Not showing DTS MASTEr OR DG True HD
Onkyo TX NR905
when I play movies in my PS3 with Dolby Digital Trus HD or DTS Master Audio HD display showing detect Dolby Digital or DTS. why it wont show DTSMAHD or DGTHD?
  • bourbon_1 Dec 31, 2008
    my tx-sr875 does the exact same thing.  Onkyo tech support are no help
  • nevot Apr 07, 2009
    not showing DTS MASTEr OR DG True HD", onkyo 9100thx
In the menu is an option for switching master and true hd on. Standard its of and played als normal dts/dolby.
also: check the input (blu ray?): maybe it is set to only output no high def signals, so the amlifier doest recieve hd sound..
Igor
Posted on May 30, 2009
Onkyo HT-S3400 not showing DTS-HD Master Audio
Hello, with the source playing press the display button on the remote. What format do you see? Thank you, CB
Apr 05, 2017 | Onkyo 5.1-Channel Home Theater Package...
Does kenwood VR-405 play DTS-HD Master
I have the 405 and a Samsung 3600 which has onboard DTS Master/ Dolby True HD. Out of the 6 movies I 've watched, only 2 have given me Dolby Digital. Bottom line: If the movie doesn't have DD, you cant get DD on the 405. I thought just about all blu rays had DD but its not so. Its time for us to upgrade!
Oct 24, 2009 | Kenwood VR-405 Receiver
Sound skipping while playing Blu Ray
HI, make sure the audio out put on the ps3 is set to hdmi and set to stream dolby digital,aac, dts, etc,then set audio input on your 696 to hdmi,also check that audio out for hdmi is set to off in the hardware menu on your amp,if you still have problems use the optical out on the ps3 as the ps3 does not out put hd master audio or dolby true hd only pcm, you will still get dolby digital.
hope this helps.
CABLE GUY.
Feb 08, 2009 | Onkyo TX-DS696 Receiver
DTS Master HD audio problem
Hey! Make shure your amp and blu-ray player output and input signals are set to "bitsteam" and you are useing HDMI and optical connections. I hooked up my Onkyo tx sr 506 integrated amp to a Samsung BD 1400 player and everthing worked perfectly right out of the box. Perhaps your amp can"t decode DTS HD Master or your blue ray doesn't support it although i think a firmware upgrade may accomplish this. Put on The Chronicles of Narnia Prince Caspian which will DEFAULT to DTS HD MASTER 7.1 and see if it works. It's an excellent source to test your system. Picture and audio recieved 5 stars from Home Theatre magaziene and like i said, either your amp, or player doesn't support it or your interconnects are keeping it from coming thru. HDMI and OPTICAL connects and check your set up for "bitstream" Remember what Todd Rundgren allways said,"Everything will work if you just let it!"
Feb 05, 2009 | Yamaha RX-V663 Receiver
No DTS-HDMA or Dolby TrueHD shown on display
DTS-HDMA and Dolby TrueHD cannot be passed to your receiver via bitstream on the PS3. DTS-HDMA cannot be decoded either so you're out of luck there.
Dolby TrueHD can be decoded internally on the PS3 assuming your firmware is up to date. Set the Blu-ray HDMI output to PCM and you can then pass it to your receiver.
If this doesnt work, do a system update on your PS3.
Jan 24, 2009 | Onkyo TX-SR606 Receiver
No output of hd audio
Change audio settings on PS3 to PCM not bitstream
Jul 26, 2008 | Denon AVR 3808Ci Receiver
Onkyo TX-SR605 7.1 Channels... Problem
firmware up date go to onkyo homepage
Apr 01, 2008 | Onkyo TX-SR605 Receiver
True HD - biggest secret
Are you playing a TrueHD format disc? Just like DTS 5.1 or any other format if your disc isnt coded in TRUEHD then your not going to get it. DTS or other formats cannot be "converted" to TrueHD like the video portion of a standard def disc. At this point there arent alot of TrueHD discs out but be paitent, this may change. Or not, due to the fact there are other "lossless" formats that may be more widely adopted. Sort of like DTS and THX were when DVD first came out. Hope this helps.
Mar 31, 2008 | Onkyo TX-SR605 Receiver
Onkyo sr 605
Check with and download the firmware update from the Onkyo web site.
Mar 16, 2008 | Onkyo TX-SR605 Receiver
1,274 people viewed this question
 Grubhead
Grubhead
