Question about XO Vision XO-2703 7 in. Car Monitor
XO-2703 WIRING I NEED TO KNOW WHERE I CAN GET THE COMPLETE WIRING HARNESS FOR THE MONITORS. WHERE IT PLUGS INTO THE MONITOR ALL THE WAY TO THE DVD PLAYER ??? THANK YOU
  • Anonymous Mar 15, 2014
    xo vison monitor working but the dvd player monitor aint powering on
  • 944 Answers
Try these guys - although they only allow installation by licensed installers, so they may not supply parts. http://xovision.com/contact.htm Wiring harnesses for this type of application will differ considerably from vehicle to vehicle depending on the location of the monitor and player and the route through which cabling has to be threaded, so they are usually constucted in situ. The connectors on these units should be standard, so any auto electric shop should be able to wire it up, but be careful not to void any warranty on the monitors. Hope this helps :)
Posted on Mar 19, 2007
What can i do to wacht dvds?
you must have connected the safety feature to the hand brake.
this disconnects the dvd from working until the hand brake is applied. you will need to attatch this wire to a ground connection to enable it to be played while moving
Apr 06, 2010 | XO Vision GX1046 10.4 in. Car Monitor
Xo vision gx2022..need the plug that turns video wire into rca's
radio shack online or crutchfield.com may have what you need
Dec 27, 2009 | XO Vision GX2022 Car Monitor
Xo vision XO1943BT
CHECK YOUR WIRES AT THE HARNESS WITH A TEST LIGHT TO BE SURE YOUR GETTING POWER TO THE HARNESS.AND A GROUND AS WELL. ANOTHER WAY TO CHECK IS TAKE THE UNIT OUT AND CONNECT DIRECT TO THE BATTERY UNDER THE HOOD
Aug 25, 2008 | XO Vision MD068 6.8 in. Car Monitor
WONT PLAY DVD
Try cleaning the discs, or check the inside of the DVD player.
Mar 27, 2008 | XO Vision GX1042 10.4 in. Car Monitor
XO Vision GX 1236
With solder.
atdlee@netzero.com
Mar 06, 2008 | XO Vision 12.1 Flip-Down Monitor w IR"
9" FLIP DOWN TFT LCD CAR MONITOR DVD OVERHEAD TV
No problem.
The size will not be the same.
Ask for the size, you wants the same or a larger size.
atdlee@netzero.com
Mar 05, 2008 | XO Vision GX733 7.3 in. Car Monitor
Flip down monitor
Check with a 12VDC from those drill battery.
Positive to red wire
Negative to black wire
Turn on radio.
atdlee@netzero.com
Mar 02, 2008 | XO Vision GX1042 10.4 in. Car Monitor
XO Vision XO-141FM 14.1 in. Car Monitor
Check that you have good ground connections.
Use DVM to check if you have 12VDC to player.
If you have no DVM, you can use small car light bulb with leads.
If bulb lits from ground and hot wires, then player is bad. Or most likely a loose connections.
atdlee@netzero.com
Feb 02, 2008 | Car Audio & Video
Xovision monitor
To what car?
Black wire to ground.
Red wire to +12VDC.
Yellow cable to input of Yellow Input's radio.
atdlee@netzero.com
Dec 21, 2007 | XO Vision 12.1 Flip-Down Monitor w IR"
XO Vision XO-2703 7 in. Car Monitor Logo
377 people viewed this question
Top XO Vision Car Audio & Video Experts
Marvin
Marvin
jason
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
