be caught underneath the front bumper in the cliff sensors. You can also use compressed air to clean them out.
6 beeps: Wheel obstruction or robot attempting to drive over an obstacle. Turn over Roomba and remove any obstructions that prevent the wheels from seating all the way up into Roomba?s body. Also, remove any obstacles that Roomba could drive over.
7 or 8 beeps: Not applicable Roomba?s beep codes do not include 7 or 8 beeps. If you are getting an error with 7 or 8 beeps, try counting again or contact iRobot Customer Care.
9 beeps: Sensor error Please contact iRobot Customer Care.
10 beeps: Roomba is stuck Pick up Roomba and start it again somewhere else. Use a virtual wall or other barrier to keep Roomba away from the
place it got stuck.
Your Roomba may be experiencing an issue where the battery is deeply discharged and may need to charge longer than the standard 3 hours. (or 7 hours if you have a standard charger)
Even with the charging light showing green (this indicates a fully charged battery) the robot is still charging. If your Roomba exhibits behavior where it charges for a short time then runs for a short time you will need to do the following.
1. Plug the charger into Roomba (if you have a home base be sure to plug directly into Roomba instead of using the home base, this will ensure the robot's charging cycle is not interrupted.)
2. After the Roomba's charging indicator goes to solid green please keep the Roomba on the charger for an additional 72 hours. (3 days)
3. After the 72 hours (3 days) has passed, turn your Roomba on and begin a normal cleaning cycle. If this works successfully it may take several uses for the battery to get back up to the performance it once had.
If this does not correct the problem, please call customer support at 877-855-8593
Nov 22, 2012 | Vacuums
Once vacuum is turned on and switched to a certain carpet level, the red light begins to flash and the brush stops spinning. How do we fix this?
The brushbar is designed to stop rotating if you've set it at a level too low for the pile of the carpet you're trying to clean. The indicator light will flash to warn you of this. Using the cleaner with the brushbar raised to the next level on the selector pad should prevent this issue from occurring.
If you have any further concerns about your vacuum, please get in touch with us directly on 1866MYDYSON. One of our experts will be happy to provide the assistance you need.
Kind regards,
Jack
Dyson Online Customer Support
Sep 24, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
Caught fridge of a blanket in vaccum. Turned off and remove object. Now beater bar does turn. How to fix?
Sounds like the belt either just slipped off, or is broken.
It's normal when the beater gets jammed.
Can you spin the beater easily?
Jun 24, 2011 | Kenmore Progressive Upright Vacuum with...
When I turn on the unit and push on the level that draws the "arm" back, it immediately shuts off. I return it to the upright position and turn it on again and repeat the process. Same thing...
seems like there is a short in the unit. it is extremely hard to find kenmore parts. i would probably just go out and buy a new vacuum. Kenmores arent worth fixing.
Mar 22, 2011 | Kenmore Progressive Upright Vacuum with...
EVERYTIME I PUSH THE BUTTON REALLY LOW TO ALLOW THOROUGH CLEANING IN THE CARPET, THE LIGHT DOESN'T TURN ON AND IT DOESN,T **** THE DIRT AT ALL.. IT ONLY WORKS IF YOU PRESS IT UP ONCE BUT IT DOESN'T GET ALL...
You need to replace the belt whenever the green brush indicator light goes out or is not steady. Be sure to observe the wear settings when re-installing the brush. The ends of the brush are marked with 1, 2, or 3 notches and numbers. In normal use the brush should have setting # 1 towards the rug. These settings adjust the brush for wear, and moving the bristles out prematurely will result in excess brush and belt wear.
Feb 24, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Kenmore InteliClean 116.35923502 Two, I believe unrelated, problems. 1) The InteliClean sensor lights stay amber and red even when the machine is in the upright position and the suction line is...
I had the same problem with the amber inteliclean light continually on. I found the problem to be in the plastic housing that connects the suction hose to the back of the upright section. You have to remove three screws and gently pull the hose housing off the vacuum. Inside I found a hairy clump that was caught on the inside of the hose. The optical "dirt sensor" is just inside the fitting on the upright section. When dirt or other stuff blocks the optical path of the sensors, the amber light will illuminate. My vacuum had an uneven cut on the hose which caused a snag point for hair, dirt and debris. Once this was removed, the vacuum worked like new.
Regarding the roller, this unit has an integrated motor in the roller. I would guess that you will need to take it apart, and hopefully only clean it up. If you need bearings, that will likely be expensive.
Dec 24, 2010 | Kenmore Progressive Bagless Upright with...
Kenmore Model 116 upright beltless vacuum, agitator will not turn
I had the same problem. The agitator stopped turning after I sucked up a foreign object (my wife's watch) and it got jammed in the intake. After removal of the watch the agitator did not spin when turning on the machine, and the reset button never deployed (it remained buried in its housing and would not depress with a paper clip). The agitator was not bound and I could manually move it in both directions with ease. Faced with prospect of paying $125 or more for a repair, a good sharp kick to the chassis from the top promptly fixed the problem. I have found that kicking malfunctioning electronics often works.
Jul 28, 2009 | Kenmore 31913 Progressive Direct Drive...
Loud noise from Kenmore Progressive Bagless Inteli-Clean
Here is a possible solution. If the vacuum sounds normal when the green light comes on, then the issue is a suction bypass. Kenmore built a suction bypass in to help cool down and protect the motor should someone either never clean the filter, empty the canister or somehow manage to clog the hose. There is a spring holding the bypass closed and is overridden by vacuum suction. I guess the spring becomes weak, allowing high suction to pull it open which in turn reduces suction so it closes again. It can do this several times per second making a loud racket and slightly affecting performance until the sensor goes green, then the vacuum suction is too low to overcome the spring tension thus why it sounds fine then. The trick? The very hard way (what I did) was to open the vacuum, open the casing where the spring is and pull it apart slightly to increase the spring tension. The easy way is to put tape over the hole where the bypass is. The inlet is under the hose track on the back on the right side as you're looking at it. The hole is about the size of a quarter and you'll see fins across the hole. The tape would keep the suction. The motor would still pull back the bypass but since tape is applied, there would be nothing to reduce the suction thus keeping performance and reducing the noise. However, this circumvents the intended design so you do so only at your own risk.
Jul 04, 2009 | Kenmore Progressive Bagless Upright with...
Do i want the green light on or off on kirby upright
It has nothing to do with the green light. Green light simply indicates that brush roll is spinning. If there is no green light:
1 - belt may be broken
2 - Improperly installed nozzle
3 - wrong brush roll is installed
Properly adjust the nozzle - turn the Kirby on. Keep lowering the nozzle till it touched the carpet and you will hear change in sound. Then lower it by one more click.
Rocky
(GoodVac.com)
Mar 30, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Kenmore 35912 / 35913 Progressive Upright Vacuum Logo
303 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
